简介
在某个厂商在发布8th产品后跨代发布了X之时,三星保持其强势并向我们展示了Samsung Galaxy S9+。只有通过拆解才能让我们知道这是一款真正的竞争者,还是说这只是一款带有奇异AR表情的机器而已。
我们同样有Samsung Galaxy S9的拆解视频,来看一看吧!
对于iFixit来说,除了拆解之外我们还有更多的内容!请关注我们的Facebook, Twitter, and Instagram去了解这部手机的全部的最新状态吧!
这个拆解是不是维修指南。 要维修你的的Samsung Galaxy S9 Plus,请使用我们的服务手册
以下向你展示S9+的各项配置 6.2英寸无刘海屏,分辨率2960X1440(~530 ppi)
  • 以下向你展示S9+的各项配置
    • 6.2英寸无刘海屏,分辨率2960X1440(~530 ppi)
    • 高通骁龙 845处理器(部分地区配备三星自制猎户座 9810处理器)
    • 12MP OIS双光圈后置主摄像头(可在f/1.5与f/2.4之间切换),附加一颗12MP OIS辅助相机以及一颗8MP前置摄像头
    • 耳机接口与MicroSD卡槽
    • IP68级别防水防尘
    • Android 8.0 奥利奥
添加评论
机身顶部,我们看到了SIM卡卡槽,以及重新排布的相机与指纹识别区,终于能告别了易花的摄像头了 机身底部同S8并没有过多的区别,这就代表了3.5mm耳机接口依旧活在这台机器上
  • 机身顶部,我们看到了SIM卡卡槽,以及重新排布的相机与指纹识别区,终于能告别了易花的摄像头
  • 机身底部同S8并没有过多的区别,这就代表了3.5mm耳机接口依旧活在这台机器上
  • 第一眼看过去,扬声器格栅似乎被替换成了一个开口,实际上它还是一个格栅式设计,只不过格栅被折叠进了内部,或许你能用棉花塞住这个扬声器孔
    • 三星好像觉得拿取出SIM卡的那个孔来冒充麦克风孔还不够,现在又多了个冒充的充电接口
It's likely that the deeper speaker cavity helps with low-end part of the audio output as it was designed to do. The top speaker is designed to be more of a tweeter, handling mids and highs.
Akram Ali - 回复
Or maybe it’s a lint trap!!!! No reason and no effect to have the mesh near the outside edge. It wouldn’t change the sound at all.
JBDragon - 回复
I haven’t had any problems with lint on my iPhone lightning port or USB-C port… I think you’re just nit-picking. Also aren’t you on the Verge forums? You have debates about iPhone X and Samsung…
djlobb01 - 回复
“SIM-eject-impersonating microphone hole topside” … what happens if an owner mistakenly uses the Sim eject push pin tool in this hole? I did, and felt something give, but havent noticed any problems yet.
Oopsy - 回复
I too accidentally made this mistake out of excitement. No noticeable problems at the moment, but I have no idea how to test a secondary microphone.
Brad Maloy -
It’s likely that you just bumped a rubber seal in that aperture, you probably won’t notice microphone performance changes (it’s mostly in charge of hearing ambient noise). There’s a chance you might have reduced waterproofing. It depends on how tough a poke you gave it, but you’re probably fairly safe =)
Sam Lionheart - 回复
Is anyone else bothered that the speaker, charging port, and headphone jack aren’t lined up straight?
Zach Heaton - 回复
I too made the same mistake of poking a pin into the mic hole. I pushed with enough force tat you would think it needed to eject a sin tray. I didn’t notice any give or sounds when I poked it. No noticeable damage or sound issues, just paranoid that a year down the road it’s going to have issues. (Anxiety) I can’t tell enough from the pics to see what lines up with the hole .
