简介
Wi-Fi 信号出现问题?你可能需要更换你 iPhone 6 的 Wi-Fi 天线。
在开始拆卸前,确保将手机电池电量放到25%以下。不小心对电量充足的锂电池施压或打孔可能会使其着火和/或爆炸
  • 在开始拆卸前,确保将手机电池电量放到25%以下。不小心对电量充足的锂电池施压或打孔可能会使其着火和/或爆炸
  • 在开始拆卸前,关闭手机电源。
  • 拧出Lightning数据口两侧的两枚3.6 mm 五角(梅花形)螺丝。
When reconnecting be VERY careful not to over tighten. The connectors on the screen that these 3.6mm Pentalobe screws lock with are notorious for breaking off
Blair Tryba - 回复
what do i do if ive managed to tighten them too hard and now they wont come off?
kristian686 -
Before opening the phone, I gently warmed it using a buckwheat heating pad. This made removal of the adhesive strips (steps 20 to 24) easy.
Howard Bales - 回复
Exactly what I did as well, the gently warming made the adhesive removal work like a charm. The heat as well help to lift the screen easily, no need for the prying tools for me to open te phone.
For the adhesive removal just pull it slowly to the bottom of the phone and keep in under tension.
On reassembly, turn on the phone after getting all connectors back in place to verify all is working fine before putting all screws back in their spot.
Maarten Vergauwen -
I put mine back together but mine looks very different than this one. Why is it that when I make a call I cannot hear through the ear piece and have to put it on speaker. Also my screen doesn't go black when my face touches it
Bailey Wilson - 回复
Hey Bailey, which repair were you attempting? Is it possible you have a 6s, or maybe a 6 Plus? You may have better luck with faster troubleshooting if you post in our Answer Forum!
Sam Lionheart -
See its a long time ago you had this issue. You can try to remove the cable from front camera/sensor/earpiece from the motherboard port and gently push it back on. All the problems you relate to is thru the same cable. If this dont solve your problem, check if the earpiece is correctly placed onto the polarity poles, and that the proximity sensor is lying right down into the corresponding socket. If something is blocking the sensor, yeah then the screen wont turn on/off when you put it onto your ear.
Kenneth Hilstan -
You only need 000 Screwdriver for ALL!
Tom Long - 回复
If you skip to STEP 36, you’ll see that you’ll need a STANDOFF SCREWDRIVER BIT to be able to get all the way to Step 39 and remove the antenna. Read through the comments, and you’ll see how frustrated people have gotten since my kit didn’t include the Standoff screwdriver, and I had to dig around for and carefully use a flathead, which took a very long time. If you can’t get that Standoff screw off, you’ll end up with a partially disassembled iPhone and unable to progress. Make sure you have this tool before you proceed.
Brian Mojica -
what do i do if all the screws fail to come off and if i don’t have some of the tools like the iSclack
Brandon Kato - 回复
I see in the preamble that when you replace your logic board, you would lose touch id functionality, so my question is what if you have the homebutton and thus the fingerprint reader for the logic board replacement, would touch id work?
socratesmens - 回复
The guide for the iPhone6 battery replacement needs to be revised. There are a couple of issues.
1) While the battery cover has two screws, they are different lengths. Since they are very small, it can be hard to see the difference (until one tries to screw the smaller one into the longer hole). The video needs to mention this.
2) The application of the adhesive strip if very different from what is mentioned. Also, there is a “one piece plastic” applique, and it is very unforgiving. The video should show this process in more detail.
I believe the attention to this detail would help folks correctly install their iPhone 6 batteries, and with the recent Apple disclosed battery problem, would continue to show that iFixit is very committed to the end-user.
Gary Long - 回复
Please reconsider this repair!
Before you remove any screws, please consider taking your part to a local repair pro and asking them to install it. The many cables connecting the screen assembly to the body of the iPhone are unruly and hard to reconnect. I knicked a cable and thus rendered the entire assembly and repair unfixable. I consider myself capable and tech savvy, but it’s too easy to make a tiny mistake and ruin your phone.
Bruce Coriell - 回复
I felt a bit silly getting stuck at the end of a long repair, unable to screw one of these last screws back in. What worked was gently pinching the phone above and below the screw, to make sure the screen and back were perfectly aligned.
Matt D - 回复
Apple edits posts on their Communities website that link to this fix page justifying as follows:
“We’ve edited your post because following the procedures at the site you provided may lead to damage to the user’s device.”
What is certain is that following Apple Support’s advice of resetting our phones again and again never works whereas this fix works. Apparently Apple does not want people to know that their hardware fails and can be fixed, because then they would need to explain why they don’t offer neither the fixing service nor the fixing advice by directing us to this website.
Brice - 回复
Before you get started, I suggest you confirm you are replacing the correct camera. If you are thinking of a camera, the front is the side of the device with the main lens. On an iPhone this is actually known as the rear facing camera. Once the phone is disassembled your orientation can be distorted and it is not that hard to fail to realize your are replacing the wrong camera. Doh!
William Miller - 回复
I found it very useful to use a magnet sheet when doing these repairs. I use electrical tape or a sharpie to make a grid, and place each micro screw in a separate box on the grid.
I work directly over the magnet sheet, so that if something drops I have a better chance at not losing it.
If you do lose a screw, go over the work area with a fridge magnet. It will pick it up if it hasn’t popped too far away.
Megan Telliano - 回复
接下来的三个步骤会用到iSclack,一个便捷而安全地打开iPhone 6机身的工具,我们推荐所有需要多次修理手机的人都人手一个。如果你没有iSclack,跳过下面的3个步骤来寻找其他的方法。
  • 接下来的三个步骤会用到iSclack,一个便捷而安全地打开iPhone 6机身的工具,我们推荐所有需要多次修理手机的人都人手一个。如果你没有iSclack,跳过下面的3个步骤来寻找其他的方法。
  • 如果iSclack上的塑料定位卡子尚未被拆下,请手动移除它——对于iPhone 6这种个头较大的手机来说不需要。
  • 握拢iSclack的手柄,使两个吸盘分开。
There was only one suction cup in my kit. Why show the need for two if ifixit provides only one?
Lisa Klitses - 回复
Do Not Worry. The Islack comes seprate. This guide shows you how to remove the front screen with a normal suction cup.
Owen -
I found that the single suction cup from the kit worked very well. It didn’t take that much force to separate the front panel from the phone. I think any suction cup that you are able to get a firm grip on will probably work as well. There isn’t any adhesive holding the front panel in. It just snaps in and out. If you have a cracked screen and no screen protector, it may be hard to get a good suction seal. If that’s the case, someone else here suggested applying clear tape to the front glass to get a good surface for applying the suction cup. In my case, I already had a screen protector that was still intact so the suction cup sealed easily.
fiftysomething - 回复
  • 将手机靠下的部分放在两个吸盘中间。
    • 调整屏幕一侧的吸盘位置,使其刚好在Home键上方,但不会盖住Home键。
  • 松开手柄,使iSclack的两个吸盘合拢。固定好吸盘的中心,并按压使其牢固地吸附在手机的正面和背面。
添加评论
  • 拿紧你的iPhone,然后再次握拢iSclack的手柄,将iPhone的前面板与机身分离。
  • iSclack专为安全地打开iPhone设计,开口大小足以分开机身组件,但不会扯到显示排线。
  • 将两个吸盘从iPhone的两个部分上取下。
  • 跳过接下来的三步,直接进行步骤8。
The iSclack opened the iPhone 6 with little effort. I could have given even less opening pressure than I did. Fantastic tool. Worth the investment.
