简介
Earlier this month, we tore down a pair of completely glued-together smartphones. This week, we're ready for something designed to be repaired, not just replaced.
Early this year, Asus announced the Chromebook C202—an education-focused Chromebook designed to be inexpensive, rugged, and highly serviceable. That last bit caught our eye, and when Asus offered up a test unit for our examination, we gladly accepted, eager to investigate the claim.
This device is far from the bleeding edge, so we're not expecting advancements in pixel density, computing power, or chassis weight. Instead, we're hoping to find innovations in repairability. Let's crack this open and harvest the fruits of design-for-repairability labor.
Stay at the top of the class by following us on Instagram, Twitter, and Facebook.
这个拆解是不是维修指南。 要维修你的的Asus Chromebook C202,请使用我们的服务手册
Class, please welcome our newest student! Chromebook C202 comes from Asus, and will be joining us for today's lesson. Dual-core, 1.6 GHz Intel Celeron N3060 processor with burst speeds up to 2.48 GHz and integrated Intel HD Graphics 400
  • Class, please welcome our newest student! Chromebook C202 comes from Asus, and will be joining us for today's lesson.
    • Dual-core, 1.6 GHz Intel Celeron N3060 processor with burst speeds up to 2.48 GHz and integrated Intel HD Graphics 400
    • 2 GB and 4 GB RAM configurations
    • 16 GB on-board storage
    • HDMI, SD card, and USB 3.0 connectivity
    • Chrome OS
    • 10-hour battery life
    • Hard candy shell ruggedized wraparound rubber bumper
添加评论
The folks at Asus clearly have confidence in their new Chromebook. They sent us this sample unit for standardized testing, knowing we would immediately tear it apart. For once, a warning label that doesn't threaten to void your warranty the moment you open something. And there was much rejoicing.
  • The folks at Asus clearly have confidence in their new Chromebook. They sent us this sample unit for standardized testing, knowing we would immediately tear it apart.
  • For once, a warning label that doesn't threaten to void your warranty the moment you open something.
    • And there was much rejoicing.
  • We grab our tools and get to work. We have to remove a rubber cover or two, but otherwise it's just standard Phillips screws securing the chassis.
添加评论
With screws dispatched, we move on to the tool of choice. The Plastic Opening Tool. Plastic clips around the edge of the spill-proof upper case secure it into the bathtub of a lower case—and after a bit of prying, we free them all. Let's open things up to see what's in store. Keyboard and trackpad ribbon cables connect the upper case to the motherboard, with plenty of slack to flip the upper case over and safely disconnect the ZIF connectors from the motherboard.
  • With screws dispatched, we move on to the tool of choice. The Plastic Opening Tool.
  • Plastic clips around the edge of the spill-proof upper case secure it into the bathtub of a lower case—and after a bit of prying, we free them all. Let's open things up to see what's in store.
  • Keyboard and trackpad ribbon cables connect the upper case to the motherboard, with plenty of slack to flip the upper case over and safely disconnect the ZIF connectors from the motherboard.
  • The trackpad, a common failure point in laptops, practically flies out, ready for transfer to another class.
添加评论
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Having popped the top off, we get a look at the entire interior. Look at all this modular hardware! The large interconnect cable even has friendly labeled ends: the side labeled IO connects to the Input/Output board, while the side labeled MB connects to Manitoba, Canada. Or maybe the motherboard... The I/O board also hosts the power jack, a common point of failure. It looks like fixing a broken power jack will be as easy as replacing this little board. A+
  • Having popped the top off, we get a look at the entire interior. Look at all this modular hardware!
  • The large interconnect cable even has friendly labeled ends: the side labeled IO connects to the Input/Output board, while the side labeled MB connects to Manitoba, Canada. Or maybe the motherboard...
  • The I/O board also hosts the power jack, a common point of failure. It looks like fixing a broken power jack will be as easy as replacing this little board. A+
  • Upon removing a hefty bracket, we're a bit surprised to find it's actually a heat sink. Shunting heat straight into the battery seems an odd design choice; batteries don't like too much heat.
添加评论
Minor inconveniences suffered, we're able to remove the battery. Still nothing but Phillips #1 screws to slow us down. Nothing proprietary, and no adhesives. This is a 38 Wh lithium ion battery, on-par with the 11" MacBook Air's 38.75 Wh battery.
  • Minor inconveniences suffered, we're able to remove the battery. Still nothing but Phillips #1 screws to slow us down. Nothing proprietary, and no adhesives.
  • This is a 38 Wh lithium ion battery, on-par with the 11" MacBook Air's 38.75 Wh battery.
    • Advertised battery life is also on-par, at 10 hours. We can't help but expect the C202 to do a little better, with its significantly less power-hungry components.
  • Either way, aspiring blasters of math and Oregon pioneers should have plenty of time to hone their craft.
添加评论
While the C202 is very modular, its disassembly is also quite linear. We had to remove the I/O board cable, heat sink, and battery, in that order, to get to the motherboard. Not that we're complaining too much, as the lack of adhesive makes removing and replacing these prerequisite parts a cinch. A last sweep before we leave the lower case reveals the speakers—a connected pair, free once the motherboard is removed.
  • While the C202 is very modular, its disassembly is also quite linear. We had to remove the I/O board cable, heat sink, and battery, in that order, to get to the motherboard.