I feel like such a dummy
Jake Reily - 回复
I alo poked the sim eject tool into the hole. I assumed it was either the sim tray or a similar setup for the micro SD card. I’ve had the phone for less than a day and I’m already worried that I’ve damaged it. Unlike other people who feel stupid for doing this, I’m annoyed at Samsung. If you design a car with something that looks like a steering wheel but is actually a wheel release handle, you are inevitably going to get lots of wheels falling of cars. Holes like this have been used for decades to reset electronic equipment, replace SIMs and eject CD drives etc - they have become a standard visual cue that all the highly paid designers at Samsung surely understand. At the very least, the design flaw should have been spotted after shipping and the phones should ship with a yellow hard to remove warning sticker telling people not to poke that hole. I’m almost hoping that the phone doesn’t work properly and that I can return it soon under warranty, rather than worry about it for the next few years.
yehudaharmor - 回复
值得我们去称赞的是,在冒出众多iPhone刘海屏模仿者时,三星还能保留着她漂亮的全视曲面非刘海屏 左边的S9+以及右边的少边框的iPhone X
  • 值得我们去称赞的是,在冒出众多iPhone刘海屏模仿者时,三星还能保留着她漂亮的全视曲面非刘海屏
    • 左边的S9+以及右边的少边框的iPhone X
  • 机身的背面,iPhone X突出的摄像头可能造成一定的损伤,但S9+的传感器布局则看起来略显庞大与尴尬
    • 由于无线充电的普及,玻璃后盖的设计迅速成为了行业标准。然而这种设计的特点就是,对手滑的人不太友好。
    • 当然,iPhone 4S的玻璃后盖您只需两分钟就可以更换完毕。而这里可就不一样了。(坏笑)
More “sprawling and awkward looking"… Really? You ooze fanboy so hard it's sad; best you'd literally do deplorable things for a chance at an exclusive, prototype iPhone --sheep.
You're Amateurs - 回复
So you are saying that the galaxy s9 plus looks perfect on the back and not at all needing a little diesign tweak? I personally also think that it doen’t look that great
Zach Heaton -
The iPhone has the Notch, but you see, there’s BONUS screen on the left and right side of it. Which is wasted space on the Samesung phone, Plus there’s another Black Bar on the bottom of the phone which the iPhone doesn’t have at all. No notch, no nothing. Glass on back was something Apple did long ago on the iPhone 4 and 4S!!! To have FAKE wireless charging, you need to use a non-conductive back. Glass works great for this. Or you go and use Plastic, which I don’t think Apple would use on a high end phone and Samesung has also moved away from on their high end phones. Maybe Ceramic is a option, but more costly. TheiPhone 6 that I have is very slippery and it’s not a glass back. I installed a bulky case to keep it from slipping from my hand.
JBDragon - 回复
What exactly is “fake wireless charging?” Go look at how induction charging works and how you don’t need to plug in your phone.
Calvin H -
I think he just means inductive charging in general. The term “wireless charging” as applied to current tech is kind of a misnomer since it’s only wireless in a trivial sense—imagine if someone sold you a “wireless router” but you had to physically place your computer on top of it to get a signal. If true long-range wireless charging ever becomes widely available, today’s “wireless charging” may seem like a lot of silly marketing hype in hindsight.
Jeff Suovanen -
(In Mr Burns voice) Samesung ey?
Seriously though, why are you even here??? LOL
djlobb01 -
在深入内部之前,我们找到了我们的老朋友Creative Electron来点高能(X光)侦测。 除开例如后置双摄之类的小部件,看起来非常像上次我们看到的那样。
  • 在深入内部之前,我们找到了我们的老朋友Creative Electron来点高能(X光)侦测。
  • 除开例如后置双摄之类的小部件,看起来非常像上次我们看到的那样。
    • 事实上,主板环绕在电池周围布局在最近的手机上还是挺常见 的,但有一个例外
添加评论
虽然她不如S4一般,但S9给在近来众多破坏性拆解后的我们一丝欣慰 标准的加热、撬动操作让我们得以进入这个三明治中——我们绝对不是在野餐! 得益于先前的经验(别去感谢三星)我们得以在不损坏电缆的情况下拆入内部
  • 虽然她不如S4一般,但S9给在近来众多破坏性拆解后的我们一丝欣慰
  • 标准的加热、撬动操作让我们得以进入这个三明治中——我们绝对不是在野餐!
