MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
$44.99
$44.99
当产品有货时,我们将给你发送消息。
换块电池,让 iPhone「满血复活」
维修工具包价格在 $16.99
产品详细说明
功能
功能
Unable to access your hard drive?
Then you might need to replace your hard drive cable!
Please read the option descriptions. Some options do not include the hard drive bracket.
兼容性
维修的故事
用户头像
我的问题
Hard drive would not boot while connected to the internal SATA cable but would boot correctly when placed into an external USB carrier.
我的修理方法
The repair process was very easy. Remove the laptop bottom cover, unscrew and remove the hard drive hold down brackets, unplug the hard drive from the SATA cable the . . .
用户头像
我的问题
A client gave me a mid-2012 MacBook Pro for recycling after he'd replaced it. The computer rarely would boot at all. It wasn't the hard drive.
I kept the computer around, loathe to recycle something that seemed close to working.
I had bought the new part to see if it improved another client's comp . . .
用户头像
我的问题
My old SATA cable wasn't able to transfer files as fast as my new SSD's disk speeds (1/5th the speed)
我的修理方法
Works great! My new SSD works find because of the new cable.
我的建议
Buying a new SSD? Buy this cable. (Get the one with the bracket. It helps.)
用户头像
我的问题
MacBook cable was damaged.
我的修理方法
It was easy to replace and so far it works well.
我的建议
If your Apple warranty is expired, try to repair this yourself rather than taking your MacBook to Apple.
用户头像
我的问题
MacBook Pro worked fine with stock hard disk but refused to boot with SSD in place. Even erasing SSD was finicky and produced partitioning errors I'd never before seen.
我的修理方法
Easy! In troubleshooting, I happened to have another client's same-model Mac on hand to briefly swap in their storage data cable and . . .
用户头像
我的问题
Hard drive cable - MacBook pro was running loops with bad contact to harddisk. I checked this by reinstalling Lion OS X externally on a hard drive. This worked so my assumption that the cable was faulty proved itself.
我的修理方法
I tried a cheap cable from amazon but people i tell you what a waste of time and m . . .
用户头像
我的问题
I replaced cable hard drive and memory. Speed was horribly slow and this cable has a history of failing (my school district replaced the cable in about 1,000 laptops). In addition, to the cable, SSD and additional memory, it is like a new machine!
It was easy with the videos at Other Wold Computin . . .
用户头像
我的问题
The hard drive cable failure is a known issue for the MacBook Pro 13" Unibody Mid 2012. I have replaced this cable in two Mid 2012 MBPs for friends. This is the second time the cable failed in one of those two computers. However, the failed cable was NOT purchased from iFixIt. Hoping that the iFixIt . . .
用户头像
我的问题
It didnt work
我的修理方法
It worked
我的建议
DO it
用户头像
我的问题
I was having more and more hard drive problems until finally I couldn't boot. I bought a new SSD (which I was planning to do anyway), but reinstalling OSX over Wifi kept failing at the reboot. After many hours searching online, I finally found someone with the same problem as me here on iFixit.
我的修理方法
It wa . . .
显示更多