    • Not that we're complaining too much, as the lack of adhesive makes removing and replacing these prerequisite parts a cinch.
  • A last sweep before we leave the lower case reveals the speakers—a connected pair, free once the motherboard is removed.
添加评论
Don't tell the other kids, but Asus brought chips. Silicon chips, that is: Intel Celeron N3060  14 nm Braswell processor, with Intel HD Graphics 400
  • Don't tell the other kids, but Asus brought chips. Silicon chips, that is:
    • Intel Celeron N3060 14 nm Braswell processor, with Intel HD Graphics 400
    • Samsung SEC 546 K4E8E32—likely LP-DDR3 (four 8-Gb chips for a total of 4 GB RAM)
    • Winbond W25Q64FWSIG and W25X40CLNIG serial flash memory
    • SMSC/Microchip MEC1322-LZY ARM Cortex M4-based keyboard and embedded controller
    • Realtek ALC5650 (likely audio codec)
    • RT5067A GQW 2H60X
    • And on the reverse side: SanDisk SDIN9DW4 16 GB eMMC NAND flash, and Infineon SLB9655TT1.2 Trusted Platform Module
添加评论
Last stop on the hit parade—the display. Don't lose your head, C202, or we'll have to send you to the principal's office. Here we encounter some more of that linear construction—we had to remove the motherboard and I/O board to get the display out. Opening up the display itself is a trivial matter. A couple more Phillips #1 screws behind stuck-on covers and a quick pry reveals the LCD, camera, microphone, antennas and hinges, ready to be plucked out and replaced.
  • Last stop on the hit parade—the display. Don't lose your head, C202, or we'll have to send you to the principal's office.
  • Here we encounter some more of that linear construction—we had to remove the motherboard and I/O board to get the display out.
  • Opening up the display itself is a trivial matter. A couple more Phillips #1 screws behind stuck-on covers and a quick pry reveals the LCD, camera, microphone, antennas and hinges, ready to be plucked out and replaced.
添加评论
Pencils down, please pass your exams forward. Asus Chromebook C202 Repairability Score: 9 out of 10 (10 is easiest to repair). Intuitive, uncomplicated design makes disassembly straightforward and reversible.
  • Pencils down, please pass your exams forward. Asus Chromebook C202 Repairability Score: 9 out of 10 (10 is easiest to repair).
    • Intuitive, uncomplicated design makes disassembly straightforward and reversible.
    • Modular components means many repairs can be carried out by quickly swapping a failed part.
    • Only Phillips #1 and #00 screws are used.
    • No adhesives are used, and all plastic clips are durable enough to easily survive reassembly.
    • Linear disassembly means you might have to remove several components to get to what needs replacing. That said, failure prone parts (battery and ports) are prioritized.
    • RAM and flash storage are soldered to the motherboard and cannot be replaced or upgraded. However, this may not be much of an issue for the C202's target market.
    • Even easy repairs can be difficult without instructions—but thankfully, Asus has published its official disassembly guide on iFixit.
添加评论
And... all laptops should be this serviceable.
Serviceability is one reason I've stuck with Dell Precision Mobile Workstations and recommend them to friends and clients... but it's good to see that there are entry level notebooks that are just as serviceable now. I cannot be the only one tired of seeing self-proclaimed "green" companies like Apple contributing to ewaste by making notebooks/laptops and other gear as unserviceable as possible. I'd rather deal with a little more bulk and heavier bags on flights with a repairable laptop than keep contributing to ewaste.
kimvette - 回复
I changed Step 8: Typo: principle to principal. Sorry!
Edward C - 回复
Thanks Edward C, I 've been looking forward to this tear down. It might be worth mentioning that you can get to the LCD panel straight away, this is an often replaced part in the education market.
Justin Marshall - 回复
"Samsung SEC 546 K4E8E32—likely LP-DDR3 (four 8-Gb chips for a total of 4 GB RAM)"
Wait, so how much ram does it have? 32GB? That seems like a bit much for a chromebook, but I suppose it is chrome, and with enough tabs...
crystalclaw - 回复
Each of the four chips is 8 Gigabits. A Gigabit (Gb) is 1/8th of a Gigabyte (GB), so that's 1 Gigabyte per chip, for 4 GB total.
Andrew Optimus Goldberg -
"(four 8-Gb chips for a total of 4 GB RAM)"
"Wait, so how much ram does it have? 32GB?"
I can't even ... what? You literally just quoted them saying a total of 4 GB. I don't get it. Are you having a seizure? Should I call an ambulance? Not to be rude but ... really man. Get some help.
Fennec Besixdouze -
I think this is unnecessarily harsh as the article could have just stated 4 x 1GB chips when 8Gb = 1GB (notice the lower case b for bit and upper case for byte). Is it not better to educate people than to insult them? What can you expert from a physics nerd though? ;-)
Mike Smith -
mine has 528mb of ram
Wesley Elder - 回复
Asus make this with a better LCD and an msata or m2 SSD and I would buy one. I suppose I could live with the screen or replace it with something better myself. One RAM slot (+ 4GB soldered RAM) would be nice and let me choose the OS I run and don’t limit me to ChromeOS. I think this is how laptops should be, all rubbery! I sound a real perv with that last comment sorry! ;-)
Mike Smith - 回复
添加评论
浏览统计数据:
过去的24小时: 13
过去的7天: 118
过去的30天: 956
总计 19,470
