简介
使用本指南可以对任何 iPhone 的晚期机型进行电池胶更换。不管什么时候取下电池,都需要对电池胶胶条进行更换。电池胶是很容易损坏的,如果你是第一次使用本指南对电池胶进行更换,请多准备一些胶条备用。
凡是 Plus 版本的 iPhone 需要使用 3 条胶条而不是 2 条,但方法是一样的。
在开始之前,请确保你使用了以下链接中的指南移除了你的手机电池:(备注:iPhone5 及以前的机型是没有电池胶的)
  • 视频地址:
https://www.youtube.com/watch?v=Xthi6DOx...
请取下胶条底部的小塑料贴片(如果有)。
  • 请取下胶条底部的小塑料贴片(如果有)。
It’s 2018 but still providing this same type of horrible adhesive strips that won’t let go of the blue backing like Jerad mentioned.
Guess I don’t have your skills guys and haven’t tried the one in the picture above but this really isn’t working and I don’t think changing the instructions will help removing the blue backing. I achieved nothing with mine… The rest is perfect.
Jou - 回复
I just had the same experience. The blue backing would not separate from the adhesive.
I tried a new tactic: Remove the ping backing and apply to the case, and then remove the blue backing. No go. It stuck to the blue backing more than it did to the case.
I should have just left the remains of the old strips in place. Instead, I just installed the battery without the adhesive. I hope that’s good enough.
bester - 回复
Effectivement j’ai connu la même expérience, le support bleu n’a pas voulu s’en détacher j’ai donc mis un adhésif double face sur deux petit points afin de maintenir la batterie et évite qu’elle bouge. C’est une étape qui m’a bien pourri le cession d’en remplacement de la batterie de l’iphone 5S. Je pensais avoir des difficultés sur autre chose mais certainement pas sur des adhésifs de m……e!
bekman - 回复
I had the exact same problem, the adhesive wouldn’t release from the blue backing. I spent more time trying to get the adhesive off than rest of the steps combined. I ended up utilizing 3M double sided tape, which worked fine. There is obviously a problem with the adhesive and IFIXIT should correct the issue.
Dan Russow - 回复
I’m in the same boat. Why iFixit uses this blue film the adhesive tends to stick to is beyond me. It’s impossible to remove, I tried the various techniques like highlighted above to no avail.
Florent Pillet - 回复
To reiterate Kadan’s comments further down: If you run into issues with your adhesive strips not coming off the backing properly, or accidentally getting ruined in the process, please reach out to the Support team via help.ifixit.com. There are far too many guides to monitor to proactively seek customers who are encountering issues, so it’s best that you reach out to us so that we can assist you in a quick fashion. Thanks again for your comments, and we look forward to helping! —I think it comes down to a few defective strips getting into the supply chain and unfortunately there’s no way to test them before we ship them out. It’s a very small number as most customers are not having this issue, but I realize that’s not much consolation if you’re one of the few. Reach out to us and we’ll get it sorted, with apologies for the trouble. In the meantime, a little double-sided tape should hold onto your battery just fine until the replacement strips arrive.
Jeff Suovanen - 回复
I think that there is a better way to align the strips. I suggest NOT removing ANY of the protective film(s) from the adhesives at first. First, lay the strips on the side of the battery that will adhere to the case, WITH THE PROTECTIVE STRIPS STILL ON. Make sure the right side of the strips is facing the battery, and move the strips around until they are correctly aligned right to left and up to down, and until the little tabs that go around the other side of the battery are the right length. At this point, use clear tape to hold the strips in place on the battery. NOW, once the strips are aligned, remove the small protective plastic strips as described in Step 1, and adhere them to the battery. Then, remove the clear tape you put on the strips to hold them in place on the battery, and continue with the tutorial. If I remove the small protective plastic strips first and try to put the small tabs on one side so that the long strips are aligned on the other side, I just can’t get it right.
