简介
使用本指南来更换您的三星盖乐世 S8上破损或者坏掉的显示屏。
“注意”:这个指南指示你只需更换显示屏,同时保留原来的外框、主板和电池。但是该手机的一些替换屏幕预先安装在一个新的外框(A.K.AutoStudio)中,你需要一个非常不同的工序来处理手机内部和安装一个新的电池。在执行这个指南之前一定要确保你有正确的组件。
本指南包括移除玻璃后壳,您将需要更换后壳上的粘合剂。 如果您更换的屏幕没有带粘合剂,那您将需要使用胶带粘起来。
“如果外框损坏或弯曲”,一定要更换它,否则新的屏幕可能无法正确安装,并因为不均匀压力的而损坏。
将显示屏与外框分离的过程通常会破坏显示屏,因此,除非您打算更换显示屏,否则不要执行此指南。
在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 把iOpener放在微波炉中间 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
which temperature must be used for heating? Thx
fbarletta - 回复
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - 回复
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - 回复
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - 回复
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - 回复
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - 回复
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - 回复
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - 回复
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - 回复
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - 回复
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - 回复
加热iOpener三十秒
  • 加热iOpener三十秒
  • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
  • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
  • 如果出现膨胀千万不要碰iOpener。
  • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - 回复
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - 回复
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - 回复
I don't own a microwave.
mdanihy - 回复
Its again waterproof when you change iphone 7 battery?
Jon - 回复
I don't have a microwave???
Joe Blow - 回复
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - 回复
can i use just ordinary microwave???
juneseok kwon - 回复
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - 回复
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - 回复
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - 回复
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - 回复
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - 回复
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - 回复
30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
60 seconds in the microwave, the iOpener burst.
I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
K
Karl Marble - 回复
  • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
Will a hair dryer work for heating the glass?
Me berg - 回复
Yes, as does a heat gun.
anonymous 4602 - 回复
I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
Cobus de Beer - 回复
  • 在S8 的背面较长一端放置加热过的iOpener 大约2分钟。
    • 你有可能要多次加热iOpener以及将iOpener放置在手机上多次来加热下方的粘合剂。 按照iOpener指南来避免过度加热iOpener。
  • 在你等待粘合剂软化的时候,请移步到下一步骤来考虑一下一会从哪撬开手机。
添加评论
  • 接下来的步骤中将切割背面玻璃面板边缘下的粘合剂。
  • 后壳上的粘合剂如第一张图像所示。
  • 从手机外面看到的撬动位置如下:
    • 厚的粘合剂部分
    • 较薄粘合剂的部分
    • 为了保护指纹识别传感器,避免撬动这里。
添加评论
  • 一旦后面板摸起来热了,尽量在手机的顶部边缘放置吸盘,同时也要避免放在弯曲的地方。
    • 吸盘不会在玻璃弯曲的地方吸附的很好。
  • 提起吸盘,在后玻璃面板下插入一个撬棒,或者打开工具。
    • 由于弯曲的玻璃,你需要按照弯曲的弧度向上推撬棒,而不是径直插入到手机里。
We can't seem to get anything between the edges even after heating the back panel. Any tips?
Megan Kennington - 回复
Hi Megan, unfortunately the adhesive is super tough on this one. I’d recommend carefully continuing to apply heat, very gradually so that you don’t accidentally overheat the battery. Eventually you should be able to get a little gap with the suction handle.
Adam O'Camb -
  • 一旦工具牢牢地插入到玻璃里面后,重新加热iOpener然后将其放置在原位来软化粘合剂。
添加评论
  • 在手机的侧面向下滑动撬棒,来分离粘合剂。
  • 慢慢操作,这样撬棒尖端就不会从缝隙中滑出。如果切割工作变得困难了,请重新加热放置iOpener。
添加评论
  • 在手机剩下的边角,重复先前的加热和切割工作
  • 在你切割下一侧的时候请在先前的一侧放置一片撬片,来避免粘合剂重新粘连。
Petite erreur: le guide dit iPhone au lieu de S7 :)
Nicolas Duthilleul - 回复
Bonjour Nicolas ! Merci pour la remarque ;-) Nous l’avons prise en compte et corrigé la traduction. La prochaine fois, n’hésitez pas à corriger directement en cliquant sur le bouton Traduire en haut à droite de l’étape.
