54 Bit Driver Kit
54 Bit Driver Kit
非卖品
非卖品
非卖品
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
产品详细说明
功能
功能
This product has been discontinued and replaced with our 64 Bit Driver Kit
  • The comprehensive standard in precision screwdriver bit sets, features 54 carefully selected bits—chosen with data collected from our thousands of free repair guides.
  • This kit forms the base of our popular Classic Pro Tech Toolkit , the industry standard for computer repair technicians and businesses.
If you're looking for replacement or legacy bits, or you just want larger and even more rare bits, be sure to also take a look at iFixit's newest bit kit and 4mm Screwdriver Bits.
Kit Contents:
  • 4 mm Aluminum Driver - featuring a magnetic socket, rubber grips, and a ball-bearing swivel top
  • Flexible Shaft Extension - snake into hard to reach places
  • 60 mm Shaft Extension - doubles as a T-handle for extra torque
  • 1/4" Adapter - use this kit's 4 mm bits in standard 1/4" drivers
  • 54 bits in the following sizes:
    • Pentalobe sizes 2, 5, 6 (iPhone, MacBook Air, MacBook Pro)
    • Flathead sizes 1, 1.5, 2, 2.5, 3, 3.5, 4 mm
    • Phillips sizes #000, #00, #0, #1, #2
    • JIS sizes 000, 00, 0, 1
    • Torx sizes T3, T4, T5, T6
    • Torx Security TR7, TR8, TR9, TR10, TR15, TR20 (compatible with non-security)
    • Hex sizes 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5, 6 mm
    • Square sizes #0, #1, #2
    • Triangle size 3 mm
    • Tri-point sizes #0, #1
    • Nut Driver sizes 2.5, 3, 3.5, 4, 5 mm
    • SIM Eject size 0.8 mm
    • Magnetic Pickup size 4 mm
维修的故事
用户头像
luisarodriguez's Story Photo #763935
我的问题
Need tools that could be used to repair anything. I fix it because now a days it's possible.
我的修理方法
I like working on electronics, G scale model trains, or anything that breaks. Most of my repairs are tiny complicated pieces that require specialized tools. ifixit tools make the job much easier to take apar . . .
用户头像
我的问题
After 5 years battery kept showing up as 'service battery'
我的修理方法
Following this guide was very straight forward and simple!
我的建议
Take your time. Its easy but follow the steps. Take your time picking up the screws so you dont drop them etc. great guide, thanks!
用户头像
我的问题
I have several sets of jewelers screwdrivers and none of them could get get the job done. Yours did the trick.
我的修理方法
Fast and easy.
我的建议
Good set to have.
用户头像
我的问题
The disc drive in both my 1st gen reverse compatible PlayStation 3 and my wii were not accepting game or movie discs. There was a rattle in the disc compartment in both. Come to find out my copious amount of children decided to stuff the systems with paper clips, safety pins and coins. Thanks to . . .
用户头像
我的问题
Needed to replace the hard drive in an iMac 24"
我的修理方法
It went well. Very impressed with the written and video instructions to open the unit up and replace the hard drive.
我的建议
Use the videos!
用户头像
我的问题
The trackpad was not clicking
我的修理方法
The repair was a complete failure. I was able to get the trackpad out without any issues. I cleaned the edges of the trackpad with a toothbrush and adjusted the screw. I replaced the trackpad, and reinserted the trackpad data cable. I then inserted the keyboard ribbon c . . .
用户头像
我的问题
I noticed a while back that the MagSafe connector was getting really hot, hot enough that it fried the two outermost terminals in the DC-In Board's port. I could only charge it when it was off or sleeping - the MagSafe connector would overheat any time I used the computer while charging. I took it . . .
用户头像
我的问题
Dead iMac battery! I inherited an iMac with still plenty of life in it, but a failing battery.
我的修理方法
Super easy! Took me 5 minutes to replace with the right tool! Thanks for the great toolkit! :)
我的建议
There are two different size screws on the iMac body -- it helps to keep track of which go where. I also used th . . .
用户头像
我的问题
It was not a fix, but more a need. I recently purchance a nice spyderco ukpk knife and wanted to switch the scales on it for a custom set. So I needed a small torx bit set to desasemble it. And I was all ready eyeballing this kit for a long time. So this was the perfect time to buy this super nice . . .
用户头像
我的问题
my mom has been wanting to upgrade her aspire 5100 memory ram cause its so freakin slow! it has only, 1gb of ram, she thought of buying a new laptop but i prefer buying a new memory ram, so i bought your tools.
我的修理方法
it was an easy repair job, but it took me longer to close it because it has 9 clips (idk w . . .
显示更多
