我们如何评估设备:
维修一个拥有完美分数的设备是相对便宜的,因为它很容易拆卸,并且有一个维修手册。分数的确定是基于打开该设备的难度、内部的紧固配件类型、以及更换主要组件的复杂程度。对设备升级度,能够使用非专有工具维修,和组件模块化给予了加分。
排序方式: 按版本 | 按维修分数
iPad 6 修理
  • 和所有iPad一样,牢固的粘合胶阻碍了任何维修,这使得返工成为了一个棘手的问题。
  • 粘合胶几乎占据了整个内部空间,电池的更换变得非常具有挑战性。
  • LCD屏幕上有泡棉胶,因此在拆卸过程中会增加损坏的风险。
2
Acer Iconia One 7
  • LCD and front glass are not fused and can be replaced individually.
  • Battery is easy to replace.
  • High wear components soldered in place, which increases replacement costs.
8
Kindle Paperwhite 7th Generation
  • The battery was very easy to remove.
  • All screws were Phillips #00 screws.
  • Thin layer of adhesive that needed to broken in order to remove the bezel and access the internal components.
8
Huawei MediaPad M2
  • The display is easily removed from the simple clips holding it to the body, simplifying repairs.
  • Most components are modular and not overly complex.
  • The battery is extremely difficult to remove, even with heat and prying.
7
Amazon Fire 5th Generation
  • The plastic case assembly is held together by clips and no adhesive, and opening only requires prying with an iFixit opening tool.
  • The digitizer and LCD panel are not fused together.
  • Removing the digitizer and LCD panel requires fighting through some very resilient adhesive.
7
HP ElitePad 1000 G2 Teardown
  • Display is easy to remove and has no adhesive.
  • Most commonly-failing components, including all the ports and buttons and are modular and can be replaced quickly.
  • RAM and SSD are soldered to the motherboard and non-upgradable.
7
Huawei MediaPad T2
  • Rear case is secured by clips, not glue, and is flexible enough to remove fairly easily.
  • Non-proprietary Phillips screws used throughout.
  • Battery is held in place with excessive adhesive. A hole in the midframe means prying the battery out may risk damaging the back of the display.
6
Sony Xperia Z4 Tablet
  • The delicate and arduous opening procedure leaves no room for mistakes, and must be completed to access any other component.
  • The display assembly consists of a thin fused glass panel and LCD, and is extremely difficult to remove and replace.
  • Many parts are modular and can be replaced independently.
5
Samsung Galaxy Tab S3
  • In order to repair or replace anything, both the front and rear panel need to be removed.
  • The front and rear panel are secured in place with a lot of adhesive, and are extremely hard to remove.
  • Many components (including the headphone jack, speakers, and micro SD slot) are modular and can be replaced.
4
Microsoft Surface Pro 5
  • 许多元件使用粘合介质进行固定,包括屏幕和电池。
  • 更换任何部件都需要先拆除屏幕,而屏幕又是易损的东西。
  • 固态硬盘不再能够更换。
维修iPad Pro 10.5寸
  • 融合的前面板增加了屏幕修复的成本,以及打开时损坏LCD屏幕的风险。
  • 胶水把所有东西都固定到位,使所有修理更加困难。
  • 虽然没有被焊接到逻辑板上,但电池被胶水固定得非常牢固,没有像我们在12.9寸iPad Pro 中看到的拉片。
2
LG G Pad 7.0
  • Very modular design allows independent replacement of several wear-prone components—like the headphone jack and speakers.
  • Only very mild adhesive holds the battery in place, making it fairly easy to safely remove and replace.
  • Display assembly is a single fused component, that requires disassembling the entire phone to replace.
8
iPad 5 Wi-Fi
  • 就像前几代iPad,前面板用胶水固定。在维修的过程中有非常大的可能会造成前面板玻璃的损坏。
  • 大量的粘合剂把所有东西粘在一起。像前辈Air 1一样,iPad 5是迄今为止电池最难拆解的iPad。
  • LCD由海绵胶条固定,拆解的时候很有可能会造成屏幕碎裂。
2
HP Pro x2 612 G2
  • 制造商提供维修资料。
  • 简单的拆解过程。
  • 复杂的结构允许模块化,但使修复不必要地更复杂。
9
Google Pixel C
  • The motherboard is glued tightly to the rear case.