Claire Rapp -
  • 指纹传感器线缆与手机在后玻璃面板靠近主摄像头的位置连接。 这个线缆十分的短,在移除玻璃面板的时候也要断开。
  • 抬起玻璃杯时,请仔查看以确保带有蓝色连接器的橙色电缆已断开连接。
  • 使用打开工具将残留粘合剂分离,小心地打开手机。
  • 如果指纹传感器电缆看起仍处于连接,请勿继续抬起面板,在继续之前请用撬棒来断开连接。
  • 移除玻璃后面板。
For reassembly, if the fingerprint scanner is removed from the back cover: it’s much easier to place the fingerprint scanner in the small compartment on the back of the phone, connect it and then finally put the replacement back cover on. The adhesive on the inside of the back cover will get connect to the fingerprint scanner and hold it tightly.
Brian Hoffmann - 回复
  • 在更换后面板之前你需要移除手机上旧的粘合剂。
    • 在移除掉旧的粘合剂后,使用用高浓度的异丙醇(至少90%)清洁手机机身的边缘,然后再贴合上新的粘合剂。
Bonjour,
Vous parlez d’ajouter de l’adhésif, comment et où le trouve-t-on cet adhésif ?
Difficile à appliquer ?
Cordialement,
Stéphane
Steph D - 回复
Mille excuses, je viens de voir les “adhesive strips” :)
Steph D - 回复
  • 移除11颗3.7mm #000 十字螺丝。
添加评论
  • 移除NFC天线和无线充电线圈组件。
添加评论
  • 使用撬棒扁平的一端撬起电池连接插头。
  • 虽然在下一步中没有展示电池,在本指南中没有必要移走电池。仅需要断开电池就可以了。
添加评论
  • 使用撬棒扁平的一端来断开显示和数字化连接插头。
添加评论
  • 加热iOpener,将其放置在S8的长侧边上大概2分钟的时间。
    • 您有可能需要多次加热iOpener来让手机变暖。 使用iOpener指南来避免过度加热。
添加评论
  • 一旦屏幕摸起来暖和了,将加热过后的手机边缘处放置吸盘,避免放置在曲面上。
    • 如果吸盘放置在曲面上有可能不能良好吸附。
  • 提起吸盘,在显示屏组件下插入撬棒或者撬片
    • 由于是曲面屏,您需要向斜上插入而不是,与手机平行地插入撬棒。
添加评论
  • 一旦工具牢固地插入玻璃中,重新加热并将其放置在手机上来软化粘合剂。
添加评论
  • 向下滑动撬棒,来分离粘合剂。
  • 慢慢地操作,使得撬棒尖端不会从缝隙中滑出。 如果切割粘合剂变得困难,请重新加热并重新放置iOpener。
  • 屏幕的排线位于这一侧的中点下方,可能会影响切割工具的使用。
添加评论
  • 对手机剩余的三面重复上述加热和切割程序。
  • 当您继续分离下一个方向时,请在每边放置一个撬片,防止粘合剂重新密封。
    • 撬片的长边应该插入手机,以避免在屏幕上产生额外的压力。
添加评论
  • 使用撬卡来从中框撬起屏幕。
  • 检查手机的背面,并记下手机的哪一侧有显示器和数字转换器连接器。 从连接器的相对侧撬起,将连接器将作为铰链。
添加评论
  • 小心地将屏幕组件从中框提起,轻轻地将显示连接插头从中间的孔拉出。
  • 移除屏幕组件。
添加评论
  • 在安装新的屏幕之前,一定要使用镊子来将手机上残留的粘合剂移除,并且注意任何小的玻璃渣。
  • 在从外框中移除所有的胶水和玻璃痕迹之后,用90%(或更高)异丙醇和无绒布或咖啡过滤器清洁粘合区域。只向一个方向滑动,不要来回移动。
  • 如果外框是弯曲的,或者如果留下了任何胶水或玻璃残留物,新显示屏将无法正确安装,并可能被损坏。如有必要,请一定更换外框。
  • 确保新屏幕安装好的最好方法是用一片定制的双面胶。将胶带贴到屏幕背面,然后小心地通过外框和电线。对齐屏幕位置并将其按压到位。
Hi, could you tell me what the earpiece is like? The atrial speaker. I would appreciate it, I can not see how completely the piece is stuck.
