在此拆机指南中的精选工具
简介
You may have heard a lot about the new Fairphone 2—the small Dutch company has been making waves with its affordable, modular, conflict-free cell phone, and once again, we're one of the first to get our hands on their latest device. When we tore down the original Fairphone, we were pleased by its modularity and easy access. Today, we're excited to see what this second-generation, responsibly-designed device has in store for us. Join us as we join the movement!
Want the inside scoop on all the newest tech? Check us out on Facebook, Twitter, and Instagram to stay up-to-date with the latest news in the repair world.
这个拆解是不是维修指南。 要维修你的的Fairphone 2,请使用我们的服务手册
Here we have the second generation of the Fairphone. It's grown in size and in style: 5" 1080p LCD display (446 ppi) with Gorilla Glass 3 protection
  • Here we have the second generation of the Fairphone. It's grown in size and in style:
    • 5" 1080p LCD display (446 ppi) with Gorilla Glass 3 protection
    • Qualcomm Snapdragon​​ 801
    • 2 GB LPDDR3 RAM
    • 32 GB internal storage with expandable storage via MicroSD slot
    • 2420 mAh user-removable lithium-ion battery
    • 8 MP rear camera
    • Android​ 5.1 Lollipop
Wow! That is one ugly looking brick of a phone!
The cheap looking plastic and design would make me stay way clear of it, even if offered to take itself apart.before repairs.
I find it hard to believe that there really is a market for something like this... What's the price?
Victor Szulc - 回复
I'm not too sure what makes this black rectangle any uglier than the rest available for purchase. The clear back is something of a turn-off, personally, but that's hardly a difficult thing to remedy.
Nick Hughes -
The price is 529.38€. The back cover is also available in black matte, black translucent, blue matte, blue translucent.
Julian Andres Klode -
a) Beauty is in the eye of the beholder, so you finding this phone ugly is uninteresting. b) If you prefer to continue using a 'beautiful' phone like an iPhone or Samsung, then you understand nothing about the fairphone project.
Doc Brown -
Measuring in at 143 × 73 × 11 mm, the Fairphone 2 is definitely a size up from the 1st generation. At 168 g (20 grams of which is the case) the Fairphone 2 is only 6 grams heavier than the 1st gen. We can already spot two SIM slots underneath the see-through case. Hooray flexibility!
  • Measuring in at 143 × 73 × 11 mm, the Fairphone 2 is definitely a size up from the 1st generation.
    • At 168 g (20 grams of which is the case) the Fairphone 2 is only 6 grams heavier than the 1st gen.
  • We can already spot two SIM slots underneath the see-through case. Hooray flexibility!
    • The whole phone snaps snugly into this (easily removable) case, no tricks here.
  • What's that? A five pin connector that seemingly connects to nothing? We'll be looking into that later...
  • This phone is lovingly labeled "Designed to open." Music to our ears!
The first item on our agenda is the translucent rear case. It's snug and secure, but snaps off with no tools required. Where's all the adhesive? Is this a dream? Slap. No, definitely not a dream. "Remove battery before releasing screen" Is this a disassembly tip on the battery?
  • The first item on our agenda is the translucent rear case. It's snug and secure, but snaps off with no tools required.
    • Where's all the adhesive? Is this a dream? Slap. No, definitely not a dream.
  • "Remove battery before releasing screen" Is this a disassembly tip on the battery?
    • Nothing makes us happier than when manufacturers include repair instructions with their device, let alone on their device.
  • We're not superstitious, but surely these are signs of even more good things to come.
Just like in the good old days, we lift out the battery and... that's it. No glue, no plugs, no drama. The battery even uses spring contacts instead of the bracket-covered press connectors we've gotten so used to seeing. We can swap out batteries like it's 2005!
  • Just like in the good old days, we lift out the battery and... that's it. No glue, no plugs, no drama.
    • The battery even uses spring contacts instead of the bracket-covered press connectors we've gotten so used to seeing. We can swap out batteries like it's 2005!
  • This handy 3.8 V lithium ion cell is rated at 2420 mAh with an energy rating of 9.2 Wh.
    • For comparison: the LG G4 weighs in with a 3.85 V pack rated for a minimum of 11.2 Wh while the iPhone 6 has a 3.82 V battery with 6.91 Wh.
The lack of visible screws had us a little worried, but not for long thanks to these handily-labeled clips. Removing the display assembly is simply a matter of flipping the switches and sliding the panel out. For those keeping score thus far, removing the front panel keeps us at a grand total of zero tools required.
  • The lack of visible screws had us a little worried, but not for long thanks to these handily-labeled clips.