Tim Dougherty - 回复
It's never mentioned anywhere that with iSclack even if you save the cables, glass easily detach from plastic frame. When you ri-assembly the phone, this will involve a glass not perfectly adherent to the body. In my opinion is better if you help yourself with a spudger to lift frame from rear case when you are using the iSclack.
marco bigoni - 回复
Holy cow this tool made it so much easier than a spudger and didn't damage anything. Totally worth the investment.
Fratelli '85 - 回复
Really need to get one of these. so much easier then the basic type.
Richard W - 回复
  • 如果你没有iSclack这个工具,使用单个吸盘来分离前面板。
    • 将吸盘按压在屏幕上,位置在Home键的正上方。
    • 按紧吸盘以保障气密性。
This is nearly impossible on a screen that is shattered
Erik Madsen - 回复
You can put clear tape over it. it works.
Owen -
Try putting a strip of packing tape on the screen. That will make the surface smooth and help keep the suction.
Joanna - 回复
John, your lips move but I can't hear what you're saying. ;-)
TimD -
Argh!! Don’t put the suction cup over the home button to pull. While it works, it also breaks the screen at the weak point below the home button. Ask me how I know.
-Tom
tombuy - 回复
  • 用一只手固定机身,另一只手轻轻地拉起吸盘,使前面板从机身上分离。
    • 不要着急慢慢来,用力要恒定、持续。iPhone的前面板固定得比大部分设备结实。
  • 在一只手继续拉吸盘的同时,另一只手使用塑料撬棍轻缓地将前面板和机身后盖撬开。
  • 前面板由数个卡口固定在机身上,所以需要吸盘和撬棍共同用力来拆下前面板。
Pulling up on the suction cup helped get me started, but what worked for me was pulling up gently while sliding the plastic prybar gently along the seam towards the top of the phone (on both sides), and it came open without having to put excess pressure on the suction.
lauren carroll - 回复
Same here, just open the gap a little with the suction cup and then use the opening tool on both sides.
Tobias - 回复
Along with the suction cup I used some Command adhesive strips to hold the bottom of the phone to a workbench as they easily pull/stretch away when you need to remove them!
Dion Sosa - 回复
That’s a very clever idea, thank you!
Megan Telliano -
Suction cup pictured here is the older version (with ring). I have one from my previous battery replacement on iPhone 5 and used that instead. The new one (gray with blue handle) kept on popping off. Overall, popping out screen was not as hard as it seems with these instructions, but do proceed with caution.
youmingc - 回复
Dion's idea to use removable adhesive strips was great, even better, use it to attach the iPhone to a clipboard. This will allow for a sort of Lazy Susan function while you work. I also used adhesive strips to attach my iPhone box to the clipboard as well and used that as a back rest (with rubber band) for the screen as pictured in steps below. This allowed me to very comfortably skip steps 13-19 as others have commented.
Adam - 回复
The new suction cup (plastic handle) is not so suctiony. Prepare for this thing to pop off a couple of times when opening the case.
Chet Seidel - 回复
Be very careful because it feels that it holds very tight but with the last pull it can fly away.
Kristaps Grinbergs - 回复
Be very careful when you pull up the display! Do not keep your other hand on the display surface or you can broke it!
Luke Man - 回复
I did all the suggestions here and it just wasn’t moving until I repositioned the suction cup up over the home button for more leverage. It finally came up enough to slip the plastic opening tool under the edge.
Alan Derrick - 回复
  • 拨动吸盘上的塑料栓来解除真空密封状态。
  • 从前面板上取下吸盘。
添加评论
  • 以屏幕顶端为支点,从屏幕底端掀起前面板。
    • 顶部边缘的数个卡扣会起到类似铰链的作用。
    • 重新组装前面板时,将前面板的卡口对齐机身顶部,然后将前面板向屏幕顶部滑动,直到其上端与机身后盖完全扣合。
It's not clear from the instructions but it is shown correctly in the pictures: when the front panel assembly is just open (at a small angle with the rear case) pull the top edge clips out of the rear case to slightly separate the two components, then swing the front panel assembly away from the rear case. I assume not doing so would potentially damage the connecting ribbon and/or the alignment clips. Just a guess...
ethanlust - 回复
Ein Tipp zum Zusammenbau: Das Display ca. in 45 Grad halten und vorsichtig an die obere Kante des Gehäuses drücken, bis es bündig und glatt anliegt.
Dann das Display langsam und vorsichtig anklappen und die Clips von oben nach unten festdrücken.
SAS - 回复
This entire process went smooth. Final step of re-assembly , the assembly does not seat into the framing. The white gasket seats on one side not the the volume button side. Alignment looks good. How much pressure does one apply on the reassembly?
Bruce Fournier - 回复
My problem is the front panel does not want to joint together with the rear panel… it feel like the front is too big but it look perfect but does not clip in place… Help…
Tony Chicoine - 回复
same problem, in the final step, the screen does not fit entirely. it looks like the size is not 100% correct, but 99%… one side of the case stays open…
Andrea Andreoli - 回复
Same thing here, with a new screen it doesn’t fit quite right during re-assembly. It sits just a little bit higher and doesn’t look seated.
Adam Carl - 回复
Some people have noted that the screen doesn’t seat properly on the case. Here’s how I solved it:
The issue is that rectangular brackets on the back of the display aren’t latching with the corresponding clips in the base. I think the brackets are missing the gap between the spring plate and bracket with the latching bumps on it on the base. Here’s my solution:
Position the top of the display slightly below the top of the case so the clips on the back top of the display start to engage with the phone case. Important: don’t push it all the way up!
Now press both sides of the top part of the display until the display seats on the back. Make sure both sides are flush with the case.
Repeat for the middle of the display. The bottom of the display will remain bent up because it will interfere with the bottom edge of the case.
Now push/slide the display up so the top of the display lines up with the top of the case. The bottom should then snap into the base, and the display should be flush with the case all round.
nigel - 回复
  • 将前面板掀起至垂直,并且在你处理手机其他部分时用什么东西支撑撑着它。
    • 必要的时候,一听没有打开的罐装饮料可以很好地完成这个任务。
  • 用橡皮筋将前面板与支撑物固定住。这可以避免拉扯到显示排线。
A picture is worth a thousand words! This idea at Step 9 is perfect and you can definitely do the entire rest of the battery replacement WITHOUT having to disconnect the display from the rear case. Just leave it secured exactly as shown in this picture and you're good to go. I just completed the repair and the most difficult part was just lining up the new battery connector! Excellent instructions and generally EASY repair because this step was so helpful!
Ryan - 回复
I did the same. Made the work go so much smoother!
dcommins - 回复
I do NOT recommend leaving the display and the rear case connected during this repair. If you run into any resistance removing the battery, or slip in the least removing it, you risk tearing the ribbon cables that attach the two pieces. I did and now I've got to replace the Front Camera and Sensor Cable. Sadness.