Tom - 回复
将电池正面朝上(电池排线在右边),使胶条已经露出胶的一小部分和电池底部对齐并轻轻按压使胶条紧贴在在电池上。
  • 将电池正面朝上(电池排线在右边),使胶条已经露出胶的一小部分和电池底部对齐并轻轻按压使胶条紧贴在在电池上。
    • 小心的将电池胶条一次性贴在电池上。一旦贴在电池上,胶条便无法取下并且不能再用,您将需要使用新的胶条了。
I found it easy to align the exposed portion by putting the strips on a flat surface and lowering the lower edge of the battery onto the strips. Therefore I could see that the battery was adhering the correct portion.
tdroz - 回复
I agree it was easier to lay the strips on a flat surface in order to align the battery and the strips properly.
rustyherrington - 回复
I used the edge of a desk as an alignment guide. I would *not* eyeball this alignment, unless you don't mind wasting your first pair of adhesive strips.
Jeff Clayton - 回复
Same issue, blue film will NOT separate from the adhesive! Bad adhesive batch?
theamzngq - 回复
hoorible adhesive couldn’t find the form to separate them!
joan -
Before adding the adhesive strip, I found it necessary to compare the shapes of the flat cable of the new battery vs the old battery. The shape of the flat cables were very different so I gently shaped the flat cable of the new battery to match the old battery. When the new battery is installed, the connector will be in correct position.
kilaueakilimanjaro - 回复
I knew this was all too good to be true. Just like the above commenter, the blue film would not separate from the adhesive strips. Now this was all a waste of time and money because there is no way to salvage the strips. Thanks.
Derek - 回复
Same issue with the blue film - there was no way the adhesive strip would separate from the blue film. Maybe tech support should QC the latest batch of adhesive strips?
gutm - 回复
Same as above. NOTHING is going easy about this. simplest step is a botch! Blue strip WILL NOT COME OFF. GARBAGE. total garbage
zoe zane - 回复
Had the same issue with the blue adhesive not coming off. I contacted iFixit support. They sent me new strips for free, but it took about 5 days total. Unless you like being without a phone for a week, I highly recommend checking the blue adhesive on the strips in your kit before you attempt a repair. It should peel off effortlessly.
Edgar Diaz - 回复
Why on earth do the adhesive strips not come with the battery? They should automatically ship with the battery - this is a ridiculous solution for stabilizing a battery. Very disappointed to find out about the strips only after I’ve taken part the phone. Everything about this is absurd!
Steve Esser - 回复
The battery I received in my kit 6/2018 came with a stiff clear plastic sleeve over the battery. The edges of the sleeve were perforated so it could bend squarely at the battery edges, and was a tight fight. It was also fitted with an opening around the battery connector cable. It LOOKED removable - but was securely overlapped and glued to itself. No such plastic sleeve is shown in the instructions or video, leaving the impression this clear plastic cover should be removed before install - BUT the sleeve isn’t mentioned or shown in any of the instructions. It is also made of fairly thick plastic (about guitar pick thickness), so I was a bit concerned leaving it on might create pressure on the back side of the display. However, the sleeve was so well-fitted I finally decided it was probably meant to remain on the battery permanently, so I left it on. The new battery works fine, but still not sure whether I should have removed that clear plastic sleeve. How about an update on this?
w5kp - 回复
The battery should look exactly like the original (apart from the labeling, which may be slightly different). Any protective sleeves or films should always be removed before installation.
Jeff Suovanen -
  • 将电池正面朝下放在平整的表面上
  • 从胶条尖端部撕下蓝色的塑料贴纸。
  • 有的蓝色塑料贴纸有缺陷,无法撕下来,所以需要更换新的胶条。
  • 如果您在iFixit购买的胶条有以上缺陷,请联系我们,我们会返还给您双倍的胶条以替换。
  • 在更换胶条的期间,您可以暂时使用一点双面胶来固定您的电池以便重新组装您的iPhone。
First time I tried this - it was near impossible to remove the plastic cover from the adhesive strip without damaging (i.e. - stretching the adhesive strip) - effectively, the adhesive strip was ruined, and I'll have to order another hoping better luck the 2nd time
Jean-Paul Eberle - 回复
The blue film would NOT remove from my strips. It was permanently adhered to the strips. I now wonder if the manufacturer messed up and put the blue film on upside down.
