简介
前面板固定着许多元件:用于外部按钮的连接器,LED按钮照明,Wi-Fi天线互连连接器,扬声器连接器和IR接收器。
要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
  • 要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - 回复
Stickers are illegal!?
Brandon -
Thank you so much for sharing such useful information with us.I will definitely share this with my friends on essay writing service feedback .They will surely love this.Well done!
1G���Q�
ThelmaBass - 回复
every time i finish my www.rushmyessays.co.uk i play games on the xbox. i would definitely go for the fan exchage because i think mine has started making strange noises. thank you for posting with this
CrystalVaughn - 回复
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - 回复
使用塑料撬棒撬起USB端口周围的塑料散热口。 散热口是十分有弹性的,使用塑料夹固定,然后将其剥离。
  • 使用塑料撬棒撬起USB端口周围的塑料散热口。
  • 散热口是十分有弹性的,使用塑料夹固定,然后将其剥离。
great guide for Xbox users, really enjoyed reading this material here online. really happy to see how things have been better and best specially in availing papersowl reviews. Thanks to all the creators.
Tammi Sherrer - 回复
在Xbox前角处有一个加强了前角的小塑料卡扣。 将卡扣向后滑动并将其取出。
  • 在Xbox前角处有一个加强了前角的小塑料卡扣。
  • 将卡扣向后滑动并将其取出。
Do u sell that plastic tag I need it
Brandon - 回复
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
B.L. Spence - 回复
在机壳后方侧面通风口处上下接缝中插入撬棒的扁平端。 卡扣的力量非常大(通常第一个就是这样),需要您使用一点力气。
  • 在机壳后方侧面通风口处上下接缝中插入撬棒的扁平端。
  • 卡扣的力量非常大(通常第一个就是这样),需要您使用一点力气。
  • 将撬棒留在原位直至您完全打开,机壳是十分有弹性的,避免一会自己自动卡回去。
添加评论
在Xbox 剩下的几个侧面中仍被几个卡扣固定。 在后散热口的上下壳连接处插入撬棒,分离卡扣。
  • 在Xbox 剩下的几个侧面中仍被几个卡扣固定。
  • 在后散热口的上下壳连接处插入撬棒,分离卡扣。
添加评论
继续向后部移动,撬起卡扣。 确保撬棒撬起位置的正确。 一些位置是被撬棒撬起但撬棒一拿走就会自行合上,所以保持撬棒已经撬起地方的开口不要自行合上,别让努力白费。
  • 继续向后部移动,撬起卡扣。
  • 确保撬棒撬起位置的正确。 一些位置是被撬棒撬起但撬棒一拿走就会自行合上,所以保持撬棒已经撬起地方的开口不要自行合上,别让努力白费。
添加评论
继续撬,滑动着撬着样效率更高。 当您到达后壳边缘处时,顶壳应该可以脱落了。 如果没有,使用撬棒来环绕一圈检查,除了USB端口的位置。
  • 继续撬,滑动着撬着样效率更高。
  • 当您到达后壳边缘处时,顶壳应该可以脱落了。 如果没有,使用撬棒来环绕一圈检查,除了USB端口的位置。
添加评论
从刚才您放下第一个撬棒的位置开始,尝试撬起剩下几个卡扣。 使用撬棒来打来还没有释放的卡扣。 切勿现在就抬起上壳,它仍通过前面板与电源线缆相连接。
  • 从刚才您放下第一个撬棒的位置开始,尝试撬起剩下几个卡扣。
    • 使用撬棒来打来还没有释放的卡扣。
  • 切勿现在就抬起上壳,它仍通过前面板与电源线缆相连接。
    • 轻轻抬起上壳,来进入前面板。
添加评论
前按钮电缆有着一个独特的ZIF连接器,请注意按照以下步骤断开连接。 使用镊子将塑料保持环从连接电路板上提起。 使用尖嘴端将连接器的锁定片推向电缆以解锁。
  • 前按钮电缆有着一个独特的ZIF连接器,请注意按照以下步骤断开连接。
  • 使用镊子将塑料保持环从连接电路板上提起。
  • 使用尖嘴端将连接器的锁定片推向电缆以解锁。
添加评论
使用镊子将线缆从电路板上的连接器中拔出。 移除上面板
  • 使用镊子将线缆从电路板上的连接器中拔出。
  • 移除上面板
添加评论
接下来的四步指导您如何组装,如果还要进行拆解请跳过。 使用撬棒扁平的一段来松开前面板的卡扣。 从顶壳上卸下前面板。
  • 接下来的四步指导您如何组装,如果还要进行拆解请跳过。
