Introduction
Use this guide to replace the rear case on your Samsung Galaxy Tab 8.9.
Parts
No parts required.
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Slide the second plastic opening tool along the edge of the device to separate the back cover.
  • Slide the second plastic opening tool along the edge of the device to separate the back cover.
Using your hands, remove the back cover.
  • Using your hands, remove the back cover.
4 other people completed this guide.
Daniel Stegenga
133 Reputation
1 Guide authored
USF Tampa, Team 11-4, Blackwell Fall 2014 Member of USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 982