kwschnautz - 回复
Same problem with the blue film not removing. I used a thin command strip instead of ordering a new set - hopefully that doesn’t interfere with the heat dissipation :(
James -
I agree with ++kwschnautz++. It took me about 30 minutes of painstaking scraping to get the backing off.
martin chisholm - 回复
Same problem, I couldn’t get the strips off the blue backing film. Manufacturing fault? Have ordered some more but will now be without phone for the next couple of days.
David Simpson - 回复
I had exactly the same thing happen: The blue strip is firmly attached to the adhesive strip. It will not come off. The pink side came off just fine. I want to order more, but if they all have the same problem, what do I do? Now my daughter’s iPhone 5c will be in pieces until I get one that works!
Engel Sanchez - 回复
Yah me too. I was totally unable to remove the blue strip.
By closely inspecting the blue strip I noticed, that its both sides feel differently (as Robert Watkins noted also). One side felt smooth and a bit oily and the other was dry and a little bit ruff.
The ruff side was attached to the strips an I have the feeling it should have been the other way around.
I am a litte bit frustrated now, since my phone is now bricked even though I did nothing wrong and I couldn’t have anticipated this, before I started. And it’s a sunday so it will be some time until I can get my hands on some new strips.
Bernhard Schmidt-Hackenberg - 回复
I can’t speak to the problem with the strips, but it’s perfectly fine to use a little double-sided tape on the back of the battery to temporarily secure it while you wait for a replacement strip. Just make sure it’s not jiggling around, then close your phone up and use it normally. I probably wouldn’t recommend doing this long-term, but it should be fine for a few days.
Jeff Suovanen -
I am running into the same problems as others have described above. The pink strip pulls free from the adhesive without issue but the blue strip is seemingly permanently adhered. The strips came from the battery kit for the 5C and I have two kits exhibiting the same problem. Another clue: in following the video above, in order to maintain the orientation of the hole in the tag (toward the cable side), the pink strip must be removed first, then the blue strip as the final step. I think there is a manufacturing issue here! Worse still, it is my wife’s phone that is taken apart now!!
Larry Fahnoe - 回复
I’m having the same issue of the adhesive sticking to the backing. I’m hesitant to order replacements unless I have a sense that the replacement strips are manufactured correctly.
Len - 回复
I did not have the problem of the blue strip not coming off on my 6S, but I did have the problem of that strip springing back onto the adhesive. Only the pointy ends were ruined, so I just cut as much as I could of the ruined chunks off once the adhesive strips were on. A little chunk of blue strip will live inside my phone forever.
Alexander Hughes - 回复
OK - so I had some of the above issue with my first iPhone 6. Blue film did peel off easily, but the “snap back” at the end of the peel caused trouble with the film getting in the strips! When I did the second iPhone, I was ready for it. I had done several “dry fits” of the battery and the strips to prepare my mind for the task. I checked the initial alignment, position of the strips on the front (with the pink film still on, and running perfectly straight and aligned with the battery edges before the flip, and finally to the lower end of the battery to see that the strips do not reach the entire length of the battery. (And, I was ready for the “flip!) On this phone, I performed the strip install exactly as shown in the video, and all went as described. Also, be sure to hold the battery firmly before the drop-in - no second chances! Practice really helped me get it right this time. Oh yeah, and this time I had a “back-up” set of strips, and did not have to use them. YES!
Bill Groth - 回复
Hi everyone!
If you run into issues with your adhesive strips not coming off the backing properly, or accidentally getting ruined in the process, or removal, please reach out to our Support team via '''help.ifixit.com'''. There are far too many guides to monitor to proactively seek customers who are encountering issues, so it’s best that you reach out to us so that we can assist you in a quick fashion.