  • 得益于先前的经验(别去感谢三星)我们得以在不损坏电缆的情况下拆入内部
添加评论
在危险的操作之后,我们用我们的方式进入了机器内部 我们笔直地去找后置摄像头,这颗充满新花样的双摄 这颗摄像头会在低光环境下自动切换到f/1.5光圈(目前手机摄像头的最大光圈),在适宜环境下则会切换到f/2.4
  • 在危险的操作之后,我们用我们的方式进入了机器内部
  • 我们笔直地去找后置摄像头,这颗充满新花样的双摄
    • 这颗摄像头会在低光环境下自动切换到f/1.5光圈(目前手机摄像头的最大光圈),在适宜环境下则会切换到f/2.4
  • 正常情况下,会使用至少五片的光圈叶片,以便使得光圈能更近似于圆形,但S9上仅用了两个环状刀片形的光圈,仅用于单一性调整
I wonder how well the 2 rotating ring blades will hold up over time? It is a moving part on a device that gets a lot of abuse. Far more in general than a Camera From what I’ve heard, it’s more hype than anything on this phone. As in it doesn’t do a whole lot. Will that become a new thing on other phones, or will it go away as a failed experiment? Who knows at this time.
JBDragon - 回复
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
重新排布的指纹识别器成为了我们的第一位受害者,我们将其从它舒适的家中翘出,一圈的胶水让其乖乖地待在那,并且不会让你手指上的液体侵入 我们有点失望,三星并没有使用更好的方式来布局指纹传感器的排线,在我们拆解时,它沾到一部分胶水,差点让我们为这一个传感器买单,明年你会如何处理呢?三星? 在卸下15颗螺丝后,我们拆出了两片熟悉的中框板,集成了无线充电模块、天线模块以及底部的扬声器
  • 重新排布的指纹识别器成为了我们的第一位受害者,我们将其从它舒适的家中翘出,一圈的胶水让其乖乖地待在那,并且不会让你手指上的液体侵入
  • 我们有点失望,三星并没有使用更好的方式来布局指纹传感器的排线,在我们拆解时,它沾到一部分胶水,差点让我们为这一个传感器买单,明年你会如何处理呢?三星?
  • 在卸下15颗螺丝后,我们拆出了两片熟悉的中框板,集成了无线充电模块、天线模块以及底部的扬声器
添加评论
  • 为了拆除Galaxy的电池,你需要怎么操作呢
    • 方案一:加热、死命地翘,一瓶灭火器、一桶沙子以及神一般的操作
    • 方案二:一个装有一点点 iFixit 胶水去除液的注射器。
  • 我们选择方案二,将蓝色的针头滴入电池背部,几分钟后我们便将其拆出了
  • 这是一块3.85V,容量3500mAh的电池,提供最高13.48Wh能量,是不是有点熟悉?
    • 没错,这和我们在去年的S8+以及“出了名”的Note 7的电池是一样的
  • 顺便一提,三星很喜欢在电池上贴着这种黑色网状结构的贴纸,我们并不清楚这有什么用,如果你知道,麻烦给我们留言
The sticky black webbing is surely something to drive the heat away from the battery, no?
Gimi - 回复
Option 1: lots of heat, a pry tool, a fire extinguisher, a bucket of sand, and nerves of steel vibranium. “
most likely what I would end up doing.
Aiden Baker - 回复
The black sponge tape over the battery is to allow for the miniscule amount of battery expansion that is 100% normal to every aging li-po battery and to not cause damage to the backglass when it eventually needs that space. Case closed.
Is that stuff even needed? The battery is glued down so well it’s going no where. So a little gap to allow for expansion shouldn’t hurt things that you need that mat. Who knows, and does it matter?
