简介
需要升级散热?或者想要更换散热器?根据本指南来为您的Xbox One 来更换散热器。
注意:将散热器与CPU分离会将损坏上面的原有导热化合物质(散热硅脂)。 您需要将其清理干净,并更换其。 请参阅这个指南
要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
  • 要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - 回复
Stickers are illegal!?
Brandon -
Thank you so much for sharing such useful information with us.I will definitely share this with my friends on essay writing service feedback .They will surely love this.Well done!
1G���Q�
ThelmaBass - 回复
every time i finish my www.rushmyessays.co.uk i play games on the xbox. i would definitely go for the fan exchage because i think mine has started making strange noises. thank you for posting with this
CrystalVaughn - 回复
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - 回复
Wow you are going places!! very intelligent!!
billy khan - 回复
使用塑料撬棒撬起USB端口周围的塑料散热口。
  • 使用塑料撬棒撬起USB端口周围的塑料散热口。
  • 散热口是十分有弹性的,使用塑料夹固定,然后将其剥离。
great guide for Xbox users, really enjoyed reading this material here online. really happy to see how things have been better and best specially in availing papersowl reviews. Thanks to all the creators.
Tammi Sherrer - 回复
  • 在Xbox前角处有一个加强了前角的小塑料卡扣。
  • 将卡扣向后滑动并将其取出。
Do u sell that plastic tag I need it
Brandon - 回复
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
B.L. Spence - 回复
  • 在机壳后方侧面通风口处上下接缝中插入撬棒的扁平端。
  • 卡扣的力量非常大(通常第一个就是这样),需要您使用一点力气。
  • 将撬棒留在原位直至您完全打开,机壳是十分有弹性的,避免一会自己自动卡回去。
添加评论
  • 在Xbox 剩下的几个侧面中仍被几个卡扣固定。
  • 在后散热口的上下壳连接处插入撬棒,分离卡扣。
添加评论
  • 继续向后部移动,撬起卡扣。
  • 确保撬棒撬起位置的正确。 一些位置是被撬棒撬起但撬棒一拿走就会自行合上,所以保持撬棒已经撬起地方的开口不要自行合上,别让努力白费。
添加评论
  • 继续撬,滑动着撬着样效率更高。
  • 当您到达后壳边缘处时,顶壳应该可以脱落了。 如果没有,使用撬棒来环绕一圈检查,除了USB端口的位置。
添加评论
  • 从刚才您放下第一个撬棒的位置开始,尝试撬起剩下几个卡扣。
    • 使用撬棒来打来还没有释放的卡扣。
  • 切勿现在就抬起上壳,它仍通过前面板与电源线缆相连接。
    • 轻轻抬起上壳,来进入前面板。
添加评论
  • 前按钮电缆有着一个独特的ZIF连接器,请注意按照以下步骤断开连接。
  • 使用镊子将塑料保持环从连接电路板上提起。
  • 使用尖嘴端将连接器的锁定片推向电缆以解锁。
I recently took my Xbox one apart to clean it and for some reason it's on for a couple minutes then it cuts off
Ali - 回复
  • 使用镊子将线缆从电路板上的连接器中拔出。
  • 移除上面板
添加评论
  • 接下来的四步指导您如何组装,如果还要进行拆解请跳过。
  • 使用撬棒扁平的一段来松开前面板的卡扣。
  • 从顶壳上卸下前面板。
添加评论
  • 重新放置顶壳。
  • 对其卡扣,按压紧实,确保卡扣已经卡到位。
添加评论
  • 在Xbox前段支撑着前面板。
  • 使用使用镊子将电缆重新安装。
  • 使用撬棒扁平的一端来将ZIF锁向左推来锁定线缆。
添加评论
  • 将机器下边缘塑料卡扣与前面板相互锁紧。
  • 45度将前面板卡扣与机器上的卡扣卡紧。