  • Removing the display assembly is simply a matter of flipping the switches and sliding the panel out.
    • For those keeping score thus far, removing the front panel keeps us at a grand total of zero tools required.
  • On the midframe we find an array of pogo pins, their counter parts are on the back of the display assembly.
  • Immediately below the contact pads on the display assembly we take off the metal shield and see where the display connects to the breakout board.
    • Fairphone modularized off-the-shelf components using breakout boards like these to foster compatibility.
Hi
I just tried pulling out the screen and I must add that it's not that simple to do it safely...
The assembly is quite tough, you must give a good amount of strength to disassemble the screen from the board. My technique was to take in my 2 hands the body and to use a strong flat surface (a table is OK) to help me sliding the screen.
The brackets are very resisting.
At least it won't be too easy to tear it apart ^^
Timothee Simiz - 回复
You are right. The display is mounted very well.
The steps and descriptions of the teardown aren't meant to be read as replacement guides.
You will find more information and pictures in the display replacement guide over here:
Fairphone 2 Display Assembly Replacement
(don't forget to unlock both sliders)
Tobias Isakeit - 回复
I saw a very useful tip on youtube, which comes from the Fairphone support: Give the phone a soft massage, push the display against the chassis forwards and backwards several times, only one or two milimeters, and after a short time it will move. I did that wearing latex gloves, because they have a very good friction and I didn't have to give to much pressure on the display, and in the end it was quite easy to remove.
Bernhard Spranger -
hello,
I'm currently designing a modular laptop concept for a project at university and I'm trying to get my hands on some of the pogo / spring loaded contact connectors which they use in this.
Does anyone have any recommendations for where to find some?
eddiehamiltonmac - 回复
Can't help with that, but must mention that that's pretty cool.
Paul Hendrix -
The wikipedia article on Pogo pins has links to manufacturers: https://en.wikipedia.org/wiki/Pogo_pin
amosbatto -
I guess you find them in Huaqiangbei ( Shenzen, China)
Andreas Azul Ramalhao - 回复
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
Et voilà, we have the mainframe with three individually removable modules. Little icons next to each one indicate what they do:
  • Et voilà, we have the mainframe with three individually removable modules. Little icons next to each one indicate what they do:
    • Headphone jack, earpiece speaker, and front-facing camera module
    • Rear-facing camera module
    • Microphone module
  • We also discover a proud little map showing the sources of the conflict-free tin and tantalum used in the phone.
  • Amazingly, up until this point we've only needed one tool: hands!
It's time to get down to brass tacks screws and see just how repairable the Fairphone 2 really is. We grab our trusty Phillips #0 screwdriver and easily remove all three modules.
  • It's time to get down to brass tacks screws and see just how repairable the Fairphone 2 really is.
  • We grab our trusty Phillips #0 screwdriver and easily remove all three modules.
  • Beneath them we find another level of spring contacts—not a flex cable or press connector in sight.
  • All these Phillips screws are created equal. Don't worry if you mix them up, they are all 5.5 mm.
And with that, we're done with the first level of user repairs. The Fairphone is designed to be easily separated into modular components, but what if you want to fix an individual module? The modules are held together with Torx T5 screws—presumably to deter the casual user from delving too deep—but are still easy to open up.
  • And with that, we're done with the first level of user repairs. The Fairphone is designed to be easily separated into modular components, but what if you want to fix an individual module?
  • The modules are held together with Torx T5 screws—presumably to deter the casual user from delving too deep—but are still easy to open up.
    • We start with the top module: the front-facing camera pops right off thanks to a simple flex cable connector.
    • Spring contacts power the earpiece speaker, making for easy replacement of that as well.
    • The headphone jack, the final component, is soldered to the board. Fortunately, nothing major remains, so a replacement board should be pretty cheap.
Up next, the rear camera module. Hopefully this unit could be upgraded in later years, à la Project Ara. Fingers crossed.
  • Up next, the rear camera module.
    • Hopefully this unit could be upgraded in later years, à la Project Ara. Fingers crossed.
  • The camera itself is an 8 megapixel CMOS camera with a 1/3.2 inch sensor and an aperture of ƒ/2.2.
  • This module is built just like the others: a plastic case around an off-the-shelf component, connected to a pogo interface board via flex cable and connector.
    • Fairphone hasn't quite removed cables or connectors, they have moved them a bit farther from DIY fixers—greatly simplifying component swap repairs.
One last module to crack open—while it's only marked with a microphone icon, there are actually quite a few components in here. The vibration motor and loudspeaker are connected by spring contacts—more easily removed parts, yay!
  • One last module to crack open—while it's only marked with a microphone icon, there are actually quite a few components in here.
