简介
按照本指南中的步骤,在您的iPad Air 2 中更换Home键组件(包括垫圈和电缆)。请注意,Home键与它们各自的逻辑板相匹配,所以在完成Home键更换后,指纹解锁将不再工作。
在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。 把iOpener放在微波炉中间 。
  • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 把iOpener放在微波炉中间 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
which temperature must be used for heating? Thx
fbarletta - 回复
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - 回复
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - 回复
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - 回复
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - 回复
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - 回复
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - 回复
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - 回复
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - 回复
加热iOpener三十秒
  • 加热iOpener三十秒
  • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
  • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
  • 如果出现膨胀千万不要碰iOpener。
  • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - 回复
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - 回复
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - 回复
I don't own a microwave.
mdanihy - 回复
Its again waterproof when you change iphone 7 battery?
Jon - 回复
I don't have a microwave???
Joe Blow - 回复
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - 回复
can i use just ordinary microwave???
juneseok kwon - 回复
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - 回复
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - 回复
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - 回复
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - 回复
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - 回复
把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
Will a hair dryer work for heating the glass?
Me berg - 回复
如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害您,请使用胶带来固定已经碎裂的屏幕。 给iPad 的正面整面贴上胶带。 这一步将保证在您翘起和移除显示屏时能够保持完整。
  • 如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害您,请使用胶带来固定已经碎裂的屏幕。
  • 给iPad 的正面整面贴上胶带。
    • 这一步将保证在您翘起和移除显示屏时能够保持完整。
  • 尽量根据下面的指南进行操作。但,一旦玻璃破碎,请停下拆解并使用金属撬刀撬出玻璃,避免更多的碎裂。
  • 戴上安全眼镜来保护你的眼睛。 小心操作不要损坏了LCD内屏。
接下来的几部将会需要用到iOpener来软化前面板下方的粘合剂。 当在微波炉中加热iOpener时切勿加热超过30秒。
  • 接下来的几部将会需要用到iOpener来软化前面板下方的粘合剂。 当在微波炉中加热iOpener时切勿加热超过30秒。
  • 抓住已经加热的iOpener的任意一端,将其放置在iPad的顶端。
  • 将iOpener放置至少2分钟来软化面板下方的粘合剂。
Yeah, this part took longer than written. Over 30 minutes and had to reheat the iOpenner since it got cool enough to only feel warm.
Christopher Lowder - 回复
虽然iPad看起来是一体化高度集成的,但在玻璃面板下面有许多细小的部件,避免伤害那些部件,只能加热或撬动指南内所描述到的区域。 在您按照本指南操作时,请小心下述区域。 Home键
  • 虽然iPad看起来是一体化高度集成的,但在玻璃面板下面有许多细小的部件,避免伤害那些部件,只能加热或撬动指南内所描述到的区域。
  • 在您按照本指南操作时,请小心下述区域。
    • Home键
    • 前置摄像头
    • 后置摄像头
you should be careful with the screen connector on the bottom right when opening
Elyazee Eble Altenawe - 回复
将吸盘小心的放在刚加热的一侧,前置摄像头的位置。 为了提升杠杆力,将吸盘尽可能的放置在边缘处,但不要超过显示屏边沿位置。
  • 将吸盘小心的放在刚加热的一侧,前置摄像头的位置。
    • 为了提升杠杆力,将吸盘尽可能的放置在边缘处,但不要超过显示屏边沿位置。
