配件
无需配件。
Remove nine 12mm Phillips screws from the upper back panel.
  • Remove nine 12mm Phillips screws from the upper back panel.
  • Remove three 12mm Phillips screws inset under the back panel.
  • As soon as the screws are removed, the panel will fall freely.
  • When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
添加评论
Power Cord Fastener
  • Power Cord Fastener
  • Ground
  • Motherboard
  • Heat Sink Fan
  • Heat Sink
添加评论
  • Remove two 7mm Hex Nuts.
  • Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
  • If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
添加评论
  • Remove one 12mm Phillips screw securing ground.
添加评论
  • Remove power cable from motherboard.
  • Pinch cable connector to release it from the motherboard, then pull.
添加评论
  • Your power cord is removed.
添加评论
结论
另外一个人完成了本指南。
Jeff Snyder
于2013年02月07日注册
2,605 信誉积分
创作了4篇指南
团队
iFixit iFixit 的会员
Community
107 名成员
创作了6,510篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 522