JBDragon - 回复
It's precision engineering, so yes it matters. If you drop your phone the small gap doesn't transfer energy as pushing the battery against the plastic frame does; as lipo(s) expand the high density foam gives way for that expanded space. It's likely on a nano-meter scale, but precision engineered as I said. Such engineering allows for cohesive standards and ability to reverse engineer in the wake of something as large as the Note 7 issue…
You're Amateurs -
Is the black webbing conductive?
michael munroe - 回复
Can you get the adhesive remover in Australia? I would like to give it a shot
James Turner - 回复
Just Use Alcohol or even Orange (not the orange you eat) find it at supermarkets if you can wait a few minutes. I’m inpatient De-Solv-it
Highly effective solvent-based cleaner
Natural citrus base
Safe to use - Not Class 3 Flammable
No overwhelming vapours
Australian made
Used to be sold at Coles now I only find it at Bunnings
Paul Zacharis -
Every other phone has pull tabs for the battery. I guess Samsung didn’t get the memo. Looks like I’ll have to invest in this syringe as I plan on having this phone for years to come.
Psedog - 回复
Maybe it helps the robot to recognize the boundary of the lipo battery. Samsung may use different suppliers as was the case on note 7
ooisk44 - 回复
Samsung engineer: “We do not know how, but the black sticker prevents battery explosion. So we just left it here. Magic.”
Евгений Фирсов - 回复
avec juste un sesamo et un peu de chaleur je vous retire la batterie en 2 min sans la tordre ni la boursouffler et l’ecran reste intacte idem pour le cache batterie .
mercy yoann - 回复
我们马上就能拆出我们的主板了,只要我们将两颗螺丝卸下并断开一堆排线就行了 没人能想到会有将显示屏排线穿过机身狭缝再连接至主板的设计,感觉好像我们一拉就会坏的样子 除了你以外应该没有了吧,总览近年来的 Galaxy设备来说,你应该是第一人了
  • 我们马上就能拆出我们的主板了,只要我们将两颗螺丝卸下并断开一堆排线就行了
  • 没人能想到会有将显示屏排线穿过机身狭缝再连接至主板的设计,感觉好像我们一拉就会坏的样子
    • 除了你以外应该没有了吧,总览近年来的 Galaxy设备来说,你应该是第一人了
    • 三星,我们知道你为什么这么做,但我们相信你有比这个更好的处理方式。现在是2018年,你应该能向我们展示一个不需要拆除背板便可拆除前面板的设备吧
  • 主板状态:解除
With a ip68 rating? You're dreaming, and your use of hyperbole is
“Glue: an adhesive substance used for sticking objects or materials together.” Pressure sensitive adhesives, like double-sided tape, are also glues, they just have a carrier =)
Sam Lionheart -
@oldturkey03
thoughts on the above comments?
George A. - 回复
@pccheese excellent comment followed by an even greater reference :-)
oldturkey03 -
尽管是个双摄设计,但这个双摄是一个整体,处于同一块PCB板上,使用着同一条排线! 算上后置的双摄,S9+一共包含了4颗摄像头,另外两颗为前置摄像头以及虹膜摄像头 但,双光圈摄像头的设计,可以说S9+一共包含了5颗摄像头,四种图像传感器,但提供五种方式进行拍摄
  • 尽管是个双摄设计,但这个双摄是一个整体,处于同一块PCB板上,使用着同一条排线!
  • 算上后置的双摄,S9+一共包含了4颗摄像头,另外两颗为前置摄像头以及虹膜摄像头
    • 但,双光圈摄像头的设计,可以说S9+一共包含了5颗摄像头,四种图像传感器,但提供五种方式进行拍摄
  • 与去年的“梦幻”相机相对于,今年的相机被称为“Star”
  • 我们在TechInsights的伙伴拆开了这个摄像头,并发现其中藏有芯片。三星声称他们在相机中集成的DRAM能让相机多获得四倍的图像数据。960FPS慢动作?
‘star’ is a device codename of S9 (starlte) and S9+ (star2lte), while ‘dream’ is the codename of S8 (dreamlte) and S8+ (dream2lte).