牢牢地提起吸盘,将前玻璃面板与后壳分离出一道小缝隙。 切勿大力拉动,这将损坏玻璃。 一旦打开一道缝隙请在缝隙处放置一个撬片。防止粘合剂将面板与后壳重新粘连。
  • 牢牢地提起吸盘,将前玻璃面板与后壳分离出一道小缝隙。
    • 切勿大力拉动,这将损坏玻璃。
  • 一旦打开一道缝隙请在缝隙处放置一个撬片。防止粘合剂将面板与后壳重新粘连。
将撬片在显示屏边缘处一直滑动到耳机孔处。 如果在滑动的时候遇到了很大的阻力,请重新加热iOpener,来进一步融化粘合剂。 小心,切勿使撬片在LCD显示屏与前面板之间滑动,这样将会永久损坏显示屏。
  • 将撬片在显示屏边缘处一直滑动到耳机孔处。
    • 如果在滑动的时候遇到了很大的阻力,请重新加热iOpener,来进一步融化粘合剂。
  • 小心,切勿使撬片在LCD显示屏与前面板之间滑动,这样将会永久损坏显示屏。
    • 法则就是,永远不要把撬片插入iPad超过1/4英寸。(约0.6cm)
I think I accidently slid my tool into the fused lcd and front panel and now the entire screen is doing weird lines and different colors and just is not natural its not even usable. I was gonna replace the battery because the batter was popping the entire front panel and lcd off of the base of the device and then when i was openingit up the rest of the way I slipped and it hit something and now its all glitchy. what should i do?? is it even worth fixing anymore? it;s too old for apple care and I already voided the warranty and displays are expensive what should I do? email me @ andrew.heidorn1@gmail.com thanks :)
Andrew Heidorn - 回复
在前置摄像头开口处插入第二块撬片。 在前置摄像头开口处插入第二块撬片。
  • 在前置摄像头开口处插入第二块撬片。
将第二块撬片一直滑动到电源键处。 将第二块撬片一直滑动到电源键处。 将第二块撬片一直滑动到电源键处。
  • 将第二块撬片一直滑动到电源键处。
在前置摄像头处插入第三片撬片。 在前置摄像头处插入第三片撬片。
  • 在前置摄像头处插入第三片撬片。
滑动右边的撬片滑过iPad右上角。 滑动右边的撬片滑过iPad右上角。 滑动右边的撬片滑过iPad右上角。
  • 滑动右边的撬片滑过iPad右上角。
滑动左边的撬片滑过iPad左上角。 滑动左边的撬片滑过iPad左上角。 滑动左边的撬片滑过iPad左上角。
  • 滑动左边的撬片滑过iPad左上角。
再次加热iOpener然后放置在iPad的右边来融化下面的粘合剂。
  • 再次加热iOpener然后放置在iPad的右边来融化下面的粘合剂。
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
滑动右边的撬片到显示屏一半的位置。 滑动右边的撬片到显示屏一半的位置。 滑动右边的撬片到显示屏一半的位置。
  • 滑动右边的撬片到显示屏一半的位置。
再次加热iOpener然后放置在iPad左边。
  • 再次加热iOpener然后放置在iPad左边。
滑动左边的撬片到显示屏一半的位置。 滑动左边的撬片到显示屏一半的位置。 滑动左边的撬片到显示屏一半的位置。
  • 滑动左边的撬片到显示屏一半的位置。
滑动右边的撬片一直到iPad底部那个角的位置。 如果有必要的话,重新加热iOpener来使得右边角位置下方的粘合剂融化。 如果有必要的话,重新加热iOpener来使得右边角位置下方的粘合剂融化。
  • 滑动右边的撬片一直到iPad底部那个角的位置。
  • 如果有必要的话,重新加热iOpener来使得右边角位置下方的粘合剂融化。
滑动左边的撬片一直到iPad底部那个角的位置。 滑动左边的撬片一直到iPad底部那个角的位置。 滑动左边的撬片一直到iPad底部那个角的位置。
  • 滑动左边的撬片一直到iPad底部那个角的位置。
使用iOpener的热量来加热iPad的底部。
  • 使用iOpener的热量来加热iPad的底部。
将右边的撬片滑过iPad的那个底角。 将右边的撬片滑过iPad的那个底角。 将右边的撬片滑过iPad的那个底角。
  • 将右边的撬片滑过iPad的那个底角。
左边做相同动作。 若果有需要的话重新加热iOpener。  小心,请勿在维修过程中过度加热iOpener。 在重新加热iOpener之前请至少等待10分钟。 若果有需要的话重新加热iOpener。  小心,请勿在维修过程中过度加热iOpener。 在重新加热iOpener之前请至少等待10分钟。
  • 左边做相同动作。
  • 若果有需要的话重新加热iOpener。 小心,请勿在维修过程中过度加热iOpener。 在重新加热iOpener之前请至少等待10分钟。
移开右侧的撬片。 移开右侧的撬片。
  • 移开右侧的撬片。
使用左边的撬片在显示屏底部滑动然后在iPad的右下角拿走它。 请十分小心的操作,切勿将撬片插入深于1/4英尺。 来避免面板伤害到面板下方的Home键和显示排线。 请十分小心的操作,切勿将撬片插入深于1/4英尺。 来避免面板伤害到面板下方的Home键和显示排线。
  • 使用左边的撬片在显示屏底部滑动然后在iPad的右下角拿走它。
  • 请十分小心的操作,切勿将撬片插入深于1/4英尺。 来避免面板伤害到面板下方的Home键和显示排线。
旋转前置摄像头那片撬片。来将面板的顶部与后壳分离。 旋转前置摄像头那片撬片。来将面板的顶部与后壳分离。 旋转前置摄像头那片撬片。来将面板的顶部与后壳分离。
  • 旋转前置摄像头那片撬片。来将面板的顶部与后壳分离。
在前置摄像头一侧继续提起。 将显示屏稍微从底部拉出,将其与后壳完全分离。 继续提起直到屏幕大致与iPad主体垂直。
  • 在前置摄像头一侧继续提起。
  • 将显示屏稍微从底部拉出,将其与后壳完全分离。
  • 继续提起直到屏幕大致与iPad主体垂直。
    • 切勿现在就移除走显示屏,它仍然与后壳连接着3条细排线。
移除单个固定电池端子与逻辑板连接的 1.8 mm Phillips螺丝。
