简介
Xiaomi's Mi 5 handset earns some points for modularity, but scores a middling 6 for overall repairability— mainly due to an unnecessarily fussy display replacement procedure.
Reference shots
  • Reference shots
添加评论
Rear cover is lightly clipped in. Comes off super easily.
  • Rear cover is lightly clipped in. Comes off super easily.
  • Looks like we can see the battery, but need to pull off some midframe components to reach the connector.
添加评论
  • Midframe comes out no problem, although we needed to punch through two tamper-evident screws.
添加评论
  • The battery is held in with adhesive pull tabs.
    • We're used to seeing these at this point, but we love their convenience and won't get tired of them any time soon.
添加评论
  • Next out is the motherboard. It's secured by a single Phillips screw and a handful of press connectors.
    • The modular front- and rear-facing cameras come with the motherboard, but the headphone jack is soldered to the board and not going anywhere.
添加评论
  • Now we can just start picking out the stragglers:
    • Daughterboard (including cable)
    • Coin-cell vibrator
    • Ambient light sensor
    • Earpiece speaker
    • Volume buttons
      • All three buttons are on a single highly-delicate flex cable assembly that tore during removal.
  • All these components came out fairly easily—the daughterboard was secured with screws while everything else was held in by friction (and the previously-removed motherboard).
添加评论
  • The screen has no visible fasteners, so we reluctantly use a suction cup and opening pick to start prying from the front.
  • The display finally separates from the midframe, but this design is a pain:
    • The LCD is held in place exclusively with glue, so reassembling the device means purchasing new adhesive designed for this unit.
    • Even though the screen is removed from the front, the LCD and digitizer connectors are not accessible without disassembling the back side.
    • The home button is trapped between the front panel assembly and the midframe, so replacing this (commonly failing) part will require removing and re-adhering the display.
添加评论
  • The Xiaomi Mi 5 earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
    • The motherboard and battery can be replaced independently and easily.
    • Most components are modular and can be replaced independently.
    • All screws are standard Phillips screws, but removing them will void your warranty.
    • The display is difficult to replace, requiring complete disassembly and purchasing consumables.
    • The manufacturer does not provide user-accessible repair documentation.
no hay pantalla original
pantalla - 回复
hi, the problem is that there is no original screen corning gorilla glass 4 for xiaomi Mi 5
pantalla - 回复
Here you can find original parts for the Mi 5: http://www.dragon-tt.com/Products.aspx?s... , they are a bit pricey though.
Alex Gerome -
Don't you use hot air for screen disassembly?
Roberto BL - 回复
终点
26等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
135,006 信誉积分
创作了728篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,207篇指南
添加评论
浏览统计数据:
过去的24小时: 51
过去的7天: 298
过去的30天: 1,414
总计 17,121