Daniel Simko - 回复
People leave out that the 960fps is at only 720P and it’s only for a few seconds which seems silly!!! Also way to SSLLLOOOWWW. As someone who does use Slow-Mo on my iPhone once in a while to record Industrial machines in a factory so that I can see what’s happening at a slower speed because it’s normally to fast for my eye’s to catch what’s going on, that is slow enough for my needs and I can record for a long period so that I can catch it making the mistake. Apple’s 240fps, is a really nice speed, where it’s slowed down enough to see what’s happen, and actually moving. To SSLLLOOWWW and you couldn’t see what was really happening. Besides the S9 can do the same as the iPhone now at 1080P 240fps which is really more useful anyway. What I’m seeing from a number of sites, Camera Sites for example, it’s recording for only .2 seconds and playback is 30fps for 6 seconds. Who the !&&* would use that? That is a GIMMICK. So stick with 240fps at 1080P. you have much, much longer/better recordings
JBDragon - 回复
The Slow-mo guys on youtube often record action at a fraction of a second. Enough to play it back to analyze the result. Just because 960fps is too slow for you doesn’t mean it is a gimmick. That’s very arrogant. I don’t find the iPhone 8’s wireless charging necessary but I wouldn’t call it a gimmick. I’m sure you’ll find ways to praise Apple’s version on the next iPhone. You seem to feel the need to venture onto non-Apple pages and articles to tell us how much the Samsung sucks and why it’s the same, yet make a positive spin for every Apple decision. The iPhone has largely stayed the same from the iPhone 6 up-to the 8, however because it’s Apple, it’s familiar and recognisable. Samsung re-uses the same design for the second iteration, they’re now Samesung… I don’t get it. I don’t even use a Samsung as my daily either haha.
djlobb01 - 回复
耳机接口的存在让人振奋,它的垫片保护着手机,而它的模块化设计让更换维修变得廉价方便 这块副板上集成了麦克风、USB-C接口以及大量触点,并借由电缆连接至主板上 这块副板的存在,让部分维修变得更简单更便宜,谢谢三星!
  • 耳机接口的存在让人振奋,它的垫片保护着手机,而它的模块化设计让更换维修变得廉价方便
  • 这块副板上集成了麦克风、USB-C接口以及大量触点,并借由电缆连接至主板上
    • 这块副板的存在,让部分维修变得更简单更便宜,谢谢三星!
  • 接着取出第二个扬声器,它的存在,使手机不仅能播放立体音效,还能播放环绕声(只要手机支持)
Easier as in you don't have to know how to do PCB soldering
@yuramateurs Correct; not everyone who buys this phone will have the capability to microsolder these components. So it makes replacement much easier for your average individual!
George A. -
who is microphone vendor?
염광현 - 回复
让我们看看丢在桌上的主板,A面的主要组件 三星(Samsung)K3UH6H6-NGCJ LPDDR4X 4GB运存,封装在高通骁龙(Qualcomm Snapdragon)845处理器之上
  • 让我们看看丢在桌上的主板,A面的主要组件
    • 三星(Samsung)K3UH6H6-NGCJ LPDDR4X 4GB运存,封装在高通骁龙(Qualcomm Snapdragon)845处理器之上
    • 东芝(Toshiba) THGAF4G9N4LBAIR 64GB UFS存储(NAND闪存+控制器)
    • 安华高科技(AVAGO)AFEM-9096 KM1746
    • 高通(Qualcomm)Aqstic™ WCD9341音频编解码器
    • 美信公司 (Maxim) MAX77705F 电源管理集成电路
    • 高通(Qualcomm)QET4100 包络追踪
    • 美信公司(Maxim) MAX98512 音频功放
From the SAMSUNG’s product link http://www.samsung.com/semiconductor/dra... , it is 48Gb LPDDR4x which should be 6GB capacity.