Kadan Sharpe - 回复
These are faulty or the QC is napping. There is no way to get the blue side unstuck from the adhesive strip. I even tried heating it. What happened ifixit? Every part I’ve bought in the past worked fine. I kinda need my phone ….so i’ll put it back together with double stick tape and hope for the best. .
will - 回复
Wow, reading the comments I was really worried about this step. But I must have gotten a good batch, because the blue backing came right off and this step was no problem at all.
Joe Teichert - 回复
  • 用手指轻轻的将胶条从电池的下部边缘开始,向后捋平。
    • 当按压胶条时不要拉伸或者卷起胶条的其他部分。
添加评论
  • 将胶条平整的贴在电池背部。
添加评论
  • 用手指或者软布轻轻地把胶条沿着电池背面按压到位。
STOP HERE!
Before you take the plastic off the adhesive, take a look at your previous battery.
See how the connector on it is bent? The connector on the new battery will also need to be bent this way before it will successfully connect to your iPhone, while still leaving enough clearance for the case to close.
I would highly recommend that you take some pliers, and carefully bend the connector to look like the previous one.
It’s much easier to bend this connector before you’ve taken the adhesive off, or (like I did) put the battery in the phone already.
This is tricky, and take special care not to grab the battery plug itself, or you might damage the connector.
Michael Gruben-Trejo - 回复
  • 将胶条剩下的保护膜撕去,完整露出贴合面。
Be careful you don’t do what I did on attempt no.1 and let the side of the plastic that will stick to the adhesive catch on it.
James Meek (Jamz) - 回复
Same happened to me, couldnt peel off the adhesive from the remaining piece of film. What a waste.
Maksim Luzik - 回复
This unlucky didn’t work out for me. Strips didn’t stick to the battery so I needed a quick fix and used TESA double-sided adhesive strip. Worked well and sticked very well. BUT the thickness of the tape compared to the iFixit adhesive strips is maybe 6:1, so I have slight problems with the display, but as a quick fix it works. Ordert new strips and hope I will get it done next time.
Stefan Hinterberger - 回复
  • 先不要将电池粘在手机上,将电池连接插头放入iPhone中,并将其对准主板上的插座。
    • 连接电池
Leave an equal sliver of empty space on all 4 sides of the battery. My original installation had this. I suspect it helps reduce transfer of vibration and shock from the battery to the rest of the internals.
Jeff Clayton - 回复
I’m glad I read the comments above first!! I decided after I attached the adhesive strips to the back of the new battery to leave the plastic backing on the sticky side of the tape that faces down and first attach the cable. I then pulled of the plastic backing and carefully centered the battery leaving room all around before pushing down to stick to the back of the case. I then disconnected the battery from the connector to complete the front panel re-connections. Good to go at that point and no bad alignment of the battery and its connector with respect to the case and surrounding components.
calvord - 回复
Good advice.
Ted -
  • 小心对准位置,然后将电池放入iPhone。
  • 如果可能的话,请尝试在电池底部边缘和左侧留出一些空间。 这样在未来需要更换电池时可以更加方便地剥离胶带。
添加评论
  • 电池对准位置后,将其放入机身中,然后轻轻按压电池使胶条贴在后盖上固定住电池。
添加评论
  • 在您重新组装iPhone前请再一次确保已经断开了iPhone的电源连接。
  • 维修手机时未断开电源连接可能会导致手机零部件的损毁。
Now what do I do? Can you include a link here to the last group of steps?
Joshua Greve - 回复
It depends on which model you have. All the instructions are linked in the introduction, above.^^
Jeff Suovanen -
I had the iPhone 6s Plus, so I returned to step 26 here:
iPhone 6s Plus 电池更换
It would be nice, though, to have all the links at the top of the page down here as well.
Joe Teichert - 回复
“Be sure to disconnect the battery again before reassembling your iPhone.”
Ummm…how does one reassemble with the battery disconnected?
Tim Shackelford - 回复
The battery needs to be disconnected while you reinstall other components, like the display. You reconnect the battery before closing up the phone. As a rule, in any electronics repair you always disconnect power first, and reconnect it last.