Elliot - 回复
Hi @fsociety_00_dat, you can find a replacement guide for the earpiece speaker here. All that holds it on the mid frame is adhesive around the speaker grill. Step 25 in that guide has good photos of the speaker being removed and shows where the adhesive is.
Adam O'Camb - 回复
I appreciate your answer, I mean the back, not behind hehe. I mean if you have any support, is that by accident, I put my lower hand on the top of the mobile, where the earpiece. That's why I would like to know if it has not sunk or has been able to take off or not even happened at all. Thank you very much.
Elliot -
Sorry, Google Translate
Elliot - 回复
@fsociety_00_dat, the display and speaker cover are both rigid enough to protect the speaker from light pressure, and the adhesive holding the speaker is strong. The earpiece speaker is probably fine and did not move at all.
Adam O'Camb - 回复
Thank you very much, then I can rest assured that you have not moved the grids you have. In fact, this model has a bit of depth grid, like the S9. Anything that can translate here I am. Greetings and thank you
Elliot -
Replacing the glass seems to require replacing the LCD display too. I followed the instructions to a t and the display won't show anymore. Can I get some assistance on the last step of reapplying the new screen?
Gunter Herd - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
110等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Adam O'Camb
于2015年04月11日注册
34,563 信誉积分
创作了104篇指南
团队
iFixit iFixit 的会员
Community
112 名成员
创作了6,717篇指南
Did my first repair two days ago. If you've done any other samsung repairs such as S7 or S7E, this will be cake for you to do. If you have big fingers like I do, the most challenging thing will be the fingerprint scanner flex on the back glass, connecting and reconnecting.
Jason Stewart - 回复
I go about this repair a bit differently if I want to salvage the lcd. I remove the battery motherboard and sensors , and start through the opening in the frame under the battery. I drip isopropyl alcohol along the perimeter of the battery opening applying heat and work a playing card in between the LCD and the frame, loosening adhesive as I go.
Ryan Brondyke - 回复
I like the way you think.
Jason Stewart -
Great guide, very accurate. Be very careful along the right side of the device, as it is very, very easy to shear the connector flex in half. To avoid any chance of damage, I remove the board and front camera/sensor flex. It's an easy job, and saves a massive headache if any parts are damaged. Overall quite a familiar phone to work on, if you've ever done any S6's and upwards.
Harry Rowse - 回复
mine was a success….excpt the tempature logo keeps flashing…any ideas on how to fix it?
Garrett - 回复
I had this issue to, there seems to be a heat sensor connected to the wireless charging device. In one case it helped to replace the battery but in another it didn’t. Anyone else who has more experience from this?
Erik Fogelberg -
Where will i be able to buy a samung s8 glass screen only because every where i check it includes an lcd
Jonathan Ruiz - 回复
Hi Jonathan! This guide is to replace the whole screen assembly. The OLED screen is extremely thin and fragile and cannot be removed safely from the glass by the ordinary DIYer, to say nothing of the reassembly process. It makes it a bit more expensive to have a fused display but this repair isn’t possible with separated display/glass components.
Sam Lionheart -
My Samsung S8 screen is broken . I wanted to how much will it cost to replace it and how long does it take ?
Kritika Sachan - 回复
I have a cracked screen on my Galaxy S8. i called an authorized Samsung Repair location a dn was quoted $220.00 for one day service.
Walt Fletcher -
Samsung authorized repair location quoted $220.00 for screen replacement. Best Buy is $250.00. Galaxy S8 with cracked screen.
Walt Fletcher -
Just curious… why do you have to tear down to replace the screen assembly? Why can’t you start at Step 16?