JJ Wu - 回复
Oh my GOD!!!! Samesung doesn’t make all their own parts!!!!!! Toshiba, Avago, Qualcomm, Maxim and a number of others!!!! Not that I really care. But this is something fandroids like to bash the iPhone over. The simple fact is, few company’s make their own parts. Apple does design their own parts including the CPU/GPU and other chips and even though the iPhone X OLED screen is made by Samesung, it was designed by Apple!!! That’s the point. A Smartphone is so complex, there is no way any simple company could make ALL their own parts. Samesung does make a lot of their own parts though. That’s a big advantage or them. For those factory’s to make a profit, that have to also make parts for others like Apple. To Apple’s specs. Those places generally have to run 24/7.
JBDragon - 回复
SAMSUNG makes more their own parts than Apple. The one you see here is “Qualcomm AP-based” S9+. You may check “SAMSUNG AP-based” model. SAMSUNG made their own CPU, GPU, modem, NFC, PMIC, LPDDR4x, UFS…
http://www.techinsights.com/about-techin...
JJ Wu -
Also, apple doesn't actually make their own chips, they design them and have someone else make them. Samsung does it all themselves.
George A. - 回复
B面也不能忘记: 村田KM7N16048 (Wi-Fi/蓝牙模块)
  • B面也不能忘记:
    • 村田KM7N16048 (Wi-Fi/蓝牙模块)
    • 恩智浦半导体(NXP)PN80T NFC控制器
    • 高通(Qualcomm)PM845 电源管理集成电路
    • 高通(Qualcomm)SDR845 101 射频收发器
    • Skyworks SKY78160-11 前端模组
    • 高通(Qualcomm)PM8005 电源管理集成电路
Qualcomm SDR845 RF Transceiver not modem. Modem is integrated in the processor.
JJ Wu - 回复
Labeling things as “likely" and continuing to be wrong as stated above? What a $@$* show you've done thus far. How do you have a job here? …unless… you're all amateur jokes?
Could you take picture again?. I can’t recognize the letter on chip.
CK. RYU - 回复
这里绝对是拆解过程中最温暖的地方,因为我们打算拆除显示屏,但强力的胶水正在挑战我们的耐心,我们祭出了一堆的iOpener并使用了热风枪 在过去,加热和撬片足以完成工作,但如果你是在S9上准备更换一块损坏的屏幕,这则像是一场马松竞赛 和相机的电缆一样,这条屏幕电缆也被标记上了Star,并将显示屏与触摸屏排线集成在了一起
  • 这里绝对是拆解过程中最温暖的地方,因为我们打算拆除显示屏,但强力的胶水正在挑战我们的耐心,我们祭出了一堆的iOpener并使用了热风枪
  • 在过去,加热和撬片足以完成工作,但如果你是在S9上准备更换一块损坏的屏幕,这则像是一场马松竞赛
  • 和相机的电缆一样,这条屏幕电缆也被标记上了Star,并将显示屏与触摸屏排线集成在了一起
  • 最后一颗芯片被集成在了显示屏上
    • 三星(Samsung)S6SY761X 触控控制器 (和S8系列上的一样)
Wow. That screen is now useless. What a
These phones are just getting harder to work on. The screen should be easy to replace as that gets cracked quite often. To replace the screen on one of these, I wouldn’t do it. Where would you take a Samesung phone for a screen replacement?
JBDragon - 回复
Well, I guess you'd go to your bank, and withdraw $400 to pay for it.
George A. -
The only way I've been able to remove the screen is to work from the other side.
Work some isopropyl alcohol through the battery compartment, LCD cable slot, camera mount, and headphone jack area. Flex the glass back and forth to suck the IPA in there, then heat up the aluminum frame to loosen the adhesive holding the OLED panel to the frame. Usually I start from the edge closest to the battery and buttons. As soon as there's a slight gap, work in a pry tool to break the adhesive, add a bit more IPA then heat, and work your way around to the top and bottom, then the other edge just levers off.
My rationale for starting from that side is that you're heating the adhesive holding the OLED to the frame more than you're heating the adhesive holding the glass to the OLED. It still shouldn't get too hot to handle with rubber/nitrile gloves on.