Jeff Suovanen -
结论
若想重新组装你的iPhone ,请使用之前的iPhone电池更换指南逆序操作即可。
987等其他人完成本指南。
特别感谢这些译者︰
93%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Jeff Suovanen
于2013年08月06日注册
172,236 信誉积分
创作了466篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,201篇指南
I had to read these directions thoroughly three times before proceeding as I didn't want to screw it up on the adhesive. Went slow and it worked just fine
patrick knaggs - 回复
I would say jus watch out as you go from step 4 to step 5 - the white adhesive can become slightly detached from the backing as you push it onto the edge of the battery and then around to the back side. Extreme care here! Very good guide and equipment. Galaxy class!
Steve Cottrell - 回复
All was good, aside from the adhesive bunched up when I removed the blue backing and it started to separate from the pink backing. I had to just gingerly make sure it was all straight and kept steady like a heart surgeon until I had it smoothed down as best as possible. It all went well, but I was worried I'd end up with a big stuck ball of white adhesive in the middle of the battery plate, making it all uneven and stupid looking.
DiscoDan74 - 回复
What happens if I use a different adhesive than this one?
gleeglee217 - 回复
The iPhone adhesive strips we sell (and the original Apple ones) are special since they have very strong adhesion, but they can be removed easily by pulling on the tabs on the lower edge of the battery. People have had success with our 3M double-sided sticky tape (aka sticker tape), but standard plastic double-sided tape may not have enough strength to hold the battery in place. If you want the strongest adhesive possible, you should use iPhone adhesive strips mentioned above, but if your phone isn't subject to lots of movement, you could get by with some sticker tape.
Evan Noronha -
Thanks for this Jeff! I had a small problem after I followed Step8 and 9 because the battery connector attached to the replacement battery was about 1mm too long and thus aligning the top of the battery caused the connector to be 1mm too high for the socket. I had to bend the 'neck' between the connector and the battery just to align the connector with the socket.
patrickczar - 回复
Are the adhesive strips necessary? Mine broke and i put in the battery anyway. Should i purchase a new set and add them in?
dsesnovich - 回复
DO not follow their directions! The color of the film is wrong. Which ever film pulls off the easiest without wrinkling is the one you pull off first then apply it to the battery. Then pull the hardest plastic off next and push the battery to the phone case.
craigmatherly - 回复
If you've wrinkled the strips, it's too late—you'll have to start over with new strips. This guide uses the strips you'll get from iFixit; if you bought different colored strips from somewhere else, you can likely still use the guide, but you'll have to be a little more alert about which side is which.
Jeff Suovanen -
The strips come with a single piece of plastic covering both strips ("double strip cover") on one side, and single pieces of plastic covering each strip individually on the other side ("single strip covers"). If you pull off the single strip covers first, the double strip cover holds the two strips aligned. This makes it easy to position them.
If instead you pull off the double strip cover first, you are left with two individual strips, and have a harder job attaching them. So I think it's clear that you pull off the single strip covers first, regardless of the color of the plastic covering.
Winston -
I completed this in about 25 minutes it was very straightforward I think of anybody has a problem with any of the instructions or videos they really shouldn't attempt it! You just need to take it slow and don't force anything.
Greg Stevens - 回复
It's reduculous to charge for these strips. Ifixit should include them with their premium priced batteries.
Mike734 - 回复
We currently include them with all our battery fix kits.
Evan Noronha -
Many of us don't need the kit as we already have all the tools. But everyone ordering a new battery needs the adhesive.
Mike734 -
Fair point. I'll ask our product team what they think of including them.
Evan Noronha -
i changed the battery every things ok now but i have problem whith charg it , 7 hours and the battery got 50% of charg ! its not full
newstyle - 回复
I don't want to put anything sticky and troublesome for replacing anything as I may want to tinker around with it.
Just want to ask if there are any problems if one is not to stick it back on.
Xavier Jiang - 回复
Without adhesive, the battery will be free to rattle around inside the phone. In the short-term it probably won't hurt anything—but if it's a phone you carry with you every day, it could cause issues over time. Maybe try a milder tape or adhesive if you plan to open it up again in the near future. A little double-sided Scotch tape works reasonably well.