  • The vibration motor and loudspeaker are connected by spring contacts—more easily removed parts, yay!
  • The USB port and microphone are soldered to the board—not necessarily a bad thing, as a USB port requires some extra rigidity, and has significantly more pins than a speaker.
The time has come to delve deep into the heart of the Fairphone 2. The metal shield plate, replete with useful icons, comes off first, revealing a heat spreader still hiding the exciting bits. Since this heat spreader rips when being peeled off, Fairphone will have it available as separate spare part.
  • The time has come to delve deep into the heart of the Fairphone 2.
  • The metal shield plate, replete with useful icons, comes off first, revealing a heat spreader still hiding the exciting bits.
    • Since this heat spreader rips when being peeled off, Fairphone will have it available as separate spare part.
  • Along the way, we find an RF cable, that sends the radio signal along the side of the frame to the main antenna, and pluck it free.
What kind of tool do i use to open the 2 screws?
lottevandenberg - 回复
Those are Torx T-5
Tobias Isakeit -
Well isn't this a beauty? We're really digging the translucent plastic frame, showing off all of its embedded antennas and buttons—all of which connect to the motherboard by spring contacts.
  • Well isn't this a beauty? We're really digging the translucent plastic frame, showing off all of its embedded antennas and buttons—all of which connect to the motherboard by spring contacts.
  • And down on the tail there are those five pogo pins we saw earlier. This is actually a USB 2.0 device interface, with power input—ready for future expansions and fancier cases.
    • Possible future upgrades include NFC-embedded cases for quick and easy payments.
I've had SIM card and SD card sockets go wrong on me before so I was hoping these would be replaceable without throwing away the entire core unit. No such luck it seems. It would have been cool if these had been embedded in the frame instead. I guess that would imply a lot of spring connectors though.
Matthew Exon - 回复
And now for the tech section.
  • And now for the tech section.
    • Samsung KLMBG4WEBC 32 GB eMMC NAND Flash
    • Qualcomm WCN3680B Wi-Fi 802.11ac Bluetooth Combo (Based on information from the Fairphone team!)
    • ST Microelectronics LSM330DLC 6-Axis Accelerometer + Gyroscope
On the backside we find a lot more:
Fairphone 2 Repairability Score: 10 out of 10 (10 is easiest to repair) The LCD and cover glass are fused, simplifying removal, but significantly increasing the cost of replacement.
  • Fairphone 2 Repairability Score: 10 out of 10 (10 is easiest to repair)
  • The LCD and cover glass are fused, simplifying removal, but significantly increasing the cost of replacement.
  • The most commonly failing components, battery and display, can be replaced without tools.
  • Internal modules are secured with Phillips #0 screws and simple spring connectors.
  • Individual modules can be opened, and many components can be individually replaced.
  • All buttons and cables are easily accessible. Spring contacts allow for future upgrades and easy component swaps.
  • In addition to the in-phone icons and instructions, the Fairphone 2 will ship with repair documentation built-in.
    • Full disclosure: we are receiving funding to co-author the Fairphone’s repair manual as part of the European Commission's initiatives to improve collaboration between the repair industry and manufacturers.
I would have given this a 9/10, and 10/10 if the glass and LCD could be replaced separately, as the glass is a very common point of breakage in drops, as well as being susceptible to scratching. Knowing that replacing damaged glass will not result in the cost of an entire LCD assembly definitely gives a bit more peace of mind. A 9/10 reparability score is still very good though.
timmytripp - 回复
i disagree. for now a perfect 10 score is fair,.
it might warrant a drop in point in the future if a better phone comes out, but for now Repairability Score of 10 is a valid point, as it is the easiest to repair compared to other phone.
milkboy -
I disagree, the fusion of display and front glass has a good reason. By removing the air gap between the LCD and the front glass, they can reduce the Light reflections in this surfaces by a good amount.
So I wouls give this Phone a 10 out of 10.
Thoth -
Just to be fair, I believe the idea is to make the phone so robust that the glass is unlikely to get cracked in the first place. Cracked screens are absurdly common because it doesn't hurt the manufacturer to make them fragile. LCD faults are also pretty common though. If you reduce the smashed glass rate to lower than the LCD fault rate, then the risk tradeoff looks much better. And so the phone is designed so that you can drop it from 6 feet without smashing the glass, something I wouldn't suggest trying with an iPhone.
At least that's the idea. Nothing short of real-life statistics will prove it true or false.
https://www.fairphone.com/2015/06/16/the...
Matthew Exon -
I agree, the fused front assembly should make it a 9/10.
