简介
卡碟? 安装新游戏地时候出了问题,或者加载蓝光版本的空中监狱出了问题?按照本指南更换Xbox One 中的光驱。
要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
  • 要打开您的Xbox one 您必须剪开或剥下这个防拆机贴纸。 这会使您的保修失效! 拆的开心!
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - 回复
Stickers are illegal!?
Brandon -
Thank you so much for sharing such useful information with us.I will definitely share this with my friends on essay writing service feedback .They will surely love this.Well done!
1G���Q�
ThelmaBass - 回复
every time i finish my www.rushmyessays.co.uk i play games on the xbox. i would definitely go for the fan exchage because i think mine has started making strange noises. thank you for posting with this
CrystalVaughn - 回复
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - 回复
Wow you are going places!! very intelligent!!
billy khan - 回复
使用塑料撬棒撬起USB端口周围的塑料散热口。
  • 使用塑料撬棒撬起USB端口周围的塑料散热口。
  • 散热口是十分有弹性的,使用塑料夹固定,然后将其剥离。
great guide for Xbox users, really enjoyed reading this material here online. really happy to see how things have been better and best specially in availing papersowl reviews. Thanks to all the creators.
Tammi Sherrer - 回复
  • 在Xbox前角处有一个加强了前角的小塑料卡扣。
  • 将卡扣向后滑动并将其取出。
Do u sell that plastic tag I need it
Brandon - 回复
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
B.L. Spence - 回复
  • 在机壳后方侧面通风口处上下接缝中插入撬棒的扁平端。
  • 卡扣的力量非常大(通常第一个就是这样),需要您使用一点力气。
  • 将撬棒留在原位直至您完全打开,机壳是十分有弹性的,避免一会自己自动卡回去。
添加评论
  • 在Xbox 剩下的几个侧面中仍被几个卡扣固定。
  • 在后散热口的上下壳连接处插入撬棒,分离卡扣。
添加评论
  • 继续向后部移动,撬起卡扣。
  • 确保撬棒撬起位置的正确。 一些位置是被撬棒撬起但撬棒一拿走就会自行合上,所以保持撬棒已经撬起地方的开口不要自行合上,别让努力白费。
添加评论
  • 继续撬,滑动着撬着样效率更高。
  • 当您到达后壳边缘处时,顶壳应该可以脱落了。 如果没有,使用撬棒来环绕一圈检查,除了USB端口的位置。
添加评论
  • 从刚才您放下第一个撬棒的位置开始,尝试撬起剩下几个卡扣。
    • 使用撬棒来打来还没有释放的卡扣。
  • 切勿现在就抬起上壳,它仍通过前面板与电源线缆相连接。
    • 轻轻抬起上壳,来进入前面板。
添加评论
  • 前按钮电缆有着一个独特的ZIF连接器,请注意按照以下步骤断开连接。
  • 使用镊子将塑料保持环从连接电路板上提起。
  • 使用尖嘴端将连接器的锁定片推向电缆以解锁。
添加评论
  • 使用镊子将线缆从电路板上的连接器中拔出。
  • 移除上面板
添加评论
  • 接下来的四步指导您如何组装,如果还要进行拆解请跳过。
  • 使用撬棒扁平的一段来松开前面板的卡扣。
  • 从顶壳上卸下前面板。
添加评论
  • 重新放置顶壳。
  • 对其卡扣,按压紧实,确保卡扣已经卡到位。
添加评论
  • 在Xbox前段支撑着前面板。
  • 使用使用镊子将电缆重新安装。
  • 使用撬棒扁平的一端来将ZIF锁向左推来锁定线缆。
添加评论
  • 将机器下边缘塑料卡扣与前面板相互锁紧。
  • 45度将前面板卡扣与机器上的卡扣卡紧。
  • 将前面板推向Xbox,就像关邮箱一样。 使劲按压,确保卡扣已经全部上紧。
添加评论
  • 小心的将扬声器线缆从前面板上分离开来。
  • 小心地拉起线缆的连接器连接器,而不是取下板子上的连接器。 这样您有可能完全将他们从电路板上弄脱落。
  • 使用撬棒扁平的一端将前面板的天线链接电缆断开。
添加评论
  • 将固定WiFi模块的两颗9.5 mm T9 Torx螺丝移除。
  • 垂直将WiFi模块从金属壳顶部的插座中提起。
  • 将WiFi天线模块放置一边。使得下方的标有C3的螺丝暴露出来。
When reassembling- put the outer ones on first to secure the port to the metal. Then putting the wi-fi board into the port will be easy
Nate Ennis - 回复
  • 从顶部金属壳上移除8颗65 mm Torx T10螺丝。
Two of the 8 were stripped even before attempting to remove….ugggh
Michael Massaro - 回复
  • 抬起,而不是移除顶部金属壳。
    • WiFi模块还仍然与主板相连。
添加评论
  • 在主板上切断WiFi模块与主板的连接。
  • 移除顶部金属壳。
添加评论
  • 在主板上拔出光驱电源和SATA线缆。
添加评论
  • 从Xbox移除光驱组件
添加评论
  • 光驱被光驱支架上的两个卡扣固定。
  • 向外推卡扣,然后将光驱滑出。