  • 使用撬棒扁平的一段来松开前面板的卡扣。
  • 从顶壳上卸下前面板。
添加评论
重新放置顶壳。 对其卡扣,按压紧实,确保卡扣已经卡到位。 对其卡扣,按压紧实,确保卡扣已经卡到位。
  • 重新放置顶壳。
  • 对其卡扣,按压紧实,确保卡扣已经卡到位。
添加评论
在Xbox前段支撑着前面板。 使用使用镊子将电缆重新安装。 使用撬棒扁平的一端来将ZIF锁向左推来锁定线缆。
  • 在Xbox前段支撑着前面板。
  • 使用使用镊子将电缆重新安装。
  • 使用撬棒扁平的一端来将ZIF锁向左推来锁定线缆。
添加评论
将机器下边缘塑料卡扣与前面板相互锁紧。 45度将前面板卡扣与机器上的卡扣卡紧。 将前面板推向Xbox,就像关邮箱一样。 使劲按压,确保卡扣已经全部上紧。
  • 将机器下边缘塑料卡扣与前面板相互锁紧。
  • 45度将前面板卡扣与机器上的卡扣卡紧。
  • 将前面板推向Xbox,就像关邮箱一样。 使劲按压,确保卡扣已经全部上紧。
添加评论
小心的将扬声器线缆从前面板上分离开来。 小心地拉起线缆的连接器连接器,而不是取下板子上的连接器。 这样您有可能完全将他们从电路板上弄脱落。 使用撬棒扁平的一端将前面板的天线链接电缆断开。
  • 小心的将扬声器线缆从前面板上分离开来。
  • 小心地拉起线缆的连接器连接器,而不是取下板子上的连接器。 这样您有可能完全将他们从电路板上弄脱落。
  • 使用撬棒扁平的一端将前面板的天线链接电缆断开。
添加评论
将固定WiFi模块的两颗9.5 mm T9 Torx螺丝移除。 垂直将WiFi模块从金属壳顶部的插座中提起。 将WiFi天线模块放置一边。使得下方的标有C3的螺丝暴露出来。
  • 将固定WiFi模块的两颗9.5 mm T9 Torx螺丝移除。
  • 垂直将WiFi模块从金属壳顶部的插座中提起。
  • 将WiFi天线模块放置一边。使得下方的标有C3的螺丝暴露出来。
添加评论
从顶部金属壳上移除8颗65 mm Torx T10螺丝。
  • 从顶部金属壳上移除8颗65 mm Torx T10螺丝。
Two of the 8 were stripped even before attempting to remove….ugggh
Michael Massaro - 回复
抬起,而不是移除顶部金属壳。 WiFi模块还仍然与主板相连。
  • 抬起,而不是移除顶部金属壳。
    • WiFi模块还仍然与主板相连。
添加评论
在主板上切断WiFi模块与主板的连接。 移除顶部金属壳。
  • 在主板上切断WiFi模块与主板的连接。
  • 移除顶部金属壳。
添加评论
在主板上移除SATA电源以及数据线缆。 在主板上移除SATA电源以及数据线缆。 在主板上移除SATA电源以及数据线缆。
  • 在主板上移除SATA电源以及数据线缆。
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Taiji Saotome - 回复
从Xbox里抬起硬盘托架,将其移除。
  • 从Xbox里抬起硬盘托架,将其移除。
添加评论
在主板上移除光驱电源,SATA 线缆 在主板上移除光驱电源,SATA 线缆 在主板上移除光驱电源,SATA 线缆
  • 在主板上移除光驱电源,SATA 线缆
添加评论
从Xbox中移除光驱。
  • 从Xbox中移除光驱。
添加评论
将主板从底壳中提出。
  • 将主板从底壳中提出。
添加评论
移除前面板上的三颗9.5mm T9 Torx 螺丝。
  • 移除前面板上的三颗9.5mm T9 Torx 螺丝。
添加评论
将其从主板上的插座中移除。
  • 将其从主板上的插座中移除。
添加评论
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
12等其他人完成本指南。
特别感谢这些译者︰
100%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Andrew Optimus Goldberg
于2009年10月17日注册
371,633 信誉积分
创作了1,284篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了5,894篇指南
Hi would you know where I could get that panel from that reienforces my consol
Nelson okanee - 回复
Also my button won't work to sync a new controller what part do I get to fix that
Nelson okanee - 回复
I did all that. Put it back together, now i push my power button and it only lights up for a second then dies. The power box and source are good. What did i do wrong?
Chris Chapman - 回复
My Xbox turns on and immediately turns back off pls help
gavin moyer - 回复
添加评论
浏览统计数据:
过去的24小时: 32
过去的7天: 211
过去的30天: 968
总计 32,869