  • Crazy strong adhesive holds the battery to the rear case, complicating the inevitable replacement.
  • Many parts, including the USB-C port, are modular and can be replaced independently.
4
HP Elite x2
  • 简单的拆解过程。
  • 简单,模块化,无胶设计。
  • 制造商提供维修资料。
10
iPad Pro 9.7"
  • 融合的前面板增加了屏幕修复的成本,以及打开LCD时损坏LCD的风险。
  • 胶粘剂黏着有的一切,使所有维修更困难。
  • 虽然没有焊接到位,电池非常坚固 - 没有像我们在更大的iPad Pro 12.9“中见的拉片,
2
iPad Pro 12.9"
  • The fused front panel increases the cost of screen repair, and the risk of damaging the LCD when opening.
  • Gobs of adhesive hold everything in place making all repairs more difficult.
  • The battery is not soldered to the logic board, and can now be removed with adhesive tabs, greatly simplifying battery removal.
3
Microsoft Surface Pro 4修理
  • 屏幕总成由全贴合的玻璃面板和液晶屏组成,极难分离和更换。
  • 多数元件由胶水固定,包括屏幕和电池。
  • 电池并非通过焊接与主板相连,但强力的胶水使得电池更换变成了一项危险的苦差事。
2
iPad mini 4 Wi-Fi修理
  • The fused front panel also increases the cost of repairing a cracked screen, and increases risk of damage to the LCD when opening.
  • The Lightning connector is soldered to the logic board, so don't bend its pins.
Kindle Voyage
  • Several modular components can be replaced individually.
  • Screws secure a slide-off rear case, simplifying opening procedure compared to other Kindles.
  • The front glass and e-ink display are fused together, increasing the cost of repairs.
7
Nexus 9
  • The interior is a maze of tape and thin, delicate cables, making disassembly and reassembly difficult and perilous.
  • The LCD is fused to the front glass, so you'll need to replace both components in the event of a cracked screen.
  • The rear case is secured with clips, so it can be easily removed without heat or tools (just don't lose your rear-facing camera).
3
iPad Mini 3 Wi-Fi修理
  • Copious amounts of adhesive hold many components in place—front glass, battery, front camera, back camera, ribbon cables—making repair extremely difficult.
  • Removing the home button is now a much more difficult job. If you want to keep Touch ID functionality after a screen replacement, you'll have to transfer the home button to the new front panel.
2
iPad Air 2
  • Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
2
Kindle 7th Generation
  • Simple, modular design with few, distinct components that can be replaced independently.
  • Easy opening procedure—clips supplemented by mild adhesive are all that hold the front bezel in place.
  • Battery adhesive is much stronger than necessary, making its replacement hazardous.
8
Kindle Fire HD 6
  • The rear case is very easy to open, granting trouble-free access to the internals.
  • All the fasteners found inside are T5 Torx screws—one non-proprietary screwdriver is all you need.
  • The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
6
Microsoft Surface Pro 3 修理
  • The display assembly consists of a fused glass panel and LCD, and is extremely difficult to remove and replace.
  • Tons of adhesive hold everything in place, including the display and battery.
  • The delicate and arduous opening procedure leaves no room for mistakes: one slip-up, and you'll be out a screen.
iPad Mini 2
  • Hidden screws mean you'll need to be very diligent when trying to remove internal components.
2
Amazon Kindle Fire HDX 8.9"
  • 前面板使用固定扣固定。
  • 模块化设计允许更换几个组件。
  • 电池是被牢牢粘上去的,难以移除。
7
iPad Air LTE
  • Gobs, gobs, and goblins of adhesive hold everything in place. This is the most difficult battery removal procedure we've seen in an iPad.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
2
Microsoft Surface Pro 2
  • The delicate and arduous opening procedure leaves no room for mistakes: one slip-up, and you'll likely shear one of the four ribbon cables in the edge of the display.
Kindle Fire HDX 7"
  • The battery is glued in place with strong adhesive and requires motherboard removal to replace.
  • The motherboard is very difficult to replace—the midframe must be separated from the display assembly in order to reinstall it.
