我们如何评估设备:
维修一个拥有完美分数的设备是相对便宜的,因为它很容易拆卸,并且有一个维修手册。分数的确定是基于打开该设备的难度、内部的紧固配件类型、以及更换主要组件的复杂程度。对设备升级度,能够使用非专有工具维修,和组件模块化给予了加分。
排序方式: 按版本 | 按维修分数
MacBook Pro 15" Touch Bar 2018修理
  • The processor, RAM, and flash memory are soldered to the logic board. Repairs and upgrades will be impractical at best.
  • The top case assembly, which includes the keyboard, battery, and speakers, is firmly glued in place—making all those components hard to replace separately.
  • The Touch ID sensor doubles as the power switch, and is paired with the T2 chip on the logic board. Fixing a broken power switch may require help from Apple, or a new logic board.
MacBook Pro 13" Touch Bar 2018
  • 处理器、内存、闪存等均被焊接在了主板上,维修和升级工作是不现实的。
  • 上壳总成,包含了键盘、电池、触控板和扬声器被胶水粘在了一起,让这些部件变得难以分离。
  • 触控 ID 按键兼做电源按钮,且与主板上的 T2 芯片配对,修复电源开关需要来自苹果的服务,或者一块全新的主板。
HP EliteBook 840 G3
  • RAM, SSD, and battery are easily accessible and removable.
  • All moving parts, including keyboard, trackpad, and pointing stick are modular and can be quickly replaced.
  • The display is immediately replaceable, without any unnecessary disassembly.
10
Dell Latitude E5270
  • All commonly failing (battery, trackpad buttons, display, keyboard) and upgradable (RAM, SSD) parts are easy to access and replace.
  • Minimal adhesive is used throughout the unit's construction. All fasteners are standard Phillips screws.
  • Overall construction is slightly complicated, but the manufacturer offers clear repair and disassembly instructions.
10
LG Gram 15"修理
  • Most components are immediately accessible after removing the lower case cover.
  • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
  • Battery is also user-replaceable.
9
Samsung Notebook Series 9 15"
  • All screws are Phillips screws.
  • RAM, SSD, and battery are all easily replaced.
  • Relatively flat, modular design means that most components can be replaced quickly without having to remove other obstructions.
9
Acer Predator 17.3"
  • A single latch releases the optical drive—no tools required.
  • A single panel gives access to the SSD, HDD, and two RAM slots.
  • The keyboard is not readily serviceable.
8
Dell XPS 13 (9343/9350/9360)
  • Manufacturer provides free manuals online.
  • Once you manage to take off the bottom cover, all the parts are pretty easily replaceable.
  • Soldered RAM means you'll never be able to upgrade when things get slow.
7
微软 Surface Laptop 修理
  • 这款笔记本根本不打算被打开或修复,你没法在不大搞破坏的情况下进入内部。
  • CPU,内存和其他板载的储存都被焊死在主板上,没法升级。
  • 耳机接口,模块化,但是只能通过移除热管,风扇,屏幕和主板来进入。
0
Retina MacBook 2017
  • The processor, RAM, and flash memory are still soldered to the logic board.
  • A large amount of strong adhesive holds the battery assembly to the lower case .
  • The Retina display is a fused unit with no separate, protective glass. If the display is damaged, it'll be arduous and expensive to repair.
MacBook Pro 13" Touch Bar 2017修理
  • 专有五角螺丝增加了拆解的不必要麻烦
  • 电池组完整并且非常牢固的用胶水粘连在外壳上,让替换变得十分困难。
  • 处理器 内存 以及硬盘都焊接在主板上
2016年末Retina显示器MacBook Pro 15"带有Touch Bar版本
  • 防撬螺丝使Mac更难被拆解
  • 电池非常难拆,被强力胶粘合在机身上,使得更换电池变得非常困难
  • 处理器,内存以及硬盘被焊接在主板上无法进行更换
MacBook Pro 13" Touch Bar Late 2016修理
  • 专有的Pentalobe 螺丝继续增加了维修设备不必要的困难。
  • 电池组件完全地且非常牢固地粘附到外壳中,使得更换变得非常复杂。
  • 处理器,内存和闪存都被焊接在逻辑主板板上。
MacBook Pro 13" Function Keys Late 2016修理
  • 防撬螺丝使Mac更难被拆解
  • 内存焊接主板。有需要升级,需要在购买时升级或者就永远8GB,没有其他机会升级
2
Retina MacBook 2016
  • The battery assembly remains entirely, and very solidly, glued into the lower case.
  • The Retina display is still a fused unit with no separate, protective glass. If the display needs replacing, it'll cost a pretty penny.
Asus Chromebook C202
  • Intuitive, uncomplicated design makes disassembly straightforward and reversible.
  • Modular components means many repairs can be carried out by quickly swapping a failed part.
  • Only Phillips #1 and #00 screws are used.