添加评论
  • 移除电源SATA线缆。
Und es wird nicht funktionieren, falscher DVD Key
Won`t work wrong DVD Key…..
dieterste36 - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
51等其他人完成本指南。
特别感谢这些译者︰
100%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Andrew Optimus Goldberg
于2009年10月17日注册
379,498 信誉积分
创作了1,308篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,207篇指南
I torn down my one to attempt to see why it stopped reading disc, i discovered that it wasn't a spinning issue but that the disc popped back out just a bit leading to why it will not spin. Any way of fixing that?
Ryan Ninteau - 回复
there is a black bar that rolls the disc into the tray try cleaning that (you will have to fully open the disc drive)
codycggrimm -
What kind of optical drive should I use?
DZ - 回复
Once replacing the optical drive does one need to flashit/swap pcb boards. Has Microsoft stopped hard coding these.
Rick Mizell - 回复
I would like to know the answer to this as well. My xbox has a terrible time loading discs. If I use the hold method to install the disc it will eventually read it.
shaunwiegert -
Yes, you will still need the swap over the PCB. I have no idea why they didn't cover this in the repair tutorial here...
AngryLemur -
Yes you would need to swap the PCB board from the new one with the old one. This requires you to open both new and old disk drives and unsolder the old and new PCBs and resolder the old one into the new disc drive. The dont tell you that or show that probably for the same reason the dont sell the drive separate from the paired mother board (40 from Ebay for the drive vs 99 + S&H for the drive and board here).
Carl Coate -
Yes you have to swap the pcb boards over for the new drive to work
Paul Atkinson - 回复
I think the issue w/ my one is the pcb board. my little brother put something in and tried taking it out w/ a knife. Therefore, i believe the board is probably faulty. What should I do or is it unfixable now
12667 -
How do you swap the pcb boards to the new drive?
JasonZ - 回复
This whole thing could have been done without trying to remove connects from the mother board. The Wifi board connector could have been removed and put back by using the screws and not trying to pull on the connection to the mother board. Now I have on wire to try and reconnect to the interconnector.
Trent Dellinger - 回复
I am looking for step by step instructions on installing new optical drive in Xbox one, including any parts from the old drive that need to be switched over.
David - 回复
Replaced optical drive in Xbox one, will not read disk. With the recent update the Xbox gives the error code E100 00000703 80910008. After some research it appears the Xbox one is bricked now. The console will not update or perform a factory reset. Is my Xbox One done for good? Can someone help?!?!
