Heat Gun
Heat Gun
Heat guns may produce residual smoke when turned off the first few times and should always be used in a well-ventilated area.
$19.99
$19.99
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
Great for reflowing solder and melting adhesive.
  • The power of fire in the palm of your hand (except for the part where flames actually come out).
  • 1500W Heat Gun needed for many different repair processes.
  • Can be used to loosen adhesive holding device components in place, or to reflow solder to repair soldered connections.
High and Low Heat settings
  • Low setting reaches 570/300 degrees F/C.
  • High setting reaches 1112/600 degrees F/C.
The high setting can ignite things. It can also burn you. So watch out!
For the professional heat gunslinger, check out our pro model, the Hakko HJ5000.
维修的故事
用户头像
Steven Rice's Story Photo #815542
Steven Rice's Story Photo #815544
我的问题
My friend dropped her phone in a parking lot.
我的修理方法
I do NOT like how this phone was constructed. I was actually maimed in the process of repairing this thing. It uses these tiny little pins to hold a metal frame onto the screen assembly. It is a horrible design. I ended up getting one of those stupid litt . . .
用户头像
我的问题
Charging was intermittent and battery runs out fast - now all good with the replacement parts.
我的修理方法
Doing both of these at the same time is a good idea. Good parts, good repair.
我的建议
I grabbed a BIG local business advertisement magnet from my fridge and used that up side down for all of the screws and parts. . . .
用户头像
我的问题
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
我的修理方法
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip v . . .
用户头像
我的问题
My Galaxy Mega 2 had a shattered screen.
我的修理方法
The repair is pretty easy as long as you take your time removing the glass. It's just held together with tape so just heat it up a little around the edges and use a pick or another small tool and run it along the sides and off she comes.
我的建议
Take your time and he . . .
用户头像
我的问题
RROD
我的修理方法
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
我的建议
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in t . . .
用户头像
我的问题
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
我的修理方法
Repairs go a lot quicker with the right tools.
我的建议
Make sure you have the ri . . .
用户头像
我的问题
I fixed it because it ha front and back screen broken.
我的修理方法
The repair went great it's fixed.
我的建议
None i did it on my own.
用户头像
我的问题
The screen shows only snow.
我的修理方法
The iFixIt repair components worked fantastically! I was able to use the heat gun to melt the adhesive holding the touch pad digitizer to the iPad frame. i used: the set of picks to help separate the digitizer from the frame without damaging the plastic ring around the c . . .
用户头像
我的问题
Screen is cracked.
我的修理方法
Haven't do the repair yet.
我的建议
Don't drop your laptop.
用户头像
我的问题
Replacing the broken glass on my samsung galaxy s4. I used the heat gun and believe I put it too close to the screen. Thus, discoloring the screen and forcing me to buy a $100 new screen/digitizer/lcd.
我的修理方法
Using the heat gun for the recommended time, I still managed to discolor my phone screen because t . . .
显示更多