Ergolad - 回复
I'm going to try it this way, because the odds of damaging the connector during removal seem greater than the risk of ripping the cable, however, I plan to cradle the phone in the "L" of simple, sheet metal bookend, and secure it using blue painter's tape. Seems more stable.
bobcloninger - 回复
If you do this step carefully- (rubber band the front panel, and carefully peel away the battery adhesive) you can SKIP 13 THRU 19!
Larry House - 回复
Rubber band and a large can of soup held the front in place. Go slow, steady firm pressure. Take the vibrator out though. Makes pulling the adhesive tape out much easier. Great video and written instructions!
Sherman Homan - 回复
I do NOT recommend leaving the display and the rear case connected during this repair. If you run into any resistance removing the battery, or slip in the least removing it, you WILL tear the ribbon cables that attach the two pieces. I did and now I've got to replace the Front Camera and Sensor Cable. MUCH Sadness.
todd adelman - 回复
I decided to do the repair on my iPhone 6 without detaching the screen. I ended up screwing two pieces of 3/4” x 3” x 6” wood together at right angles. I used 2 rubber bands to secure the screen to the vertical piece and 1 rubber band to secure the base to the horizontal piece. One of the two adhesive strips broke and I had to really work to get the battery out. The rubber bands held everything together nicely. The wood pieces were slightly wider than the phone which made it easy to hold everything together while I was working the adhesive strip out.
brian - 回复
Mine worked great install went perfect. Was like a new phone… for a couple months. Phone may be failing for other reasons, but there’s a ghost image in the shape of the battery in the display now. Very strange. The ifixit kit did give life to it for a while though.
smahar - 回复
Hey Smahar! If you still have your tools, I’d recommend opening your phone up to make sure the battery isn’t swollen. If it’s pressing against the screen, it’s possible that is the case. If it is swollen, I highly recommend you replace it, it can be dangerous to leave it in place.
Sam Lionheart -
  • 卸下电池排线固定架上的两颗十字型螺丝。
    • 一个2.2毫米螺丝
    • 一个3.2毫米螺丝
ok well what exactly does 2.2 mm and 3.2 mm mean if a #000 is needed? why even mention those numbers?
Cory Berends -
Those are the screw lengths. They’re important to mention so that you don’t put the longer screw in the wrong place. If you start mixing up screws, you can end up with permanent logic board damage.
Jeff Suovanen -
These screws require a Phillips #000 not Phillips #00 bit.
David Powell - 回复
How do you know that? Just wondering :)
Didier Daniel -
I replace the antenna in the upper left-hand corner an in the bottom middle with the lightning connector because After disassemble it completely i lose my ability to have Cellular. After i replace both antennas i can find i nevertheless have cellular. anybody an idea ?
kupies2011 - 回复
@davidsapowell @David+Pobuda - I've submitted an update per your comments. Thanks for the guidance!
Nate Schley - 回复
With the phillips screwdriver included in the repair kit I cannot unscrew any of the interior screws because it is not the right size even though according to these comments all of the screws are #000 and on the product listing it says that the screwdriver I got is #000. Any suggestions?
Wilson Styres - 回复
Sounds like you need to adjust your technique. The included PH000 driver works fine; I’ve done many many phones with it.
Jeff Suovanen -
Upon reassembly I found the Red 2.2 mm screw won't seat. Is it possible it sheared off? The Orange 3.2 is solid in both holes but 2.2 doesn't securely fit in either.. Should I just leave off the 2.2?
smcgreg - 回复
My phone was missing this screw also!
Gail Starr -
Duh, had the cover on the wrong way. Switched it around and the screw fit. (:
smcgreg - 回复
When I insert the 3.2 mm screw... The phone shuts down, very weird because am not seeing what could cause this short...
Juan Monge - 回复
I’m having the same issue. Thinking about just leaving that screw out. Did you ever get your’s working?
Cavell Blood -
Using the Phillips 000 screwdriver included in the kit, I am able to remove the 3.2 mm screw, but not the 2.2 mm one.
Dan Solovay - 回复
None of the screwdriver heads in this kit are big enough for these screws!!! I now have an open iphone and i have to go to the store to buy a different screwdriver..I do not recommend this
Elaine Eason - 回复
I was unable to unscrew the 2.2mm screw with the provided screwdriver. I was able to unscrew the 3.2mm screw but not the 2.2mm
Jameison Martin - 回复
I'm stuck in the same boat here. The one screw came out no problem but the second isn't catching at all.
Brian Adams - 回复
Stuck with Jameison and Brian here... 2.2mm won't catch with all three provided screwdrivers.
Matthijs Rog - 回复
Agreed, the screwheads included in this kit didn’t work for me either. Fortunately my own toolbox has an appropriate screwdriver…. Seeing as how we are paying for this kit so we don’t need to purchase extra tools, iFixit should really include screwheads that actually work!
Priscilla Cheng - 回复
When putting everything back together, I took care of steps 10-12 (or, more accurately 12-10) after reinserting the SIM (so between steps 20 & 19). It was easier to do before dealing with reconnecting the screen.
dhcohen67 - 回复
why do i buy a kit from you guys but you don’t provide the necessary tools for unscrewing
i dont have any screwdrivers at home the 2.2mm simply wont come off its ridiculous now i just have an open phone
Michael Amara - 回复
I had to use Phillips #00 for the 3.2mm (orange) and #0 for the 2.2mm (red). The #000 screw driver came in the toolkit is useless on both screws so I had to go out and buy new ones from a hardware store…
Tung-wei Lin - 回复
My two screws are the same diameter - 1.1mm, taking a Philips PH000 driver. However the one toward the middle is 3.3mm long, the one nearer the side is 2.2mm long.
Alastair Lack - 回复
So my kit didn’t come with the right screw driver, I should have read the comments first before buying.
My iPhone 6 battery connector bracket has 3.2mm which the PH000 works. But the 2.2mm didn’t work with included Y000.
What screw driver do I need for the 2.2 mm screw??
John Palaganas - 回复
The heads on both of those screws are identical. The included PH000 is the correct driver. There are no Y000 screws anywhere in the iPhone 6.
Jeff Suovanen -
The Phillips in the repair kit worked fine. I did 2 phones with it.
Eric Craumer - 回复
Just a followup to all the comments above for anyone who is confused: the drivers included in the repair kit work fine, assuming you know how to use a screwdriver correctly in the first place. There are quite a few folks who never learned, and that’s nothing to be ashamed of—in fact it’s common enough that we made a guide for it. Those bits were designed first and foremost to work with iPhone screws and have been extensively, extensively tested. You may come across stubborn screws or strip the heads if you’re not careful, and maybe that’s why some folks here are having trouble. In the very rare event that you actually received a malformed bit of some kind due to a manufacturing defect (which should be clear just from looking at it up close), reach out to customer service and they’ll get you squared away.
Jeff Suovanen - 回复
I just completed the battery replacement and I too found that the PH000 did not sit properly in either the 3.2 or 2.2 mm screws. Using a magnifying glass it seemed that the PH000 driver bit did not sufficiently fill the space of the screw. I happen to have the iFixit Pro Kit and used the PH00 driver bit instead, and this seemed to fill the space of both screws much better leading to successful extraction and replacement. My lack of experience with phone repair may have been a factor, but it seemed at least for my particular phone the PH00 was the proper driver bit for these two screws.
