Mac Mini Logic Board Removal Tool
  • 关闭360°
  • 360°
360
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
The least originally named tool we offer.
  • Simple tool pries the logic board free to allow access to the hard drive in 2010-up Mac Minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
维修的故事
用户头像
我的问题
Upgrade to SSD
我的修理方法
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
我的建议
Note in the guide to reformat the SSD before installing into the Mac mini
用户头像
我的问题
replaced HDD with SSD
我的修理方法
did not need tool to remove logic board but screen did not fit back could not use one screw
我的建议
take risks but use good tools
用户头像
我的问题
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
我的修理方法
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
用户头像
我的问题
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
我的修理方法
"Repair" its . . .
用户头像
我的问题
My original 500GB hard drive was very SLOW .
我的修理方法
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
我的建议
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
用户头像
我的问题
The hard drive was to slow - change it to a SSD
我的修理方法
Followed the repair guid for harddisk installation, and the guide was really helpful.
我的建议
Take your time and read the guid carefully. If you do, you will not go wrong
用户头像
我的问题
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
我的修理方法
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
用户头像
我的问题
Slow mechanical hard drive - upgrade to SSD.
我的修理方法
Went smoothly.
我的建议
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
用户头像
我的问题
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
我的修理方法
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
用户头像
我的问题
I thought I could live with a slow spinning drive - I couldn't...
我的修理方法
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
显示更多
