iFixit Opening Picks set of 6
  • 关闭360°
  • 360°
360
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
Pick your way to repair!
  • 6 very thin opening picks
  • Can be used for prying, sliding, separating, and air guitaring.
  • These picks are especially useful for prying open iPads and other glue-laden devices.
维修的故事
用户头像
Scott Cassio's Story Photo #885867
我的问题
Cracked front panel assembly
我的修理方法
The repair is pretty straight forward until the conclusion which states, 'But first ensure to place a narrow piece of tape over the copper/silver at the bottom of the digitizer to the left and right of the home button.'
Since there was no tape in those areas when I took . . .
用户头像
我的问题
Spider web screen
我的修理方法
Repair went very well instructions were plain enough was a little nervous of crushing a connector after the first one was in it was smooth sailing about an hour to do
我的建议
Go slow take your time and follow instrutions
用户头像
我的问题
Accidentally dropped my phone right on the back.
我的修理方法
With a heat gun on low the glue softened up very easily. Needed something sharper and thinner to get under the glass but once I did it peeled off easily. Removed all the old glue with a knife to hopefully retail some water resistance.
我的建议
Use the heatgun . . .
用户头像
我的问题
Screen was badly cracked after bing dropped on corner of iPad.
我的修理方法
Repair went smoothly. No major issues but needed another tool to make it really work.
我的建议
Need to stay patient as it's tedious work getting the screen off. After that it's pretty easy. The plastic tool to pry open the screen from the edge isn' . . .
用户头像
我的问题
My wife's phone. She cracked her LCD screen
我的修理方法
The "Ifixit" video manual was to the point and quite accurate except a couple of things. On this particular phone the original adhesive refused to let go after heating the chassis several times. The iSclack was not strong enough to lift the rear cover loos . . .
用户头像
我的问题
My power switch was stuck. I bought a spare part off eBay.
我的修理方法
You guys rated the fixability a "1" and I completely agree. What a pain. I was able to get the switch replaced and the unit works except that when I was using the picks I pushed one in too far and it broke the digitizer membrane on the top-le . . .
用户头像
我的问题
Cracked Screen
我的修理方法
Great!
我的建议
Becareful where you order your screens. I had to do this twice!!
用户头像
我的问题
Kindle would not charge unless you did the wire dance ( moved it all over) until you find the spot that if you're lucky will charge after you sit it down . Got to the point that I had to do it without moving the Kindle.
我的修理方法
Very well, you just have to pay attention to details.
我的建议
Have a clean surface and all . . .
用户头像
我的问题
iPad 4th Gen WiFi with a broken front glass.
我的修理方法
The instructions were great except that for some reason, they assumed that I would be replacing an intact glass panel. Mine was broken in 4 lines, and every time I got to another break, it would shatter down to powdered glass and glue (Yes I know it is 3M . . .
用户头像
我的问题
Screen was cracked, after replacing screen I found there was more wrong with the Samsung Core phone.
我的修理方法
Screen replacement went well
我的建议
Include instructions for the specific phone
显示更多
