简介
This guide will teach you how to access, remove, and replace your iRobot Roomba 870 battery.
配件
无需配件。
To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down. Then find the battery pack cover   that is located in the space between the caster wheel, side brush, and vacuum.
  • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
  • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
  • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
添加评论
Remove the loose battery cover to access the battery compartment. Use the yellow tabs, located on the short ends of the  battery pack, to gently pull the battery up and out of its slot. Use the yellow tabs, located on the short ends of the  battery pack, to gently pull the battery up and out of its slot.
  • Remove the loose battery cover to access the battery compartment.
  • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
添加评论
结论
Follow the steps in reverse order for reassembly.
另外一个人完成了本指南。
Vitek Harvey
于2017年04月26日注册
125 信誉积分
创作了2篇指南
团队
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S14G3
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 7
过去的30天: 77
总计 618
