简介
Use this guide to replace the old battery in your Sony Xperia Z3.
Heat the back cover of your Xperia Z3 to loosen the adhesive underneath. Lift up the back cover with a suction handle and put an opening pick in the gap. Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
  • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
  • Lift up the back cover with a suction handle and put an opening pick in the gap.
  • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
  • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
How hot (how many C) should the iOpener be? I think it would be safer / more accurate to heat the iOpener in an oven with accurate temperature control.
Magnus Myklebost - 回复
Careful here. The back cover cracked in two places. Once when I exerted pressure with the suction handle, and in the corner when moving the pick around the edges- even though I was very gentle. The battery was adhered firmly to the back cover.
Joseph Doyle - 回复
After the adhesive around the egdes is loosened, pull up the back cover with your suction handle. Use a tweezer to pull out two black straps that are attached to two pieces of adhesive right on the battery.
  • After the adhesive around the egdes is loosened, pull up the back cover with your suction handle.
  • Use a tweezer to pull out two black straps that are attached to two pieces of adhesive right on the battery.
添加评论
Gently pull out both of the black straps with the adhesive tabs. Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs right in between. In this case use a plastic card to pry off the back cover carefully, use heat if necessary !
  • Gently pull out both of the black straps with the adhesive tabs.
  • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs right in between. In this case use a plastic card to pry off the back cover carefully, use heat if necessary !
添加评论
After pulling out the adhesive tabs, you can lift the back cover  and remove it. After pulling out the adhesive tabs, you can lift the back cover  and remove it.
  • After pulling out the adhesive tabs, you can lift the back cover and remove it.
添加评论
Unplug the battery flex connector. Use a tweezer to gently pull off the adhesive strip on the bottom part of the battery.
  • Unplug the battery flex connector.
  • Use a tweezer to gently pull off the adhesive strip on the bottom part of the battery.
添加评论
Use a spudger on the left side of the frame to lever out the battery. Be careful with the spudger - there are cables beneath the battery!
  • Use a spudger on the left side of the frame to lever out the battery.
    • Be careful with the spudger - there are cables beneath the battery!
  • Remove the battery.
添加评论
结论
6等其他人完成本指南。
Dominik Schnabelrauch
于2016年11月23日注册
11,980 信誉积分
创作了235篇指南
团队
iFixit iFixit 的会员
Community
117 名成员
创作了5,767篇指南
En hoe krijg je ‘m dan weer goed dicht?
Tijmen Brozius - 回复
If the original tape won’t hold anymore, you could replace it with double sided adhesive tape to reseal the back cover. Take a look here:
Tesa 61395 Tape
or directly in the EU Store for shipping to the Netherlands:
https://eustore.ifixit.com/en/Tools/Cons...
Tobias Isakeit -
When I opened up my phone to replace the battery, almost everything in this guide was still correct except that now the battery is screwed in with 1.2mm star screws.
Marisha Parker - 回复
Once replaced do i need to recalibrate the phone to show charge level correctly or should this happen automatically? As phone seems to discharge to 8% then stay there for a couple of hours?
Craig - 回复
添加评论
浏览统计数据:
过去的24小时: 30
过去的7天: 211
过去的30天: 1,009
总计 11,939