9
Retina MacBook 2015
  • 全部使用五角梅花螺丝让整个设备的打开变得不必要地麻烦,新的线缆让整个挣个步骤变得更加麻烦。
  • USB-C接口由三角螺丝固定,并且被隐藏在显示屏下方,让修复变得更加麻烦,而且,单一接口与典型的单一用途接口相比会影响使用与携带。
  • 电池是被完全安装进去的,而且非常坚固,在机身中被胶水粘住
MacBook Pro(13 英寸,配备 Retina 显示屏2015 年初期)维修
  • 专有的防撬螺丝继续使该设备的开启有着不必要的困难。
  • 电池的组装完全,而且非常牢固,粘在外壳上,因此使更换变得更加复杂。此外,电池还可以将触控板固定在合适的位置,这意味着在不首先移除电池的情况下,不可能更换触控板。
  • 视网膜显示屏是一个整体,没有单独的保护玻璃。如果在显示器内部有任何问题,那么整个($$)组装就需要被替换。
MacBook Air 11" Early 2015
  • The outer case is held on with Apple's proprietary Pentalobe screws, so you'll need the right screwdriver to get inside.
  • Just like the screws, all the components—including the RAM and SSD—are proprietary, making replacement parts more difficult to source.
  • Once you get past the outer case, all the major components are fairly easy to access for replacement.
4
MacBook Air 13" Early 2015
  • Proprietary screws on the case require the right screwdriver.
  • All the components—including RAM and SSD—are proprietary.
4
MacBook Pro 13" Retina Display Late 2013
  • Proprietary pentalobe screws continue to make opening the device unnecessarily difficult.
  • The battery assembly is now entirely, and very solidly, glued into the case, thus complicating replacement. Additionally, the battery now covers the screws and cable holding the trackpad in place. It is impossible to replace the trackpad without first removing the battery.
  • The Retina display is a fused unit with no protective glass. If anything ever fails inside the display, the entire ($$$) assembly will need to be replaced.
MacBook Pro 15" Retina Display Late 2013
  • 专有的五角螺丝可阻止你进入任何内部物品。
  • 与在MacBook Air中一样,RAM被焊接到主板。现在最大限度为16GB,或者永远保持内心平静——你无法升级。
  • 专有SSD已改为PCIe格式,但仍然不是标准的2.5英寸驱动器。但是,它是一个单独的子卡,我们希望我们可以在不久的将来提供升级。
MacBook Air 11" Mid 2013
4
MacBook Air 13" Mid 2013
4
Dell Inspiron Duo
  • Much of the internal hardware is not only user-replaceable, but is also easy purchased from Dell or a third party vendor.
  • Almost the entire computer can be taken apart with a plastic opening tool (or two) and a Phillips #0 screwdriver.
  • You have to remove the top case to access the battery, which is shameful for a Dell product.
7
MacBook Pro 13" Retina Display Late 2012
  • The battery is still glued into the laptop's top case, but it's slightly less difficult to remove compared to the 15" model.
  • Proprietary pentalobe screws prevent you from gaining access to anything inside.
  • The RAM is surface-mount soldered to the logic board, so no upgrade is possible. It will forever have 8 GB of RAM.
2
Asus Zenbook UX32VD
  • All the components are easy to access, with no proprietary screws inhibiting access.
  • The battery is not glued in place, and a person equipped with the right tools can replace it in a matter of minutes.
  • A lot of components were held in place with more adhesive than is necessary.
8
MacBook Pro 15" Unibody Mid 2012
  • Easily removable bottom panel and readily accessible battery, optical drive, hard drive, fans, and RAM.
  • Standard screws were used for all components, save for the battery.
  • Tri-wing screws on the battery require a specialty driver that an average user may not have.
7
MacBook Pro 15" Retina Display Mid 2012
  • As in the MacBook Air, the RAM is soldered to the logic board. Max out at 16GB now, or forever hold your peace—you can't upgrade.
  • The proprietary SSD isn't upgradeable either (yet), as it is similar but not identical to the one in the Air. It is a separate daughtercard, and we’re hopeful we can offer an upgrade in the near future.
MacBook Air 13" Mid 2012
  • 底盖上的专用螺丝需要正确的螺丝刀拧下。
  • 所有组件—包括RAM和SSD—都是专用的。
  • 一旦你设法打开底盖,所有的零件都很容易更换。
4
MacBook Air 13" Mid 2011
  • Opening the bottom cover is quite difficult if you don't have the right screwdriver. It's clear that Apple didn't want people to open their machine.
  • All the components -- including RAM and SSD -- are proprietary, meaning that no off-the-shelf parts will work in it without serious rigging.
4
MacBook Pro 15" Unibody Early 2011
  • Easily removable bottom panel and readily accessible battery connector allow for easy repair of most components without touching the battery screws.
  • Unibody design allows for easy access of most components with minimal amounts of extra work needed to get to them.
  • Tri-wing screws limit the average person from replacing their own battery.
7
MacBook Air 11" Late 2010
  • All the components -- including RAM and hard drive -- are proprietary, meaning that no off-the-shelf parts will work in it without serious rigging.
4
蜀ICP备17039037号
