Heavy-Duty Suction Cups (Pair)
  • 关闭360°
  • 360°
360
$14.99
$14.99
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
Large glass panels rarely come with handles. Use these suction cups to safely lift and remove glass and display assemblies from devices.
We specifically built these suction cups for iMac repair. For years we struggled with finding a reliable source for quality suction cups, so we bit the bullet and engineered our own. The specially formulated rubber foot sticks stronger and longer.
Includes two 2.25" diameter suction cups used for lifting display glass off Aluminum iMacs—or anything else that needs heavy duty lifting. A must-have for any iMac repair.
维修的故事
用户头像
David Robledo's Story Photo #1303672
David Robledo's Story Photo #1303671
我的问题
I had the iMac 2011 grey screen, to blank screen, to crazy demonic rainbow screen.
我的修理方法
Ordered the Pro-Tech Toolkit a Magnetic Project Mat and the suction cups. Figured it would be cheaper to try to open and check for damaged cables or power assembly. I’ve never done anything THIS involved. Reluctantl . . .
用户头像
Brent Lewis's Story Photo #1317153
我的问题
Hard drive in an iMac 21.5" was failing so needed to replace the hard drive for continued use of the machine.
我的修理方法
It was smooth for most part outside of a couple of annoyances (detailed in the "Enlightenment section). Had it not been for the lack of connector puller/long fingernails and magnets near the . . .
用户头像
我的问题
I could only charge wirelessly
我的修理方法
I missed 2 screws and shattered the digitizer
我的建议
Remove the seal and count the screws.
用户头像
我的问题
We had a mid-2011 27" iMac that had never been used much.... sometimes bigger isn't always easier to use! Moving some furniture allowed us to consider using it again but it wouldn't start up, no lights, no sounds, just dead. Rather than recycling a barely used machine we decided to risk spending t . . .
用户头像
我的问题
Original power supply was dead.
我的修理方法
About an hour.
我的建议
Wow, this replacement was awesome. I've been working with electronic equipment for 30 years and this was one of the smoothest replacements I've ever done. The part from Ifixit was beautifully packed and the part appeared to be OEM. Thankfully the Mac i . . .
用户头像
我的问题
Original battery was not holding a charge.
我的修理方法
Excellent, downloaded a calibration APP to try to help the charging scenario.
我的建议
Ifix is awesome!
用户头像
我的问题
I have two five year old thunderbolt displays, One with no video and one with broken glass. I determined that the one with no display had a bad built in cable by plugging a thunderbolt cable into port on the back. When I found the teardown guide, I looke like a straighforward procedure. To test the . . .
用户头像
我的问题
The machine would not boot and had burning smell coming from exhaust. Had to open it to troubleshoot.
我的修理方法
The repair did not happen because the mainboard had two or more burnt capacitors.
我的建议
Take your time and follow the repair guide exactly.
用户头像
我的问题
All in one cable went on HD Cinema Display
我的修理方法
The suction cup tools made it so easy to pull the glass off the screen. Should have done this ages ago...
我的建议
Use the right tools for the job...
用户头像
我的问题
Battery not holding a charge
我的修理方法
Smoothly for my first battery replacement
我的建议
Top of screen should be fitted in lower portion FIRST
显示更多