Jimmy Doi - 回复
The PH000 screwdriver I received cannot remove the smaller screw…
Michael Pesenti - 回复
So I spend 34 bucks on a kit of tools to repair my phone and they send the wrong sized screwdriver to get the battery cover off. Awesome. I can get the larger screw out but not the smaller one. What a waste of time and money.
@michael_pesenti Those screw heads are the same; the screws are just different lengths. If you have the right driver for one, you have the right driver for both, unless someone put your iPhone together with the wrong screws.
Jeff Suovanen -
@jeffsu
Nope. Actually turns out that ifixit just sent me a defective screwdriver that only was poorly sized and only managed to catch one of the screws. I had to order a new PH000 Screwdriver on Amazon and it got the screws out instantly and I was able to repair my phone.
I used the “Maximum” precision set from Canadian Tire and the PH#00 works nicely for both these screws.
Matt - 回复
Screws in mine required different size drivers also - maybe because refurbished? But have had the same probs on mbps also. Felt silly but followed Jeff’s suggestion to look at the screwdriver best practice guide and realised I was stripping screws by using too small a driver - have a couple either side of the suggested size and use the largest one that catches - I mainly used PH#0 & 00, though some screws needed #000, and there wasn’t any consistency to which screws needed which driver.
Trish - 回复
  • 取下iPhone的金属的电池排线托架。
Why in the YouTube video do you skip removing the battery connector
mjcoughlin70 - 回复
Where to buy this bracket?
syidan - 回复
One of the screws is longer than the other, use it for the higher inside hole.
Bobby Slone - 回复
  • 用塑料撬棍从主板上撬下电池排线的接头。
  • 注意只在排线接口上用力,不要伤到主板上的接口插座。如果你撬到了接口插座,你可能会直接把接口弄坏。
I skipped steps 13-19 and just left the front panel rubber banded while I removed the battery. I just made sure to be careful while removing the adhesive strips so as not to move around the body of the phone too much. Skipping the steps made the whole process much faster and easier.
Tonima Chaudhury - 回复
I wish I had done that.
Gail Starr -
Thanks for this awesome tip. Made the replacement go much smoother - saved me from removing all those other screws. I also recommend watching the ifixit battery adhesive strip video before proceeding with step 21.
Andy Milne -
Me too, no need to detach the screen (when you take care),
Tom Long -
In trying to replace my antenna flex cable, I attempted to skip steps 13-19 but eventually gave up around step 31/32 as I simply didn’t have the access I needed - the space was just too cramped with the screen still attached and I was afraid I would break something. If you’re a novice, don’t have good lighting and a magnifying glass, etc. you may just want to go ahead and perform 13-19. (Yes it will take extra time of course.)
Perrin Haley -
I also skipped steps 13-19 after reading the first comment.
youmingc - 回复
I skipped those steps too and was successful. Thanks for this tip!
jaksbackpack - 回复
Can disconnecting the battery connector while power is on ruin the backlight? Or can disconnecting the power connector at a different stage ruin the back light?
mitch Toler - 回复
You should power down the phone before disconnecting the battery. That said, the backlight should be fine. A blown backlight circuit is most commonly caused by disconnecting the display when the battery is still connected.
Jeff Suovanen -
I did open the lcd without disconnecting the battery and my lcd wouldn't working
Reza I. Permana -
Thanks for that tip Tonima! This is another confirmation that skipping steps 13-19 worked out great!
As an extra measure, in addition to leaving the front panel rubber banded in it's open, vertical position (I secured mine to a can of beans) and being very careful and controlled when removing the adhesive strips; before using the suction cup to separate the front panel from the rear case, I had secured the back side of the rear case to my working surface (kitchen table) with a strip of folded over duct tape (creating double sided tape). Such might not have been necessary as I held the rear case with one hand while removing the adhesive strips with the other, though it just felt safer having the rear case (as well as the front panel) well secured in place to help assure that I didn't accidentally cause any damage to those very fragile looking cables that were left connected, by any possible movements of either of the iPhone's halfs during the pulling to remove the adhesive strips.
Russ Levey - 回复
It happened to me, by prying the battery connector with another tool I broke part of the socket off the board. However, by placing it exactly back in place the connector could be placed correctly and it works. Lucky.
Udo Schuehle - 回复
I'd like a little more explanation on how to re-attach the battery connector. But in the end I lined it up and pressed gently down till it snapped into place.
Garret Gray - 回复
I skipped the steps removing the screen only because I didn't feel confident at all doing this. For someone who is used to electronics I would really suggest removing it because I imagine the whole process would've been easier. If there's a next time, perhaps I'll do that.
Garret Gray - 回复
The suggestions that recommend skipping step 13-19 apply to some other repair. We replaced the display, and to do so, steps 13-19 are, of course, necessary.
Gabriel Zachmann - 回复
When replacing the battery you should prepare the cable to sit in exactly as you see it in the picture. I had mine all the way back in (with sticky strips) and had to find a way to fit the cable in with the weird way it bends. Dry fit the battery with cable in place - lesson learned.
Chet Seidel - 回复
Good idea. All the instructions were great until I got to the last thing- reattaching the battery connector! I like your recommendation to dry fit the connector so you can get the right bend to the connector ribbon first.
Tom Rohrer -
I wish I had seen this also, I feel like this should be in the guide. Mine seems to be working out but I had to force the connector into place a little bit.
Kevin Harvey -
I wish I had seen this first! I also had the issue, now I have a permanent discoloration of the screen where the connector is pushing against the back. Hoping that it doesnt lead to other problems. This site is really lacking on the reassembly steps… shame..
thomasjmaclean - 回复
I'm just wondering if my computer would still recognize my phone with the battery disconnected?
Sare - 回复
It appears that I haven’t properly connected the battery back up, since the hard reset didn’t work. I did my best to connect the battery before adhering it to the battery spot, but the connector doesn’t seem to “click” or otherwise confirm that it is properly positioned. The left side of the connector (closest to the battery) seemed slightly raised, which made me wonder if I had done it correctly. So I’m probably going to have to try using my last adhesive strips to lay it in better to allow for a better connection. I’m also worried that I may have damaged the connection spot. Is there anywhere on here where this is discussed? This is my second battery replacement, but first on this particular phone, which is apparently a refurbished one (and which has a slightly different looking connector cover).
Alex Kosmider - 回复
Ah, it helps to discover that it’s actually a 6S rather than a 6.
Alex Kosmider -
For those of you replacing the Digitizer you to need follow steps 13 - 19.
lowestseries - 回复
Doing a lightning connector replacement - skipped steps 13-19 as well. No problems.
cambo.robertson - 回复
Hello, Is it necessary to do step 13 to 18 if I only want to change the battery?
What does can happen if I don’t make all step?
