P2 Pentalobe Screwdriver iPhone
$8.99
$8.99
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
维修的故事
用户头像
我的问题
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
我的修理方法
Super simple! Make sure that you have that pentalobe (?) screw driver.
我的建议
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
用户头像
我的问题
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
我的修理方法
Very well.
我的建议
NA
用户头像
我的问题
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
我的修理方法
Perfectly
我的建议
Saw a video on you tube
用户头像
我的问题
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
我的修理方法
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
我的建议
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
用户头像
我的问题
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
我的修理方法
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
用户头像
我的问题
I water damaged my 6s.
我的修理方法
It went great!
我的建议
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
用户头像
我的问题
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
我的修理方法
Took less than a minute, super super easy
我的建议
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
用户头像
我的问题
screen cracked
我的修理方法
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
用户头像
我的问题
Cracked display
我的修理方法
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
我的建议
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
用户头像
我的问题
I have a FIIO X5s High Def music player and the back had been pulled open by the magnetic stand that I was using to hold it to my cars dash. It has 2 small screws that hold the back plate in place. The screw drive that I received wass perfect for the job. I was able to replace the back plate and sec . . .
显示更多