  • 移除单个固定电池端子与逻辑板连接的 1.8 mm Phillips螺丝。
为了防止触电的风险,您可以使用一个电池撬片来切断电池的连接。 将电池撬片滑动到电池端子和逻辑板连接的下方,然后在您工作的时候就无需理会撬片。
  • 为了防止触电的风险,您可以使用一个电池撬片来切断电池的连接。
    • 将电池撬片滑动到电池端子和逻辑板连接的下方,然后在您工作的时候就无需理会撬片。
移除三个显示排线保护壳上的 1.3mm Phillips螺丝。 取下保护壳。 取下保护壳。
  • 移除三个显示排线保护壳上的 1.3mm Phillips螺丝。
  • 取下保护壳。
切断显示数据传输线与逻辑板插座上的连接。 切断显示数据传输线与逻辑板插座上的连接。
  • 切断显示数据传输线与逻辑板插座上的连接。
切断在连接线下方其余两个线缆。 切断在连接线下方其余两个线缆。 切断在连接线下方其余两个线缆。
  • 切断在连接线下方其余两个线缆。
将前面板与后壳分离。
  • 将前面板与后壳分离。
将显示屏组件倒置。 使用塑料打开工具撬起Home键后的支架。 当将支架转移到新的显示屏组件上时,请使用粘合剂将支架固定在显示屏上。
  • 将显示屏组件倒置。
  • 使用塑料打开工具撬起Home键后的支架。
  • 当将支架转移到新的显示屏组件上时,请使用粘合剂将支架固定在显示屏上。
移走Home键支架,并剥去连接其的胶带。 移走Home键支架,并剥去连接其的胶带。 移走Home键支架,并剥去连接其的胶带。
  • 移走Home键支架,并剥去连接其的胶带。
剥离覆盖在Home键ZIF连接器上的胶带。 剥离覆盖在Home键ZIF连接器上的胶带。 剥离覆盖在Home键ZIF连接器上的胶带。
  • 剥离覆盖在Home键ZIF连接器上的胶带。
使用撬棒扁平的一端来翻转Home键线缆插座上的挡板。 使用撬棒扁平的一端来翻转Home键线缆插座上的挡板。
  • 使用撬棒扁平的一端来翻转Home键线缆插座上的挡板。
断开Home键线缆。 断开Home键线缆。
  • 断开Home键线缆。
使用撬棒扁平一端来拨开Home键线缆和Touch ID 控制芯片。 使用撬棒扁平一端来拨开Home键线缆和Touch ID 控制芯片。 使用撬棒扁平一端来拨开Home键线缆和Touch ID 控制芯片。
  • 使用撬棒扁平一端来拨开Home键线缆和Touch ID 控制芯片。
撬起在角落剩余的Home键线缆。 撬起在角落剩余的Home键线缆。
  • 撬起在角落剩余的Home键线缆。
重新加热您的iOpener,将其放置在显示屏的底端,来融化Home键按钮垫圈上的粘合剂。
  • 重新加热您的iOpener,将其放置在显示屏的底端,来融化Home键按钮垫圈上的粘合剂。
    • 在进行下一步前请等待大约2分钟来软化粘合剂。
Most screens don’t come with the home button adhesive so during reassembly the residue from the home button gasket is enough but the bracket needs new glue.
Thaddeus Lee - 回复
在接下来几步中,您将要从您的iPad前面板中分离Home键垫圈。  这个垫圈十分细小,也特别容易被撕裂。 如果垫圈不能够从前面板上分离,请使用iOpener来重新加热。 使用撬棒尖端来轻轻地从显示屏上撬起Home键组件。 使用撬棒尖端来轻轻地从显示屏上撬起Home键组件。
  • 在接下来几步中,您将要从您的iPad前面板中分离Home键垫圈。 这个垫圈十分细小,也特别容易被撕裂。 如果垫圈不能够从前面板上分离,请使用iOpener来重新加热。
  • 使用撬棒尖端来轻轻地从显示屏上撬起Home键组件。
继续使用撬棒的尖端在垫圈周围撬动,直到垫圈完全与前面板分离。 继续使用撬棒的尖端在垫圈周围撬动,直到垫圈完全与前面板分离。 继续使用撬棒的尖端在垫圈周围撬动,直到垫圈完全与前面板分离。
  • 继续使用撬棒的尖端在垫圈周围撬动,直到垫圈完全与前面板分离。
移除Home键组件。 移除Home键组件。
  • 移除Home键组件。
结论
在复原设备时,请依照指南以相反的步骤将其复原。
15等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Evan Noronha
自 2015年02月05日就是会员了
108,877 信誉积分
635撰写一个指南
团队
iFixit iFixit 的会员
Community
124 名成员
4,639撰写一个指南
There is a small black plastic ring between the back of the glass and the home button gasket that no one seems to be mentioning. Do you see it? It does not appear on any of the photos. What's up with that?
Tim - 回复
Its the washer, better to transfer to new screen if the screen does not come with the washer. Without the washer the home button will work fine, just feel weird. Good luck
hatrongminh -
Changing the home button, the touch ID stills working? Or we lose this function?
Jose - 回复
As I understand it, the touch ID chip on the home button ribbon cable is paired to the logic board at the factory. Unless you put the same home button assembly back, you will lose the touch ID when a replacement home button assembly is installed. The home button will work but without touch ID
James Sturgeon - 回复
I confirm it. I had personally checked it on iPhones and now on iPads. Thanks for the answer ;)
Jose - 回复
添加评论
浏览统计数据:
过去的24小时: 19
过去的7天: 230
过去的30天: 921
总计 10,995