Juan - 回复
  • 卸下前面板排线固定板上的五颗十字型螺丝。
    • 三颗1.2 mm螺丝
    • 一颗1.7 mm螺丝
    • 一颗3.1mm螺丝
  • 安装过程中错误放置螺丝会造成iPhone 主板永久性损坏。
Be careful when replacing the screws, not to accidentally put the 1.7mm screw into the center hole, where the 1.2 screw belongs. This can cause "Long Screw" damage, and render your phone unusable.
damianodessgillett - 回复
I don't have the magnetic pad but use duct tape face up in a tray. I write the step number and color of the screw on the sticky surface and let the screw stand heads up on the goo. The screw is presented for the driver when reassembling.
griffn - 回复
Can't stress enough how important it is not to mix up these screws! Using the 1.7mm screw for the lower left fixing will cause "long screw damage" and kill the backlight on the phone. I believe @damianodessgillett made the same point. Wish we could display a small warning message here to be extra careful for future fixers!
kev - 回复
I use a screw ID technique similar to griffn's; I print out the PDF version of the guide, then Scotch-tape each screw type to the guide at the step where the screw was removed. The screws are then distinguished by size and type at the point where they need to be reinstalled.
adlerpe - 回复
i am trying but only could open 2 screws and cannot open the rest of them, can you help me??
girlsrock742 - 回复
@girlsrock742 - I'm new here, but from what I've seen, questions like yours don't get answered. I have 2 suggestions:
# Be more specific about what your issue is.
# Make sure you're using the right screwdriver. (Get a magnifying glass & make sure the screwdriver fits nicely in the screwhead.) This guide is included in a guide I'm looking at, and my guide has a comment that #000 phillips is required for the battery connector bracket above, not #00 as documented. (That comment did not convey to this guide....)
Good luck!
Nate Schley - 回复
Thanks to @griffn & @adlerpe! I've updated the tools list to include the magnetic pad, and -- for us infrequent fixers -- I made a note in the intro text to describe the sort of thing you two noted here in place of the mag pad.
Also, to @damianodessgillett & @kev - I've submitted an update to the instructions to add the caution you recommend to the step. Hopefully others will avoid the pain of the Long Screw damage.
Nate Schley - 回复
It's possible to damage only a slot of flex cable ? I've opened my iPhone 6 but now front camera, speaker and the proximity sensor are not working. I've bought a new flex cabe to test it, but I have to be sure about that.
cruz.giovanni - 回复
I'm so worried I'm going insert the wrong screw. Does anyone have any suggestions to knowing how to properly tell the size of each screw? I bought a screw set and a magnetic pad but still have the same issue. Not knowing the correct placement of each screw. I'd definitely appreciate any help.
Patric - 回复
Hi Patric! We use a set of calipers to measure our screws, failing that you could use a very fine ruler. If you don't have any kind of measuring equipment, line the screws up on the magnetic mat and sort them by size there. Ideally you only have screws from this step! If you are trying to determine the size of all the screws in this guide, it's probably best to get a real ruler/caliper for the fine distinctions.
Sam Lionheart -
Do you have to remove the display to replace the battery?
Michael Aguilera - 回复
It's not absolutely necessary to remove the display, I kept my display propped up throughout the operation. Removal of the display doesn't seem to offer any particular benefit, unless you have problems with the adhesive strips.
Adam - 回复
Hi. I messed up with the screws in the cover guard sheet for the display ribbon and my iPhone 6 plus isn't turning on. Does that mean the logic board is dead or the battery ? Should I throw the phone in the garbage can ?
nzf - 回复
Did anyone even answer your question? I'm having the same issue
Sare -
I can confirm it's not necessary to remove anything other than battery bracket. If you support the screen against something as in the picture, just make sure you hold the iPhone absolutely still with one hand while pulling out the adhesive strips with the other. I also used a small piece of tape to hold the screen in place against the box while I worked.
I am now a very happy customer and am looking forward to another few years life from my awesome iPhone 6!
Matt Whiteley - 回复
There is no need to do this step. No need to remove these 5 screws. Just make sure the screen is propped up against something strong and this step is unnecessary for the proper removal and re-insertion of battery.
arunhn - 回复
I left the front panel connected and it was much quicker. But, if you have to wrestle with the battery, it is much safer with the front panel removed. If you have worked on a few phone before, I'd try removing the battery with the front panel connected. If the battery is giving you problems(like if you tear the strips and have to heat the backside), you can always come back to this step.
Joel Horie - 回复
I strongly recommend you leave the display connectors alone if you can. My battery came out without a fight, but I found the display connectors to be almost tragically delicate, and I had white lines in the display when I booted it. During the subsequent attempts to remedy that situation, things went down hill and now I'm waiting for an entirely new display to try to rescue the phone from repair oblivion.
kevin hekman - 回复
I also skipped all of the screen-removal steps and had nary a problem. Just rubber band the screen around whatever it is propped against and I believe you'll be fine.
Billy Bob Baler - 回复
Hello! I put the screws on in the wrong order and I believe my backlight is dead, iTunes still recognizes my phone when I plug it in, but the screen is blank. Is it possible to replace the logic board or is the phone useless forever?
Tanya Lyn Willard - 回复
You probably connected the cables wrong, try doing this step again and carefully correct your cables.
June Beltran -
Remove each screw, tape it to a piece of letter paper, mark what spot it came out of. red, yellow, orange and the 3 reds. This way you can not possibly put them back in the wrong spots.
smahar -
I totally recommend doing this step first before removing the battery connector bracket, it will be much easier and comfortable with the screen out of the way.
Also I recommend drawing the bracket on a piece of paper and place the screws on top of the respective position on the drawing, this way you won't be confused when putting them back.
June Beltran - 回复
I accidentally lost a 1.2mm screw while doing a screen replacement. Will this make the phone malfunction in anyway after I close it back up or its fine?
Walter White - 回复
DO NOT DO THIS STEP. It is totally unnecessary to remove the connectors, and they are a really big pain to put back in, and there is risk of damaging them, and it adds a lot of time to the process of replacing the battery. Just securely prop up the front panel, and then if you gently heat the back of the phone when removing the adhesive strips, the battery comes off easily. I could have saved myself about 2 hours and a lot of frustration if I had just left these connectors in. I wish the instructions here would just include this step (connector removal) ONLY IF the battery doesn't come out easily.
J Marr - 回复
Exactly, just like J, Marr indicates, this step is not necessary. Just make sure you're careful to not move the phone too much, otherwise you can damage the film connectors. Other than that I even heated my phone to remove the adhesive, and thank God, nothing bad happened to it.
Mc Floyd -
It’s only necessary if you’re like me an need to fix the screen or water damage (mine fell in water…)
jacobdanderson -
Ergolad - 回复
How can't you do step 33 if you don't do 13-19? iPhone 6.
predylindsay - 回复
I'm missing something here, I want to swap out the screen. How does one skip steps 13-19 if wanting to remove the screen?
BW Lee - 回复
Any tips for removing the 1.2 mm screws? Mine won't budge at all with the PH000 and I'm afraid I'm stripping the screws.
MClare - 回复
I had to use the larger bit for ALL of the screws as the small one was too narrow at the tip to actually grab anything. It worked but made it a bit more difficult.
Heather Best - 回复
Is it really necessary to remove the front panel at all, can't you just ask a friend to hold it in an upright position while you work on the battery?
Peter - 回复
I also skipped steps 13 - 19. Just be very careful not to apply to much stress to the connectors in between the screen and the base. For me I also used another box to keep the base from sliding around while removing the battery.
Patrick Reed - 回复
You cannot skip these steps, of course, when you want to replace the display (which was the kind of repair we did).
When putting the little connectors in place again afterwards, I can recommend to hold the connectors to the display using a little rubber band. That way, they don’t get in the way when you put them in place one by one.