3
Kindle Fire HD 2013
  • Simple, modular design means the few components that might fail can be easily, inexpensively replaced.
  • All the fasteners found inside are Torx T5 screws—one non-proprietary screwdriver is all you need.
  • A decent amount of adhesive is used on the battery, meaning some prying and gentle working is required for disassembly.
8
Dell XPS 10
  • 易拆开,且电池易拆卸。
  • 彩色编码的螺钉和内标电缆。
  • 液晶是融合在玻璃上的。
9
  • The display assembly (comprising of a fused glass and LCD) is extremely difficult to remove/replace.
  • Unless you perform the opening procedure 100% correctly, chances are you'll shear one of the four cables surrounding the display perimeter.
Amazon Kindle Fire HD 8.9"
  • 因为只有数个固定扣,拆卸该设备非常容易。
  • 融合的液晶屏和前面板玻璃需要热胶枪。
  • 电池和电缆被粘在外壳上。
5
Google Nexus 10
  • 易拆卸电池。液晶屏不与玻璃融合。
  • 拆卸过程十分困难。
  • 一些组件使用螺丝和胶水固定。
6
iPad Mini Wi-Fi
  • Copious amounts of adhesive hold many components in place -- front glass, logic board, battery, front camera, back camera, ribbon cables -- making repair extremely difficult.
2
iPad 4 Wi-Fi
  • Just like in the iPad 2 & 3, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • Gobs, gobs, and gobs of adhesive hold everything in place, including the prone-to-start-a-fire-if-punctured battery.
2
Microsoft Surface RT
  • It's pretty difficult to remove the rear panel and gain access to the device.
  • It is impossible to remove the keyboard connector without first removing the display from the frame.
  • Several components are modular and replaceable without requiring desoldering.
4
Kindle Fire HD
  • The battery is held in with absolutely no adhesive.
  • Copper tape over the processor is somewhat difficult to remove and to readhere correctly.
7
Nexus 7
  • The rear case is very easy to open, and requires minimal prying effort with a plastic opening tool to remove.
  • All fasteners inside are Phillips #00 screws—no security or proprietary screws here.
  • The LCD does not separate from the display glass, increasing repair costs.
7
Nook Simple Touch with GlowLight
  • The opening procedure was very simple, and aside from the massive amounts of adhesive, every part came free rather easily.
  • There were a total of only 12 screws (all T5 Torx), 11 of which were the same length.
  • The front glass, GlowLight LEDs, and digitizer are fused together, so breaking any of these parts will require replacement of the entire display assembly.
7
Samsung Galaxy Tab 2 7.0
  • 模块化设计和便于拆卸的组件。
  • 前面板玻璃未与液晶屏融合。
  • 需要热风枪才能更换液晶屏。
8
iPad 3 4G
  • Just like the iPad 2, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • Gobs, gobs, and gobs of adhesive hold down everything in place, including the prone-to-start-a-fire-if-punctured battery.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of the front panel being shattered during disassembly
2
Nook Tablet
  • The LCD is not fused to the front panel assembly, making replacement easy, if necessary.
  • Hidden screws prevent removal of rear panel.
  • Excessive amount of adhesive and adhesive strips make disassembly a painfully tedious process.
6
Kindle Fire
  • All the fasteners found inside are Phillips #0 screws—one non-proprietary screwdriver is all you need.
8
iPad 2 Wi-Fi EMC 2415
  • The front panel is now glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • The battery is very securely stuck down to rear case, and you have to remove the logic board to remove it.
2
Motorola Xoom
  • There's no proprietary screws or fasteners in the machine -- everything comes out with a spudger and a couple of Torx screwdrivers.
  • LCD and front panel glass are not fused together. That's great news for folks unfortunate enough to drop their Xooms and crack their glass.
  • Everything is accessible but somewhat inconvenient to repair -- there's just a lot of labor involved with removing that many screws.
8
Dell Streak
  • Good: Replacing the battery is super easy and takes less than one minute.
  • Good: Opening the device requires prying the bezels and removing five screws.
  • Bad: The LCD is bonded to the Gorilla Glass, increasing the cost of fixing the device if you break just the glass.
8
iPad Wi-Fi修理
6
蜀ICP备17039037号