  • 将前面板推向Xbox,就像关邮箱一样。 使劲按压,确保卡扣已经全部上紧。
添加评论
  • 小心的将扬声器线缆从前面板上分离开来。
  • 小心地拉起线缆的连接器连接器,而不是取下板子上的连接器。 这样您有可能完全将他们从电路板上弄脱落。
  • 使用撬棒扁平的一端将前面板的天线链接电缆断开。
添加评论
  • 将固定WiFi模块的两颗9.5 mm T9 Torx螺丝移除。
  • 垂直将WiFi模块从金属壳顶部的插座中提起。
  • 将WiFi天线模块放置一边。使得下方的标有C3的螺丝暴露出来。
When reassembling- put the outer ones on first to secure the port to the metal. Then putting the wi-fi board into the port will be easy
Nate Ennis - 回复
  • 从顶部金属壳上移除8颗65 mm Torx T10螺丝。
Two of the 8 were stripped even before attempting to remove….ugggh
Michael Massaro - 回复
  • 抬起,而不是移除顶部金属壳。
    • WiFi模块还仍然与主板相连。
添加评论
  • 在主板上切断WiFi模块与主板的连接。
  • 移除顶部金属壳。
添加评论
  • 在主板上移除SATA电源以及数据线缆。
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Taiji Saotome - 回复
Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
shuaib ahmd - 回复
  • 从Xbox里抬起硬盘托架,将其移除。
添加评论
  • 在主板上移除光驱电源,SATA 线缆
添加评论
  • 从Xbox中移除光驱。
添加评论
  • 将主板从底壳中提出。
添加评论
  • 移除前面板上的三颗9.5mm T9 Torx 螺丝。
添加评论
  • 将其从主板上的插座中移除。
添加评论
  • 两个黑色塑料螺丝支架,通过卡扣卡在框架上。
  • 捏住两个卡扣,将卡扣移出框架,来移除螺丝支架。
添加评论
  • 移除固定白色塑料螺丝支架到金属框上的8.3mm T9 Torx 螺丝
  • 从框架上移除白色螺丝支架。
添加评论
  • 将金属框架翻转,让风扇支撑着元件。
  • 移除底壳上的螺丝。
    • 4颗11.2mm T10 Torx 螺丝
    • 4颗 9.5mm T9 Torx 螺丝
添加评论
  • 2个小的塑料插销插在金属底壳中。一个位于USB口下面,另一个位于AC端口下面。 这些插销卡在金属外壳上,导致很难卸下主板。
  • 在金属底壳上推两个插销。
添加评论
  • 从金属底壳中抬起主板以及散热器/风扇模块
添加评论
  • 在主板上移除风扇线缆的连接。
添加评论
  • 在X固定夹具的一个角上插入一个小的平头螺丝刀。
  • 轻轻地提起螺丝刀,将X夹具的一个金属臂提起。
添加评论
  • 使用相同的方法来将剩下的金属臂提起。
  • 移除X金属夹具。
添加评论
  • 将主板与风扇/散热器分离。
  • 当您重新组装您的Xbox时请按照我们的如何涂抹散热膏指南来为CPU 重新涂抹散热膏。
添加评论
  • 风扇被四个卡扣与散热器相固定。
  • 使用塑料打开工具来撬动散热器一侧的两个卡扣。
添加评论
  • 将风扇和散热器相分离。
添加评论
结论
要来重新组装设备,请按照下面的指导的相反顺序进行。 别忘记将新的导热化合物涂抹在CPU上。 按照这个指南来学习如何涂抹散热硅脂。
9等其他人完成本指南。
特别感谢这些译者︰
100%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Andrew Optimus Goldberg
于2009年10月17日注册
387,928 信誉积分
创作了412篇指南
团队
iFixit iFixit 的会员
Community
113 名成员
创作了6,758篇指南
Can you by chance get the measurements for the heatsink such as the mounting points and height of the heatsink?
marshalljosh - 回复
Hi.I've just wondering can i put a liquid metal thermal paste i think the radiator has to be copper and that's all , pluses of the procedure that liquid metal thermal paste doesn't age, and the xbox will need only fan cleaning
Kiril Angelov - 回复
添加评论
浏览统计数据:
过去的24小时: 16
过去的7天: 98
过去的30天: 460
总计 13,848