You SHOULD do the steps of removing the display. I have done battery replacements on several dozen phones. Of the ones I did NOT remove the cables, 2 of them had issues directly related to components related to these cables (front facing camera, earpiece speaker, etc.). Although tedious, I recommend removing these connectors to prevent any short circuit when reconnecting the new battery.
ACMT - 4 years.
jonbessom - 回复
I skipped this step and just affixed the screen to the Iphone box with a rubber band during replacement. I decided to take this risk to prevent some of the other issues that have been discussed when removing the screen. I understand it is risky because if you slip or need to use any significant force to remove the battery, disaster awaits. On my repair, it worked out fine and I ensured that I took my time and kept the bottom of the phone held to the worksurface.
Michael Kirkpatrick - 回复
There are only 2 screws when i opened mine.The centre one and the left top corner one..Is it okay to use it like that..Please help
Naresh Annepu - 回复
If you can try to leave your display how it is. I removed it and it ended with white stripes and touchscreen not working. After a while it touch started to work and stripes went away. I think it was static electricity.
If you decide to go ahead with this step… I did it prior to removing the battery bracket and found it to be easier. Having the screen off made things a lot easier during the battery removal process.
Eric Craumer - 回复
Two of the screws are damaged and I can’t open them. What can I do to remove the bracket?
L He - 回复
Stay organized with the screws with just a piece of paper. Lay them out, mark ‘em up. Go slow, take your time.
Sherman Homan - 回复
I'm noticing some questions I have that others are asking yet no one is answering. You're all talking about the same problem that I find completely pointless. If you skip steps and it works, good for you move on. There are real questions being asked. Someone asked about losing a screw, would that effect anything? You all talk about the importance of having the screws organized, yet don't explain if someone either loses the screws or have them put into the wrong places. Since no one talks about it, I figured it wasn't as important as you all claim it is. Now my phone seems to not want to do anything anymore. Stop arguing with each other about something so miniscule like skipping steps. 40 comments on this part and 5 people actually have real problems but no answers. So, if anyone actually took the time to read this, my questions are; what happens if the screws are put in the wrong order?(other than the obvious long screw damage) and what happens if we put the phone back together without some screws?
Sare - 回复
@sarery I’m a little puzzled by your question. If you’re not willing to put the screws back in the right place as instructed, despite all the warnings in both the guide and the comments, why would you want to attempt this repair in the first place? But nevertheless I will try to answer. Some screws, if left out, have no noticeable effect. That’s the best you can hope for. Other screws perform a vital function such as providing a path to ground. Some screws are made of nonferrous materials—getting those mixed up can interfere with things like compass functionality. And putting a wrong screw pretty much anywhere can result in cross-threading or component damage. The reason we go to the trouble of providing all these screw markings and measurements is to help you put your phone back together in perfect working order. Which you may still be able to do, if you are careful, and patient. Good luck.
Jeff Suovanen -
Thank you very much for that information. That's all I and I believe some other people were curious about.
That's what I thought this website was for, not post fighting over who's the smarter one and not putting others down. This isn't Facebook
Sare - 回复
well said Sare - perhaps if folk stuck to the subject instead of proving how clever they are (not) there wouldn’t be 44 comments to scroll through to find an intelligent answer
philbjh - 回复
For those who are removing the digitizer, you do need to remove the bracket to get access to cable.
lowestseries - 回复
Definitely do NOT disconnect the screen for the battery replacement!
The battery replacement worked like a charm but now I am left with whit e stripes in the screen and touch screen functionality is lost despite many tries to get the screen reconnected.
Indiana Jones - 回复
Hello, well I accidentally put the screws back in the wrong order after replacing the charging port, phone turns on but stays on Apple screen, any suggestions? Thank you
d.rando90 - 回复
i have replaced my iphone 6’s screen twice now, first the phones fingerprint sensor wouldn’t work ( the original one ), so i replaced the entire screen ( new fingerprint sensor), but still doesn’t work and now the phones brightness is extremely dim on both screens. So now both screens now are dim and finger print sensors dont work.
Regan Murray - 回复
  • 从主板上取下前面板排线固定板。
添加评论
  • 在接下来的四个步骤中,使用撬棒时注意只撬排线接口,而不是接口插座。
  • 使用撬棒或手指甲断开前摄像头和传感器排线接口。
I can not get these electrical connections to reconnect. If there is some secret to this it should be noted. I now have a phone all taken apart and can not get it back together. It makes no sense to only give directions to take a phone apart and not to put it back together.
douglas hughes - 回复
Use sideways bright light and peek underneath as you mate the contacts to align properly. Press very gently and evenly. Others have written that too much pressure in the center may warp the contact.
mahoffman - 回复
I'm having the same problem as above...really upset and frustrated at this point. :( 2/4 connectors (top and right) will 'click' just fine...the other two (bottom two) for the life of me wont connect!!!! :( any suggestions? i feel like i have tried everything. Sucks that is only thing stopping me screen from being repaired....
alyssaavaldezz - 回复
Hi alyssa. Were you able to connect the cables? I am having the same problem
Veronica del Rio -
regarding cable connects - if two of the ribbon cables are not properly overlapped around each other, then it will appear as if cable #2 will need to plug into the closest jack, which is actually for cable#3. Look at the two connectors carefully - they are opposite gender and can't be interchanged.
David Panak - 回复
This is good advice, and usually the problem people experience here. There is a very specific way the ribbon cables are layered, and if not correct when reassembled, the reach of the cables will cause you to assume which cable goes where and to try to insert the wrong plugs into the wrong sockets. Please do not try to force them. If they don't snap in easily, examine them closely, and you'll see the plugs and sockets are slightly different sizes, with one wider than the other. Better to take care to note how the cables layer during disassembly, or perhaps mark them to avoid this frustration on reassembly.
gybeho -
Check order of cables. From screen replacement.
lee moran - 回复
my problem is that the connectors are different the screen i replaced it with the connectors were longer than the broken screen even though there the exact same type of screen
andrew midgett - 回复
Probably just have the cables out of order. Check the posts above.
gybeho - 回复
"gybeho" Ok, but it's impossible to install flex cables out of order. Each one has diferent sizes of docking...
cruz.giovanni - 回复
it is very possible to install flex cables out of order. to most people working on their first screen replacement they do not have the experience to notice that their flex cable connection is different than the dock connection. this causes them to press harder and force the connection into the dock, ruining the connections, if they do not think the they have the cables out of order
Dakota Navarrete - 回复
I'm with Andrew Midgett. The connectors are just plain different in size and orientation. My phone matches what's shown in the picture above. You can see an example of the replacement part if you search Amazon for "Sanka LCD Touch Screen Digitizer Frame Assembly Full Set Screen Replacement for iPhone 6". And Sanka isn't the only iPhone 6 replacement that looks like that, so no hating on that manufacturer here.
Does this mean that some iPhone 6 phones have one set of connectors and some have a different set? FWIW, the model on the back of my phone says A1549.
PG McLaughlin - 回复
Update: Searching for iPhone 6S instead of 6 on Amazon, I see lots of replacement screens with connectors that look a lot more like what I have and what's shown in the picture above. (One connector has a horizontal orientation, the other is vertical. I can't be sure whether the pins or dimensions match otherwise.) Any wisdom here?