Mel Rabinowitz - 回复
but they are fused by design and repairability doesn't involve that. You could maybe give it a 7/10 or 8/10 on modular design but it shouldn't affect repairability score which we're concerned with here.
Sharad A - 回复
By that logic even phone gets 10/10 because it's a single module and you can replace the whole thing.
From the overall design, I'm expecting this phone to be very user repairable, but also pretty unreliable.
For most users that is a pretty negative trade off.
alex -
Hi, the fusion between the LCD ans the screen is understandable but FP should offer discount the price for those who send back the broken screen units for refurbishing.
Emmanuel Valette - 回复
I think a 10/10 is warranted because a 9/10 would put it in the same class as many lesser phones.
But being a happy owner I'm potentially bias.
Mattias Pettersson - 回复
Hi people, I am a volunteer in the Repair Café of Deventer and we are very excited about the new Fairphone2 because it showcases what we are working for: Repairable design. We are with over 300 Repair Café's in Holland now and promoting the Fairphone is one of the things I like to do. I cannot wait to receive mine, should be end of this month. So I can take it to Paris on the 12th Decmber for the big Climate March. Super glad and proud with Fiarphone, they deserve 10/10 score all the way!
rodecaban - 回复
Aside from making the phone thinner, fusing the display and digitizer eliminates the issue of dust infiltration (specks of crap under the glass that just can't be cleaned off) which is a warranty/service concern on devices where the two are separate. The combination is also more rigid, providing a subjectively better (firmer) "feel" when the user taps the screen. It's also, all else equal, more resilient against impact or drop damage. From an engineering standpoint, the case can easily be made that these advantages outweigh the potentially increased repair cost, especially since the fused glass is less likely to break to begin with.
gahanj - 回复
need to get me one of these
nev tevi - 回复
Where is the GPS???
Riqz - 回复
Can this be used in the US, and with which carriers?
mgehrking - 回复
Hey iFixit, there is a dead link in step 6 (Fairphone 2 Teardown link in the word 'map'). We changed our site so that is probably the reason. Can you fix it?
Thanks!
@Riqz: The GPS is in the Core module.
@Mgehrking: It can, but you have to research yourself where there is coverage with which carrier. Do realise we do not ship outside Europe (also not for after sales support). https://fairphone.zendesk.com/hc/en-us/a...
Esmée - Fairphone Customer Support
Esmee - 回复
The dead link is now fixed. Thanks for the tip! :)
Jeff Suovanen -
The Philips #1 Screwdriver didn't work that well, I had to use a flat 1.4mm driver to remove the screws. Maybe better to recommend using a #00?
Victor
victorhugolimachi - 回复
Is there going to be a US LTE variant available anytime soon? Me want!
Mike Hayes - 回复
I'm unable to get beyond step #4 - I flipped the blue switches but I can't slide the screen out. Too bad there is no real-life Fairphone community nearer to me than London (I'm in Leamington Spa in Warwickshire). I would so much rather have a hands-on demonstration than attempt to follow a video.
louisaradice - 回复
Hello louisaradice, a teardown is not meant for repairs. You might want to look at the display assembly guide for that. There are also additional comments on step 4 to get the display off. Here you go: Fairphone 2 Display Assembly Replacement
Tobias Isakeit -
I have looked at Fairphone 2 Display Assembly Replacement but I'm still none the wiser. Try as I can, I still can't slide the screen out.
louisaradice - 回复
Louisaradice, Have you looked at Fairphone's screen replacement video guide on YouTube? It's also possible that your clips have somehow jammed? If you are still unable to replace the display I suggest posting a question inn our Answers forum, and take photos of the clips to share with our users. Hopefully we can help you troubleshoot!
Sam Lionheart -
Hello,
my Mother's phone has fallen in the water. How can I diagnose which module(s) have to be replaced?
Francesco Maltoni - 回复
Hello Francesco,
first, make sure it is completly dry. You should have removed the battery immediately after the dive.
you can remove all three modules. Then clean the contacts with alcohol.
Then WITHOUT the modules (just screen and core) try start the phone.
If its boots up replace one module at a time then check again.
For futher help: check the fairphone forum https://forum.fairphone.com/
pa sch -
Hi, Do you know the spec of the antenna, and where I can order another one? Thanks!
Elizabeth Adams - 回复
Mine does also very often NOT connect to a telephone network (either 2G, 3G or 4G), all other phones I tried are much better (at the same location and with the same network provider). Would changing the antenna resolve this (I mean, how likely does such a simple part become defective)?
MWalzer - 回复
添加评论
浏览统计数据:
过去的24小时: 65
过去的7天: 411
过去的30天: 2,145
总计 179,702