I've done this with an 80+% success rate on more than a dozen phones with only two destroyed screens, maybe three, but I wasn't trying to save that last one.
Mark H - 回复
生物特征识别的较量
  • 生物特征识别的较量
  • 左侧的选手是我们的S9+,同去年的发现相类似,S9+配备了:虹膜扫描仪、前置摄像头、红外传感器及距离传感器
  • 右侧的选手是产生留海屏的苹果,其配备的Face ID包括了:前置摄像头、红外点阵投影仪、红外相机以及泛光传感器和距离传感器
  • 部分需要组装
  • 早期的评估现实下,三星可能在没有更新硬件的情况下过于野心勃勃地加入Animoji的竞争队列
Samesung’s version seems a little creepy. Not sure who would use it. More Gimmick than anything anyway.
JBDragon - 回复
Samsung scans your eye. Apple scans your entire face. Your eye is more unique than a fingerprint or your face. I don’t see what’s so creepy about an eye scanner… they’ve been around since the 90’s, and it’s pretty hard to trick a modern one. While a face, on the other hand, could be tricked easily with a picture molded onto a dummy head or a mask.
https://en.wikipedia.org/wiki/Iris_recog...
Please stop calling Samsung a gimmick just because you personally have no use for its features.
George A. -
I would say both Animoji and AR Emoji are both gimmicks. The difference being you can actually use your avatar as a gif in many 3rd party apps similarly to Bitmoji. It is kind of creepy. However I think both are novelty. You can’t single out Samsung just because you own an iPhone X.
djlobb01 -
He's talking about the animoji not the face or retina scanning!
Richard Denton - 回复
Is it just me or the arrangement of the front facing camera and sensors differ from one phone to the other? I have my front facing camera alone on the right side of the phone and the other sensors are on the left side. Also when i checked jerryrig's teardown video on the S9, the front facing camera has another lense besides it.
Gian Marty - 回复
这就像个包裹,无论如何,让Galaxy S9+丰富你的视觉体验吧,期待着来自iFixit的更多拆解乐趣吧
  • 这就像个包裹,无论如何,让Galaxy S9+丰富你的视觉体验吧,期待着来自iFixit的更多拆解乐趣吧
  • 想成为第一个知悉拆解讯息的人吗?在我们的资讯栏留下你的联系方式。
Why a 4 if it's easily opened and fixed screen is an old one which means there is no way of saving it so removing the broken glass with the screen means just replacing everything you guys are way behind on technology
Gasper Torner - 回复
最后的想法
  • 许多组件都是模块化的且易于更换
  • 电池可以进行更换 但胶水的使用增加了不必要的困难
  • 前后面板牢牢粘住的玻璃非常容易破碎,同时让拆解维修变得困难
  • 维修屏幕在伴随着大量拆解工作的同时,还要处理这些强力的粘胶
可修复性评分
4
可修复性10分中得4分
(10是最容易修复)
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Just like the S8 being called the “Dream”, the Note 8 was called the “Great” and the S9 is called the “Star.“ So yes, there are fingerprint sensors out there called the “Dream Finger,“ “Great Finger,“ and “Star Finger.“ Weird, yet hilarious.
iliketurtuls - 回复
Actually they're not referred to as Finger anything; terrible, stupid
You're Amateurs -
Lmao, I hope you understand your referring to the ribbon and not the entire sensor; I am not at liberty to correct you, but lookup the description of a fingerprint sensor from a genuine OEM authorized reseller
You're Amateurs -
Yes, I do understand that I am referring to the ribbon, that’s why I called it a cable. It’s not a leap to assume that the cable is carrying the label for the assembly. Just like the “S9+” printed on the rear case represents the whole phone, not just the glass.
Sam Lionheart -
The sticky black webbing on the battery is most likely a thermal pad to assist with heat dissipation. An air gap, even a tiny one (microns) still acts as a poor thermal conductor.