Jeff Suovanen -
1. Be very careful not to pry near the top of the battery if the adhesive breaks during removal. It's tempting to use a long plastic probe/spudger at the top of the battery: there is more space there than on the side. Don't. The upper component cable is under the top of the battery. It's easy to catch with whatever you use to pry. I damaged mine, and now the power button, video microphone, flash, and mute switch don't work. (Luckily the volume buttons still do.) Even from the side, be careful not to pry near the top.
2. I put the adhesive on the case first. This left plenty of tab at the end of the adhesive strips, but this didn't help when I found I had a defective replacement. The adhesive tore. It's possible the adhesive is directional, and meant to go on the battery first.
3. Pulling the adhesive to the side is not recommended by 3M for their Command hooks, which use similar adhesive.
http://www.command.com/3M/en_US/command/...
4. Replacement adhesive I got was thicker than the original.
Winston - 回复
Some posts suggest putting the adhesive in the case first. This defeats the black plastic tabs on the adhesive. Note Steps 1 & 2 in the instructions. A bit of adhesive above the black plastic strips on one side adheres to the TOP side of the battery. This positions the black plastic strips at the foot of the battery. If you put the adhesive in the case first, the black plastic tabs will be upside down, and you'll have the tabs sticking up.
Look at the black plastic tabs to see which side of the plastic coverings to remove first, Remove the side which has the bit of adhesive first.
Alterations to instructions:
1. Put long part of adhesive on the battery first, then do the black plastic tabs. Alignment of the adhesive is easier.
2. Align the side of the battery with the side of the iPhone case, leaving 1/16"/1mm at bottom, then fold the battery down into the phone. This allows for easy top and bottom alignment. Check that the adhesive will not touch the Upper Component Cable before folding the battery down.
Winston - 回复
Easy Peasy! Lemon Squeezy! Thanks for the great tutorial, it went off without a hitch!
Patrick Burnett - 回复
Thoroughly read the directions prior to installation to ensure how to install the adhesive strips properly. Was able to remove the old battery adhesive with very little problems. Just took my time and removed it by pulling it out slowly. If you follow the directions you shouldn't have a problem. Took 7 minutes to remove the old battery and install the new one.
ronjon40 - 回复
Very helpful instructions for the adhesive strips. The most challenging part is lining up that tiny battery connector PRIOR to sticking the battery in place. It is very helpful to line the battery/connector up BEFORE removing the last pink strip. This way you know exactly where the top of the battery needs to be BEFORE you stick it to the bottom of the case. Hope this helps!
Ryan - 回复
A piece of the plastic case that the rubber adhesives came with ended up sticking to the adhesive strips when i was not being careful. Because I don't have another set of strips, and the plastic was only blocking a portion of the adhesive, i trimmed around the plastic, and installed the battery.
If there is a small piece of plastic between the adhesive and the back of the phone, will this cause future problems? Thanks in advance!
srdisciullo - 回复
I wonder if it'd be ok to maybe use less of the adhesive strips. I guess their function is to keep the battery from sliding around. I was thinking in hindsight since I had such a hard time getting the battery out, why not just use minimal stripping to keep it from sliding? Maybe little squares on the corners. This would make the battery easier to get free when the strips break because there would be less sticky surface area holding it in but enough to keep that light weight battery from sliding. I did the full stripping and I'm hoping I never have to do this again as my experience of taking off the strips almost resulted in a calamity. Next time though I may just heat the back up to melt the strips without even trying to take them out like described.
Garret Gray - 回复
I have replaced about 6 batteries in iPhone 5S and 6. I cut and only use about 1.5 inches of the new strip, centered in the middle (horizontally) of the battery with the end tab wrapped over the battery bottom for future grasping / removal. Those strips are very secure and don’t see the point of two 3.5 inch strips to hold it in place. I thought that they possibly served a dual purpose of securing the phone and as a thermal transfer medium to move heat from the battery to the case back. I have yet to see anyone post that there is a need for heat transfer from the strips, so to me, use the smallest length possible to secure the phone and make it an easy job for the next removal !!
bdahl385 -
i used any Double-sided adhesive tape and had never issues.
