简介
Often a wine cooler is replaced because of a noise problem. Often a $10 fix
配件
无需配件。
  • The Cuisinart - Private Reserve 16-Bottle Wine Cellar often is replaced because the cooling fan becomes noisy.
添加评论
  • The original fan has a sleeved bearing (which becomes noisy as the lubrication wears out) and you can replace this fan with a ball bearing fan for around $10
添加评论
  • The replacement 12 VDC fan may have an additional wire (yellow) but it is not needed, just splice in the red and black wires to the original connector.
添加评论
  • when you order a replacement fan. measure the diameter (usually 4x4) and the thickness, to make sure it fits under the rear cover.
添加评论
  • To access the fan - unplug the unit. Remove the rear cover with a #2 phillips screw driver. Once the cover is off you will see the fan and it is held on by 4 small screws and nuts. The electrical connector location on the circuit board is labeled "fan". Carefully unplug the connector and remove the fan.
添加评论
结论
for around $10 you have a working wine cooler
3等其他人完成本指南。
Michael Williams
于2013年12月02日注册
162 信誉积分
撰写一个指南
What direction do the fans need to blow? Into the fridge or out? I took the fans out and didn't look what way they were blowing
Steve - 回复
You want the heat to be blown out.
Michael Williams - 回复
How do I order a brushless DC fan model #9025S and from where?
thank you,
Skip M.
Skip McDowell - 回复
I had to order a replacement from the manufacturer in China. I Googled the name on the fan and found the site. I ordered 2 replacements as my cooler has 2 levels. $14 and free shipping, but it won’t be here for 2 months. You might try entering the fan specs on your search engine (brushless fan whatever volts, amps, size). I got some hits on that but the amperage was too high as I need 0.8 amps. Good luck.
Donna Brinkoetter - 回复
I had to order one from the fan manufacturer in China as Electrolux did not have any replacement parts. The name was on the fan so I was able to find the company website. I had already checked some of the appliance repair sites, but they did not have a 12 v 0.8 amp. Cost $14 for 2 fans and free shipping. The downside is that it takes 2 months for delivery.
添加评论
浏览统计数据:
过去的24小时: 10
过去的7天: 90
过去的30天: 338
总计 11,973