PG McLaughlin - 回复
Had the same problem with the correct layering of cable harnesses. Perhaps an additional photo showing the correct layering would be helpful for 1st timers?
William Breen - 回复
+1 for a photo showing the correct layering and routing of cables. I accidentally routed the home button ribbon above the digitizer ribbon and beneath the power and backlight ribbons. The uneven pressure it put on the digitizer connector after tightening the plate caused my digitizer to not recognize touching the display or made touches appear off center.
drpotter -
For everybody who thinks they can skip these steps I commend you. No way I would have been able to get my battery out - two broken strips - without removing the screen. Re-inserting these cables was not really difficult - once the first one is back in place the rest follow quickly.
Chet Seidel - 回复
I tried to reconnect these for ages until I watched a video of someone else doing it.
Don’t try to line up the connectors by looking at them with the screen leaning on a soda can, just hold the two halves in each hand and line the first one up by feel. Really. After that it’s plain sailing.
Even with great lighting I couldn’t make this work with the bits on the bench - yet when I picked them up it was really easy to feel them line up. I had all four popped back on in about 60 seconds.
Pitt Monqui - 回复
  • 用撬棍或手指甲断开Home键排线接口。
Muy buenas....una pregunta tecnica...si el botón falla o no está bien conectado...al conectar este conector ¿ se apagaría el teléfono?. Repare mi iphone y al conectarlo se me apaga el movil, sin embargo si no lo enchufo el movil enciende perfectamente.
Gracias.
Berta fernandez - 回复
  • 在连接或断开这一步中的排线之前,请确保电池已经断开连接。
  • 用撬棒或手指甲断开显示排线接口。
  • 重新组装手机时,显示排线可能会从插座上松动,这回导致重开机时屏幕显示白线或者直接白屏。如果出现这种情况,只需再次装好排线并将手机电源重置一次。重置手机电源最好的方式就是将电池排线断开再装上
you missed the name of the second connctor. there are four total
copykatt - 回复
My screen is completely black and i can see the lights turning on when i press the home or lock button. Maybe this cable got damaged ?
Gabriel Hirata - 回复
Perhaps you bought a faulty screen. Often this is the case when it shows completely black.
William Mullan - 回复
When I was preforming this step, while reassembling, I had to connect the digitizer cable four times. On the last time, before screwing the Front Panel Assembly Cable Bracket on, I reconnected the battery connector and turned my phone on (ensuring that I was careful not to damage any cables!) to ensure that all cables were connected correctly and that the screen was fully functional.
Christopher - 回复
NO NO NO ! i am a professional iphone repairman and i strongly recommend against using ANY tool to disconnect the flex connectors if u slip or use to much force you will damage the connector and may cause permanent damage to the phones logic board rendering it completely UNrepairable! Instead gently use the edge of your fingernail and pry up and the connectors will usually come off with very little effort .
taylor sparks - 回复
Fingernails work great as well! However, there's nothing wrong with using a tool, as long as you exercise a little caution. If you've ever seen one of Apple's iPhone service manuals, you'll note that they use the exact same tool as iFixit (Apple calls it a "black stick" and iFixit dubs it a "spudger.")
Jeff Suovanen -
I'm pretty sure ifixit are pros, I used them 4 times to fix phones and no problems with using tools for flex cables.
Dave - 回复
If you still have white lines after you've tried reconnecting the connectors and power cycling. Just do a hard reset a few more times, let the phone stay on and wait a while. As long as it's not damaged, the lines will fade over the next hour or so. Your phone will be as good as new.
grjos - 回复
If my screen is giving me white lines and occasional ghost clicks on the right side does anyone know if it’s possibly only a faulty cable vs needing a full screen swap? I’d rather not waste a perfectly good screen.
Andrew Hill - 回复
what if my phone wont turn back on even after following all these steps carefully . i even put the old screen back on and it wont turn on still???
Daniel Murcia - 回复
what if the batery was not disconnected?
Sergio Midence - 回复
Re-connecting display data cable was trickiest part for me - my eyes are old! I had to do it a couple of times as the cable had indeed popped off its connector, resulting in a black screen when turned on. Needs lots of patience and good lighting, also helped to have a really good look at plug and socket under magnifying glass to see how they fit together, and to reconnect using finger rather than tool - this helped me feel when I had eventually connected properly.
Trish - 回复
Followed steps to a “T” - got phone up and running successfully! However, there is a vertical line in the center of the screen that changes color with whatever button is being displayed in the center screen. For example, a dead battery icon shows a red vertical line, acknowledging a blue “OK” button when setting up the phone shows a blue vertical line, etc. Essentially it’s not a black screen or white lines. Could it be that the display data connector is not correctly attached or perhaps a faulty connector?
Cyndi - 回复
  • 用撬棒的平头断开触摸层排线接头。
  • 当你要组装触摸层排线时, 请不要按压接头的中间地方。按压接头的一端, 接着再按压另一端。因为若是按压接头中间时, 有可能造成触摸层变形损坏。
Reassembly was harder than other i devices I have worked on. A bench light from the side helped a lot with the first cable, the digitizer. The others went a bit better in this crowded space. I had screen lines when testing it out before closing the top, so reinstalled all four connectors here with the aid of a side light and happily, that worked!
griffn - 回复
i crossed over the first two cables initially, when re-assembled; make sure by the WIDTH that you are trying to connect them in the right order.
awr - 回复
How many times can i peel these connections without braking the connection between screen and logic borad
falken1337 - 回复
Is this the breaking down process for the Verizon version of the iPhone 6s? I know the flex cables were different for other versions and with my last iPhone I made the mistake of ordering one that had completely different cable places. Someone please send me a link to one that fits the Verizon 4.7 display!!!
Bailey Duncan - 回复
This break down isn't for a 6S. It is for a plain 6 (no S). Yes there is some differences because of the 3D touch feature.
Keith Mullins - 回复
So what is the fix if there is digitizer damage? Replacing the screen?
After reinstallation, I am encountering issues with an area of the screen that is not responding to touch. Everything else works fine.
Anyone have any ideas how I should proceed?
Jonathan Rivera - 回复
I had the exact same problem. I tried 10-20 times and the screen had vertical lines in the middle and the touch function didn't properly work. Then I discovered the issue. I had damaged the first connector (lcd connector) when reassembling the screen.
What I did was to carefully with a tweezer press the damaged ones in to the correct position. Than I heard a solid "click" when I attached it and I got really hopeful.
I finished with the rest of the connectors and put the bracket and screws back to Place and hit the powerbutton. IT WORKED!
So, look at the first connector with a magnifying glass, the shortest one, closest to the camera. Maybe I got a little lucky when I managed to fix the connector without replacing it. Good luck. I feel your frustration all the way to Sweden.
// Simon
Simon Tengstrand -
I mean digitizer Cable= the first connector (lcd connector).
Simon Tengstrand -
I had the most issues when reassembling with this step. The plastic tool is a fail in my experience since not enough pressure could be applied using it. I just ended up using my finger and that worked 10Xs better. My advice, watch a few YouTube videos of people reconnecting the connectors and you'll be fine.
grjos - 回复
I have dis-connected and reconnected several times with the white line appearing each time. The screen however seems to be responsive. I did lose a 1.2 mm screw. Is it the missing screw or did I damage the digitizer connection?
