简介
使用本指南替换 iPhone 8上的显示屏组件。本指南不包括移除屏幕上的小型组件,因此您可能需要将组件转移到新的屏幕上。 我们将在不久的将来为这个过程提供详细的指导,敬请期待。
确保将旧的主页按钮转移到新的屏幕上。 原始的 home/Touch ID 传感器必须被转移到新的显示才能让 Touch ID 正常工作。
打开 iPhone 8会损坏显示屏上的防水封条。 如果不更换密封胶条,手机能正常工作,但不再防水。
视频介绍
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
结论
要重新组装您的设备,请按照相反的顺序执行这些指示。
43等其他人完成本指南。
特别感谢这些译者︰
80%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Adam O'Camb
于2015年04月11日注册
25,168 信誉积分
创作了295篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了5,912篇指南
So once the adhesive seal is broken, obviously the warranty is done for, but is there any way to restore water-resistance?
Chris - 回复
You need to buy a special waterproof glue for it.
Ou Hiroshizon -
And do you just wing it for the front camera, proximity sensor etc ?
kyle - 回复
This guide assumes you’re replacing the entire display assembly, with those parts included. If you bought a bare display then yes, you’ll have to transfer those additional components over, and that’s beyond the scope of this guide—although as mentioned in the introduction, we’re working on adding guides for those additional components as well.
Jeff Suovanen -
I’m looking to replace the back glass as well. Any advice?
Trey Granger - 回复
This video shows what’s involved. Basically, remove ALL of the internals from the phone, and then painstakingly heat + pry the glass shards off the back of the chassis. The metal camera housing has to be forcibly twisted out and replaced. It’s a very difficult repair, with a high risk of damage to your phone (and a high risk of injury if you don’t wear gloves and safety glasses). I’m not sure the phone will ever look 100% again or retain its IP67 rating. My advice would be to wait until a full enclosure replacement part becomes available with the glass preinstalled, and then transplant your entire phone into that. Meantime, the glass itself is purely cosmetic, so I’d suggest covering it with a custom skin or wrap. Of course, the final option is to pay Apple $349 USD for an “other damage” repair and make it their problem (they’ll swap you out for a new phone and yours will go to a refurbishing center somewhere).
Jeff Suovanen -
wait a second… Are you saying that when we change the screen it is also necessary to change the front camera?
Caio Antonius - 回复
@eitantonius A lot of new screens come with a replacement front camera already installed. They cost a bit more, but make the job easier. You can save a few bucks if you buy a stripped-down display, but you’ll need to go through some additional steps to transfer the original front camera (and a few other components) from your broken screen to the new one.
Jeff Suovanen -
I cracked the camera glass (housing) on the back of the phone. Is it possible to replace without replacing the entire back of the phone/case?
Chris - 回复
May I know any way to fix the auto-brightness issue after screen replacement?
Alison - 回复
Is there any update on the ambient light sensor yet? Is it working with the new beta version of IOS12? I would be delighted to hear about it.
valentijnawc - 回复
To the best of my knowledge, no, there is no update. Apple seems to be ignoring the problem for the time being. Various aftermarket screen suppliers and refurbishers are trying to develop a fix, but none of them have made it to market yet.
Jeff Suovanen -
添加评论
浏览统计数据:
过去的24小时: 176
过去的7天: 1,051
过去的30天: 5,217
总计 35,292