Mandala Fris - 回复
Very straight forward.. very simple and easy to apply.
Dennis Burgos - 回复
The blue backing won’t peel away from the adhesive!! What kind of crap design is this?!?!
Nathan Crane - 回复
All went well until removing the old adhesive tape as it broke off close to the tab end. Not having a warming pad, I used my wife’s hairdryer to heat the underside of the phone. Being mindful not to overheat the phone, it took several attempts with the hairdryer on full heat, to build up enough heat to soften the tapes. I was surprised at just how much heat was needed! Not also having the plastic card tool, I improvised with cutting out my own from an empty ice cream tub lid. This worked well together with the spunge tools and eventually lifted the battery from the case side.
The phone is now reassembled and being charged up so fingers crossed that it works without any problem when it reaches full charge!
Dave Pym - 回复
I tried it and it worked the first time. I had trouble getting the left adhesive out, but once I got a second ‘grip’ of it I got it out. On reassemble I lost one of the tiny screws for the ribbon cable cover plate. But phone works great again. Thanks for the excellent step-by-step.
Kent Kersey - 回复
Worked as planned. The adhesive strips are really stiiiicky. It’s a little tricky making sure they lay flat on the back of the battery. Once they touch they are stuck. Had a little trouble deciding how to and then positioning the very stiff part of the new battery lead. Worked out OK. I have an optivisor loop. It was really helpful for seeing and replacing the tiniest of the screws. I’d recommend some kind of magnification aid if you have older eyes like mine.
Claude Rightmire - 回复
Excellent guide, this battery replacement went perfectly for me.
mikeatkinson - 回复
Great guide with lots of details. I ended up skipping removal of the display and leaving it rubber-banded to a soda can while I pulled the adhesive tabs loose. The adhesive came right out and I was done in less than 10 minutes.
dllamond - 回复
Blue side adhesive was beyond stuck to the plastic backing. Either was old/defect or… something… The adhesive tab was not the same as shown in video. kinda disappointing but this is the first time its happened out of all the ifixit jobs I have done.
Sean Tobeler - 回复
Hi Sean! Thank you for your comment. We’re sorry to hear your adhesive strips arrived unusable. Our Support team would be happy to send you a new set of adhesives if you like! If it’s not too much trouble, please contact them through our help page so that they can get you all fixed up.
Kadan Sharpe -
OMG these are terrible instructions. My adhesive strip? The pink side peeled off easily, but the blue side refused to come loose. The instruction imply that the blue side goes down on the battery, and the pink side goes down on the case. But there is no way my blue side is going to come loose. To top it off, people are commenting that the instructions are backwards. It would great if there was a definitive correction to this!
peterbastian - 回复
These are TERRIBLE instructions. My blue side (which the instructions say goes down on the battery) will not separate from the blue backing. The pink side, which the instructions say goes down on the case comes off very easily. But, since I cant separate the blue side from the blue backing, I’m screwed. To top it off, some people are commenting that the instructions are backwards. Either way, my adhesive strips are defective. Cannot separate the strips from the blue side. They will not budge.
peterbastian - 回复
Sorry to hear that! If you get in touch with customer service we’d be happy to set you up with a replacement.
Evan Noronha -
I went through the instructions entirely one tie and it took me approximately 10 minutes to completely open, remove, install, and close. I was able to fix this by only removing the two Penelobe screws at the bottom of the phone and the two Phillips for the battery ribbon. I left the screen attached and had no issue. Excellent guides.
Brian Moore - 回复
Same. Pink comes off fine; blue will not release from adhesive. Blue-side-complaints seem to begin around Oct 2017. I’d bet it’s a manufacturing flaw, not a problem with instructions.
shawncampbell - 回复
The adhesive refuysed to come off the blue foil. It completely ripped and it ruined the entire repair. Absolute material fail. Worst repair ever.