Charlotte - 回复
I finished with the rest of the connectors and put the bracket and screws back to place and hit the powerbutton. IT WORKED!
I had three screws left when I did some repairs on my iphone 4 and that didn't matter. It worked like a charm :)
// Simon
Simon Tengstrand -
Simon Tengstrand -
Be especially careful in this step or your iPhone won’t respond to your touch after reassembling.
Ume Nishikino - 回复
My home screen button is not working after reassembly, not only the Touch ID but the actual button doesn't work. I have iPhone 6S . How can I fix this? Thanks
Sissy -
I noticed that I had bent this connector. Barely. After about a dozen connect/reconnect attempts, bent it back and everything works as intended. Prior to bending it, was getting white lines and touchscreen was unresponsive. After bending and reconnecting, fired up exactly as it had prior to disassembly.
Heywoz - 回复
  • 至此,前面板可以彻底与机身分离了。
Is it not possible to start here? Just leave the screen assembly attached and only replace the home button?
Joeri Boersen - 回复
Please don’t do that. You will break your cables almost assuredly if you leave it attached to your phone trust me
Curtis Jordan Lenox - 回复
Is front camera supposed to be attached to the digitizer?
Neos Kosmos - 回复
  • 从上线缆支架上移除以下 Phillips 螺丝。
    • 一个 2.9 mm螺丝
    • 一个2.2 mm螺丝
添加评论
  • 把上线缆支架移除 。
添加评论
  • 从Wi-Fi天线上移除以下四个Phillips 螺丝。
    • 一个1.5 mm 螺丝
    • 一个1.4 mm 螺丝
    • 两个2.1 mm 螺丝
添加评论
  • 把Wi-Fi天线从iPhone上移除。
  • 注意千万不要徒手触碰金属接触点--请使用镊子或者手套。手指上的油脂可能会影响导电性。如果你触碰到任何组件,在组装之前请使用windex、异丙醇或者类似的脱脂剂清理这些组件。
Bei schlechtem WiFi-Empfang kann es genügen, die Stecker abzuziehen und wieder einzustecken, sowie die Schrauben der WiFi-Antenne eine Viertelderehung zu öffnen und wieder zu schliessen. Warum: Die Antenne kann kaum kaput gehen, meistens handet es sich um Kontaktprobleme. Wie in meinem Fall!
Silvio Zarth - 回复
结论
要重新组装你的设备,按照这篇指南的步骤逆序操作即可。
100等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Sam Lionheart
于2012年10月18日注册
327,370 信誉积分
创作了1,681篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,201篇指南
If your iphone 6 has bad wifi signal, replacing this unit alone won't fix the problem. I had to replace the cable (PN: T308S) connecting this unit to the logic board. I bought it on eBay. It came with completely differnt part number, but worked perfectly
khanhag005 - 回复
Yeah khanhag005 is right, replacing this piece alone most likely won't do anything to help your WiFi / Bluetooth.
Replace the WiFi / Bluetooth cable if your WiFi or Bluetooth isn't working or if your WiFi button in greyed out. I bought mine on eBay for less than $3 and it took me less than an hour to do using the guide iPhone 6天线Flex电缆更换
GotMac -
Referring to the Antenna Flex Cable Replacement post comment on Aug30/31 post by Andy, 85 was referencing the grey out probably can't be fixed by replacing the cable neither
wonder if anyone has the actually grey out wifi issue and know which part to order?
Walter A -
I had an issue with my iPhone with poor WiFi reception and most of the time couldn't connect to WiFi at all. If the WiFi signal from a router was strong, that was the only time I could connect. The Apple store ran their diagnostics and told me there was no fault detected and the option was to pay $429 AUD for a replacement phone so I did some fault finding myself. After reinstalling the firmware through a DFU restore and reinstalling the software to rule out both those contenders it was pretty certain it was a hardware issue.
I replaced the WiFi antenna and also the antenna flex cable while I was in there. The issue is resolved and phone is functioning perfectly. I cannot say which part solved the issue but figured it was worth changing both out at the same time. The repair guide was spot on and super easy to follow, parts supplied from iFIXIT were good quality and did the job. Overall coast was just over $50 AUD including tools and shipping. Thank you!
tooeasy - 回复
Bought the new antenna and the required tools from amazing and followed this guide to the last detail. I was successfully able to replace my antenna and solve my wifi and gps issues. Thanks a lot.
Prakhar Singh - 回复
I just bought a wifi antenna from ifixit but I don’t believe it is the wifi antenna, this looks to me like the GPS antenna so will do nothing to fix my phone. The pictures show changing the GPS antenna not the wifi, to do that you need to take out the complete mother board which is a little bit tricky. I’ll be sending mine directly back and getting the right parts from a dutch website.
Bruce Gibb - 回复
Thank you so much
omar - 回复
I changed the wifi antenna and the antenna flex cable and my wifi still wont connect. what could be the problem it’s driving me crazy
Jawand G - 回复
Hello, the wifi icon of my iPhone 6 keeps flickering, I can search and connect to a wifi network just normally, but then the phone keeps dropping the wifi connection and reconnecting to that network constantly within ca. 1 second. Does anyone have an idea what the problem could be? I´m planning to replace the wifi antenna and the flex cable… Every advice would be highly appreciated.
Martin Kulle - 回复
I used this article together with ‘https://www.ifixit.com/Guide/iPhone+6+Lo... to replace my wifi flex cable and this was an excellent guide for me as this is the first time i did something like this.
Dushani Radika - 回复
This is showing the GPS Signal Antenna being removed!!! That has nothing to do with the Wifi Antenna. In fact if you look at that last picture, step 23, right above the GPS antenna that the tweezers are grabbing onto is the WiFi Antenna. This requires a few more steps because it’s attached the other side of the board. So the whole board needs to be pulled out. I just finished doing it myself. I replaced the Wifi and GPS antenna’s as I was having issues with both and Bluetooth which seems to have fixed that also.
Seems Sam Lionheart has screwed up this iFixit Help. This is all about the GPS Antenna, NOT the Wifi antenna.
GPS Antenna
https://www.amazon.com/gp/product/B00ZK9...
Wifi Antenna
https://www.amazon.com/gp/product/B01MQQ...
These are for the iPhone 6 ONLY. You can find directions on YouTube to replace the Wifi Antenna.
JBDragon - 回复
Hey guys , I had iPhone 6 and it keep on restarting, when ever I turn on WiFi or airplane mode phone keep on restarting and at the same time phone hot heat up back side of the phone under the camera. I restore the phone and format the phone none of the thing help we. What is solution, can anyone tell me ?
Thank you
Mjahainzeb - 回复
Bilgilendirme için teşekkür ederim.Gayet başarılı ...
Muhammed AÇIKGÖZ - 回复
Super! Mein Iphone 6 hatte schlechtes Wifi, schlechtes Blutooth und extrem schwache GPS-Ortung. Ich habe die Wifi Antenne und das Antennenflexkabel getauscht. Alles funktioniert wieder. Bin begeistert! Versand war auch superschnell!
Mike - 回复
添加评论
浏览统计数据:
过去的24小时: 187
过去的7天: 1,320
过去的30天: 5,842
总计 102,325
