简介
Replacing a button is one of the most common clothing repairs. Fortunately, it's also one of the easiest. This guide will show you how to reattach a standard four-hole button with a needle and thread. In this guide we're using contrasting thread for visibility, but when it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
工具
无需工具。
配件
Locate the area where the button has gone missing.
  • Locate the area where the button has gone missing.
添加评论
Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk. Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
  • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
添加评论
Get a length of thread—about an arms-length should be more than enough. Thread a needle.
  • Get a length of thread—about an arms-length should be more than enough.
  • Thread a needle.
You can use common cotton thread found in most basic sewing kits, but for a stronger, more durable repair you might consider "button thread". It is a cotton-blend thread that is a bit thicker and stronger due to the polyester content.
It can be found in any good craft or fabric shop and is only about 50 cents more than the average spool of common thread.
Matt - 回复
Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle. Tie the loose ends of the thread together. Tie the loose ends of the thread together.
  • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
  • Tie the loose ends of the thread together.
添加评论
Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric. Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
  • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
添加评论
Poke the needle up through the chalk mark  from the underside of the fabric. Pull the thread taut, until the knot catches the backside of the fabric. Pull the thread taut, until the knot catches the backside of the fabric.
  • Poke the needle up through the chalk mark from the underside of the fabric.
  • Pull the thread taut, until the knot catches the backside of the fabric.
添加评论
Thread the needle through one hole of the button. You can pick any hole to start with. Let the button drop all the way down onto the fabric.
  • Thread the needle through one hole of the button. You can pick any hole to start with.
  • Let the button drop all the way down onto the fabric.
添加评论
Push the needle through the buttonhole directly opposite the one you have already threaded. Be sure to go through only the button, not the fabric. Be sure to go through only the button, not the fabric.
  • Push the needle through the buttonhole directly opposite the one you have already threaded.
  • Be sure to go through only the button, not the fabric.
添加评论
Push the needle back through the fabric directly next to where you initially pushed the needle up. Pull the thread taut, until the button lays flat on the fabric. Pull the thread taut, until the button lays flat on the fabric.
  • Push the needle back through the fabric directly next to where you initially pushed the needle up.
  • Pull the thread taut, until the button lays flat on the fabric.
添加评论
Push the needle back up through the backside of the fabric, directly next to the original knot Work the needle up through one of the two remaining holes without thread . Pull the thread taut.
  • Push the needle back up through the backside of the fabric, directly next to the original knot
  • Work the needle up through one of the two remaining holes without thread .
  • Pull the thread taut.
添加评论
Go back through the last remaining empty hole on the button. Be sure to go through only the button, not the fabric. Go back down through the fabric, as close as possible to the other two threads.
  • Go back through the last remaining empty hole on the button.
  • Go back down through the fabric, as close as possible to the other two threads.
添加评论
Drive the needle back up through the underside of the fabric and into the first hole that you threaded. Pull the thread taut. Pull the thread taut.
  • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
添加评论
Go back down through the second hole, directly across from the hole you just came up through. Pull taut.
  • Go back down through the second hole, directly across from the hole you just came up through.
  • Pull taut.
添加评论
Push the needle up through the third hole again. Pull it taut. Push the needle down through the fourth hole and pull it taut.
  • Push the needle up through the third hole again.
  • Pull it taut.
  • Push the needle down through the fourth hole and pull it taut.
  • Repeat steps 12-14 of this guide one more time, then proceed.
添加评论
You have sewn in the button. Now you need a knot to keep the button in place. Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric. Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
  • You have sewn in the button. Now you need a knot to keep the button in place.
  • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
添加评论
Leave some slack in the thread and draw the needle through the loop created by the slack. Pull the thread taut, forming a knot.
  • Leave some slack in the thread and draw the needle through the loop created by the slack.
  • Pull the thread taut, forming a knot.
  • Repeat steps 15 and 16 one more time to add a second knot.
添加评论
Clip the excess thread off. Check your button for stability.
  • Clip the excess thread off.
  • Check your button for stability.
添加评论
终点
33等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
78,597 信誉积分
创作了433篇指南
团队
iFixit iFixit 的会员
Community
113 名成员
创作了6,002篇指南
What helps after the last step 14 is to wrap the thread around and around a few times underneath the button itself (binding all the threads together) and making one last pass through the cloth before the final knot. This makes the repair much more durable.
mccreerydennis - 回复
The wrapping below the button is not only more durable, but is actually frequently used when replacing buttons on blazers, sport coats, and the like as a protection from friction as the garment moves and shifts while being worn.
Matt - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 56
过去的30天: 181
总计 8,374