Doopy - 回复
My repair worked fine. I pressed the adhesive strip down with my fingers to make sure it stuck to the battery, and was able to peel the pink strip away. The adhesive wanted to come off the battery in places but I kept steady pressure on removing the pink strip at a 45 degree angle. The adhesive stayed on the battery. I didn’t remove the screen (just the 2 Penelopes), and the 2 Phillips screws for the battery connector cover. So I completed the repair successfully.
ericrose62 - 回复
The blue tape DOES NOT release from the white sticky tape. Even worse: you've known about this issue for months and have not corrected it, sending me junk tape in January. Shame on you.
Paul Daly - 回复
@catsnot I hear your frustration and I’m sorry you had a bad time with this. If you get in touch with the support team they will be happy to send you some replacement strips. Yes, we know there are some defective release liners out there; unfortunately we don’t manufacture this particular product and there’s no way for us to test individual strips without destroying them. It’s also hard to track because the vast majority of folks have no problem. (I’ve yet to see a defective one in person even though I use them all the time.) Long story short, we haven’t figured out how to prevent the bad ones from shipping out—but if your order is one of the unlucky ones, just contact us and we’ll get you a replacement on the double. In the meantime, if you want, you can reassemble your phone with a little double-sided tape to secure the battery temporarily. Apologies again for the trouble.
Jeff Suovanen -
for anyone doing this for the first time, definitely detach the camera/screen before trying to remove the battery.  it became a real tug of war to get it out.  battery can get mangled/bent.  Be sure to reconnect before the final battery attachment.  bending the battery connection before reconnecting was key.
todd adelman - 回复
I’m not sure how many people had trouble with the screen, but the rubber band and the box trick worked very well for keeping the screen attached and out of my way. It was the first time I attempted iPhone surgery.
James Gatts -
If you remove the Taptic Engine while trying to get the battery out, be sure to put it back in BEFORE putting the battery back in with new adhesive strips. If you don’t leave enough space for the Taptic Engine, you’ll have to start all over with new adhesive strips.
Erik Johnson - 回复
i literally used the tape things from the backs of the adhesive hooks
Jake Longacre - 回复
So I removed the old battery, and secured the new battery and then I reassembled the phone, put last two screws in and then it wouldn’t turn on. I plugged it in and the white turn on screen with the Apple in the middle came up, then it turned back off. And did it several times till unplugged it, then it wouldn’t turn on at all. So I put the old battery back in and that’s what I’m using now. — not sure what is my plan of recourse..- Mike Gliko
zoot_scoot_riot - 回复
Sounds like you got a defective battery. Contact the seller and ask for a refund or exchange. On the off-chance you bought the cheapest thing you could find off eBay or Amazon, you might want to cut your losses and just buy one from someplace reputable—not worth trying to save a few bucks on something as important as a battery.
Jeff Suovanen -
Worked perfectly. No issues, thanks!
mdavis43 - 回复
Tolle und Verständliche Anleitung, als Erfahrener Modellbauer hatte ich mit dem Akku Tausch keinerlei Probleme.
Ich habe den Kleber unter dem Akku mit der Kleberziehmethode ohne Erwärmen und ohne verbiegen entfernt, das Alte Akku ist ohne jede Beschädigung.
Das Werkzeug das bei dem Set war ist zwar Einfach aber Ausreichend. Die Montageplastikkarten sowie das Ersatzklebeset fürs Akku habe ich umsonst gekauft weil nicht benötigt.
Das war ganz Sicher nicht der letzte Akku den ich hier gekauft habe. Wir haben noch mehr iPhone in der Familie da kommt noch etwas auf mich zu :-)
LG Hennaman
D.Drumm - 回复
I received one of the defective strips and iFixit sent me replacement strips with no issue. :) Thanks iFixit!
Sarah Ybarra - 回复
添加评论
浏览统计数据:
过去的24小时: 189
过去的7天: 1,463
过去的30天: 6,640
总计 242,896