Ashley Foxcroft - 回复
It's interesting, isn't it, that they dedicate significant internal space to that heat pipe for better thermal management. However even so, neither chip (I assume, more testing needed) catches the A11s sustained performance over time. Makes me wonder what improvement that heat pipe would show in the A11. And makes me want an actively cooled A11X clamshell….
tipoo - 回复
I’m waiting since the launch of iPhone X, I think it will beat a decent amount of i7 processors.
Abdurrahman Al Sheyyab -
Dahhhh, A11 already been beaten --follow antutu news more frequently,
You're Amateurs -
You guys did not talk about the new heart rate pulse oximeter sensor that Samsung is touting. I noted it has 4 LEDs (a pair of red and a pair of infrared?). It is definitely not the same part as the S8, which appears to be a Maxim IC. Comments?
anonymous 3038 - 回复
Probably a similar system to the Apple Watch. Except it’s red instead of green.
Liam Powell -
Hi. Hmm the wireless charger receiver does not look like it is exactly in the middle. It looks more towards the bottom part of the phone. Maybe the size is bigger? Would you please confirm the exact location and size of the wireless charging receiver coil?
Eddy - 回复
As usually the screen broke? You have to pay for the frame, hearpeace, small prarts and to pay 450$ nice
Fixmart Laboratory - 回复
My supplier only sells Samsung LCD’s with the Frames, however only accepts ones without frames for recycle. So I have frames sitting around doing nothing.
James Turner -
This is why I haven’t bought a new smartphone in over a year…. I’ll just keep taking my friends money and fix their $800.00+ phones while my $125 (new, over a year ago) ZTE Prestige keeps on doing what the $800 ones do… except the draining my wallet part.
Vincent - 回复
Hello:
So, no radio on this model either?
Thanx for another great video and teardown explanation : )
Héctor Gonçalvez - 回复
At least they made microphone easier to replace, that was the biggest problems in phones. Now give me this phone for free because all older phones from Samsung, Nokia, LG is expensive $@$* who breaks fast.
janisr545 - 回复
“While phone makers and operating system developers of dubious numeracy skip straight from eight to ten “
Funny, but Samsung actually innovated this first! They went from the Galaxy Note 5 to the Galaxy Note 7
Nick - 回复
What the auto-adjust aperture camera module size?
Ryan Wu - 回复
Pour moi ce téléphone aurait une note de 7/10
mercy yoann - 回复
I dropped and cracked the rear glass on my galaxy s9+. I don't want to take it in to sprint to have them replace it because they'll charge me a fee when I can do it myself. Does anyone know where I can buy one?
Gina - 回复
I mistakenly thought the bottom of the phone had the sim card slot. I inserted the sim tool into the small hole next to the usb c port. I think this is part of the speaker. Did I do any damage?
Dan Coogan - 回复
That’s a microphone opening.
Caleb Kan -
me too. I just did that and mic seems to work OK but idk if it works flawlessly or if the seal is broken. Why they make all this things so confusing.
Please let me know your outcome.
Andres Corona -
So what about the camera lens cover? Can that still be replaced in the same way as with the S8+? I.e.: basically just heat it up with a heat gun and snap/break it out, then put a new one in with a sticky pad… All without without having to actually open up the phone?
Obviously the lens cover is now rectangular in shape an no longer square but other than that I’m hoping it’s the same procedure as I have a brand new s9+ that already has a scratch running through the lens which is causing a lot of glare in sunny shots :(
Any news on when a replacement part like that might start hitting the store??
Thx!
Silvermane - 回复
The X-ray is my screensaver.
Rob C - 回复
Compared to other devices, it is decently modular, however I would have liked to see an easy to remove battery.
EXE167 - 回复
I suspect that the pad on the battery is for friction and vibration control. The gap between the midframe and the battery will close over time and at some point it will rub and rattle.
Kevin McMurtrie - 回复
添加评论
浏览统计数据:
过去的24小时: 293
过去的7天: 1,520
过去的30天: 8,001
总计 149,774
