64 Bit Driver Kit
  • 关闭360°
  • 360°
360
64 Bit Driver Kit
$24.99
$24.99
当产品有货时,我们将给你发送消息。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
The ultimate high-performance bit kit
  • The complete screw-turning solution for precision repair jobs.
  • Custom handle with two-zone grip profile provides up to 8.5 N-m of torque.
    • Textured precision zone for delicate screw turning
    • Three-faceted, large-diameter grip zone for heavy duty wrenching.
  • 64 purpose-driven screwdriver bits selected based on the data from thousands of repair guides.
  • This bit kit contains bits to repair cell phones, game consoles, wearables, laptops, desktops, tablets, small appliances, and much more!
  • The specially-designed case conveniently holds and displays all the contents in high-density foam.
  • The lid of the case features an integrated sorting tray.
  • Ergonomic Aluminum Handle provides plenty of torque and grip with swivel cap and magnetized bit holder.
  • Longer bit necks for increased precision and accessibility.
Interested in purchasing more than 10? Contact Us!
Kit Includes
  • 64 Bit Driver
  • 150 mm Flex Extension
  • 4 mm Screwdriver Bits
    • Phillips - 000, 00, 0, 1, 2
    • Flathead - 1, 1.5, 2, 2.5, 3, 4 mm
    • Torx - T2, T3, T4, T5
    • Torx Security - TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25
    • Pentalobe - P2, P5, P6
    • JIS - J000, J00, J0, J1
    • Hex - 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut Driver - 2.5, 3, 3.5, 4, 5, 5.5 mm
    • Square - 1, 2
    • Gamebit - 3.8, 4.5 mm
    • Spanner - 6, 8
    • Triangle - 2, 3 mm
    • iPhone Standoff Bit
    • Oval Drive
    • SIM Eject Bit
    • Magnetic Pickup Bit
    • 1/4" to 4 mm Driver Adapter
产品视频
维修的故事
用户头像
Alex Anfrie's Story Photo #1268915
我的问题
My phone fell off my car and ended up with a broken screen
我的修理方法
The repair went well, i struggled a bit trying to figure out all the parts (cameras, speaker, etc) that needed to be taken off the old screen to the new one
我的建议
Don't forget the parts on the old screen that needs to be placed on the new one:
Jack . . .
用户头像
我的问题
Needed to destroy storage on old phone before it's sent to recycling
我的修理方法
The "Repair" as it is hasn't happened yet because when you open up the Moto G, everything is covered in metal panels. I wanted to drill into whatever was the storage area before sending the phone off to recycling so that nefarious p . . .
用户头像
我的问题
The factory battery began to expand and was causing problems.
我的修理方法
Very easy and simple. Just needed the right screw driver bit.
我的建议
Nope.
用户头像
我的问题
My Gamecube C-Stick was drifting in games.
我的修理方法
Will be quick
我的建议
With the proper driver I could unscrew the triangle screws holding together controller. I noticed that a new C-stick is needed. Now all I need to do is replace the C-stick with a similar stock item.
用户头像
我的问题
This is what we do..
我的修理方法
as it should
我的建议
Never give up.
用户头像
我的问题
After we moved into our new house, our PS3 would overheat within seconds of powering it on.
我的修理方法
After following the steps for the full teardown, I was able to see that the thermal paste needed to be replaced in two spots. After carefully removing the old paste and replacing, it powered on and worked like . . .
用户头像
我的问题
I had to remove a large heatsink from my CPU to replace the CPU, hwoever Hyper 212 evos arte notorious for being less than steller with their X bracket mount despite otherwise being an awsome cooler. So I purchased the 64 peice driver set and it worked amazingly. Arrived a day later than expected bu . . .
用户头像
我的问题
I broke my iphone 5s screen and decided to buy the 64 bit repair kit, a suction cup, and bought a cheap replacement screen from another source.
我的修理方法
In the beginning it actually went quite well. I removed the screen, removed the screws, the covers, and removed the screen wires. the transferring of compone . . .
用户头像
我的问题
My mouse was clicking by itself and going nuts.
我的修理方法
Very detailed and simple. Fluid, smooth guide and the tools came so quick! and handy! THOROUGHLY IMPRESSED!
我的建议
Be patient, and be gentle. ANYONE CAN DO IT!
用户头像
我的问题
My CPAP machine broke down and a new unit just wasn’t in my budget. But you know what was? The 64bit kit.
我的修理方法
After watch a video from YouTube, I saw that the tools needed were in a kit offered from iFixIt. And in the past I’ve bought kits for the iPhone 4s and iPhone 6 and I knew that they provided . . .
显示更多