Marissa Murley - 回复
You need to put your old drive back in to take the update, the drives are hard coded/matched to the console. Once you've done that you'll need to swap the control PCB from your old drive to the new one and everything will work fine from then on. Of course you could just swap the PCB now and then take the update.
Simon Eller -
What is a PCB and how do I swap that? I just ordered a replacement drive and it had a letter in it saying it needed to be "flashed" with my consoles security key?
Paul Rhoads -
I also need help because after replacing the optical driver with a new one, taking the control PCB from the older one (the new one didn't have the control PCB) but it doesn't read disks.
What can I do to make it work?
Cristian Pellizzari - 回复
Due to the speaker connection being so flimsy, I found it easier/safer to disconnect the speaker from the black plastic speaker holder. Push back the two rear clips with the spudger and the speaker pops off easily.
Also, I'd recommend using a metal pry bar rather than a plastic spudger to pop open the main case. The clips are so strong it permanently deformed my plastic spudger when forcing it in.
Kurt Johansen - 回复
Xbox one DVD drive model numbers
asik Bieber - 回复
so if i have OEM replacemen part can i just putt it in and it works or do i have still pair them if my replacement part and original is same
Jesse Lyytikäinen - 回复
You guys nay take in consideration get the EXACT SAME model of your optical disk reader or else it'll throw back an error.. You either get the exact same model or take the trouble of replacing the PBC boards inside those disk to prevent error (didn't known this before trying myself and found myself stuck with an incompartuble disk reader :(
skait1364 - 回复
Sounds to me like the serial numbers have also been hard coded to the motherboard and/or hard drive. Simply replacing with an "identical" BD drive won't work. The model and firmware may be the same, but the serial number is not. Microslop... Tightwads!!!
omegaman7769 -
Any ideas why or how to solve the problem of the disc not grabing it in? do i have to re-solder anything else?
Seshmaru Darknes - 回复
did you get this problem solved? i have just put everything back together and now the disc only goes in 1/4 of the way and then you can hear/see the belt slip with in the drive. Please help me!
Kray Shivers -
Did you solve this issue? if so how? i have the old board in the new drive and had the xbox all back together went to insert a disc and it went in 1/4 of the way and the the belt started slipping. Please help?!
Kray Shivers -
How do you tell if you have the correct pcb board and mother board are there matching serial numbers or something else
Paul Reyes Arellano - 回复
Awesome write up. My daughter shoved a nickel in the BD-Rom Drive. Followed the steps to get the drive out and pulled the drive apart to retrieve the rogue coin. Had a bit of difficulty with the front panel ribbon cable, it’s a pain to reattach. Anyway, thank you!
benganzel - 回复
Where to buy a new optical drive
Shahnaz Ul Rehman, M.D. - 回复
How do I flash the new drive so it will be able to read game disks?
Robert Restemayer - 回复
How do I flash the new drive so it will read game disks?
Do you have to solder
CampoKing0077 - 回复
i would defenitly say when you start having read issues with these blueray drives just spend the 30 $ by the optical laser and replace it . will brobably end up saving you 40 on a new board from what i know and ive seen the boards are still encoded together. and thanks fixit my repair was 100 % succesfull great part clean nicely packaged couldnt ask for more. tbh if you are a begginer to xbox teardowns etc the drive is not the place to start i have torn mine down and rebuilt it like 6 times swapping hhds with ssds etc and the drive was a little more complicated and delicate when you dive into it
David Prince - 回复
and to answer guy above me there is no soldering involved on an xbox if you are only replacing mechanical parts in this case from what i see from the tutorial it left out the bit of swapping a motherboard but if you are just getting the issues with the drive now refrain from taking it apart and or misplacing the drive beause more then likely the board on the blueray drive is still good wich means should just be an optical replacement not to much more difficult and you would not have to swap motherboard on main unit again thanks fixit team!
David Prince - 回复
添加评论
浏览统计数据:
过去的24小时: 66
过去的7天: 501
过去的30天: 2,296
总计 86,460