LENZAQ - 回复
Because you need to perform step 15 to take the screen out, and that connector is on the back…
Dre Albulescu -
Does anyone know if i must purchase the glass replacement with the LCD for the galaxy S8? I found a glass replacement that does not include LCD and it saves me like 200 dollars. thank you
Isamar D.C - 回复
My phone responds to my touch its just cracked on the side. what type of screen do i need. Do i need one with LCD
Meranda Carty - 回复
You just need the outer glass screen, but I'm not sure if the phone need to be disassembled like in this tutorial to replace this screen. Any advice on this?
Dean Al Salem -
There’s a chance you can replace just the digitizer without removing the entire display, but since you can’t disconnect the display cable without opening the back of the phone, you’d risk tearing the display cable while working on the display. Separating the digitizer from the LCD is also an extremely difficult and risky process in itself, and isn’t recommended unless you really know what you’re doing.
Adam O'Camb -
Do you not need glue to re-seal before following the steps backwards?
mylesmchugh - 回复
When following the steps backward to reassemble the phone, you’ll first need rear cover adhesive strips, to reinstall the rear cover. Toward the end of reassembly, when you’re ready to install the display, you’ll need display adhesive strips for the long sides of the display, and Tesa tape for the short sides of the display. Unfortunately, the phone will likely not be fully waterproof after reassembly.
Adam O'Camb -
Yesterday I replaced broken LCD and the middle frame. Finally, when I tried to put cardholder into the hole it did not go. Did I forget something or do I need to do something before?
Jure Tandara - 回复
can i get in to the wather my samsung s8 after i change the glass??
Martin Freire Carrera - 回复
Why does the back of the phone have to come off to replace the screen
Glen Tracey - 回复
Hi Glen, unfortunately the display cable threads through the mid frame and connects on the back of the motherboard. To find and unplug that connector you have to open up the back of the phone before you can remove the display.
Adam O'Camb -
Boa Noite. Muito bom . Foi muito útil . Pra mim. Obrigado, por dividi seu conhecimento..
Wendell araujo - 回复
Spend an hour with a heat gun trying to insert the spudger with zero progress. Is it possible they changed the adhesive?
Josh Eaves - 回复
Unfortunately in this phone’s case it’s very much “try try again!” The seam allowances are extremely tight, and it does seem to vary between units. We definitely spend a good long while trying to gain purchase. If you don’t have the thin-profiled halberd spudger, you should be able to use the triangular opening pick, or a plastic opening tool. It may also help to use a heavy duty suction cup, or even a suction cup on each side. Also do be sure that you’re prying at an upward angle, not perpendicular to the phone. Best of luck!
Sam Lionheart -
I can’t get my digitizer to reconnect. Could the connector be broke? Any tips on how to get it to reconnect?
Ben Knight - 回复
Broken front glass on my S8. I have some spots where it seems unresponsive (by the cracks in the glass). No damage to the LCD, curious if glass only will fix or if glass and digitizer is needed?
Kevin Litvak - 回复
Technically you can replace the digitizer separately from the LCD, but it’s an extremely difficult repair requiring special tools, and you’re very likely to break the LCD in the process. Replacing the digitizer and LCD together is much safer and more reliable.
Adam O'Camb -
dopo la riparazione il telefono ( galaxy s8) perde l’impermeabilità o potrebbe riscontrare altri problemi con più facilità?
giovanni russo - 回复
Hi, I’m working through this right now and I had difficulty figuring out how to pull the back and front off, specifically how to hold the rest of the phone whilst pulling on the suction cap, I tried using one hand on the base or top and the other on the cap and managed to lift but I didn’t have enough hands to use a third one to get the bayonette in. It’s also not clear in the instructions how to accomplish this. My solution was to use my bare foot big toe side to hold the bottom whilst lifting with the suction cap on the edge middle using my middle finger on the cap and other fingers on the top of the phone and then the bayonet with my other hand, after getting it in it was easy but my solution seems a little bit insane and using my foot made me look like a complete fool.
does anyone have any adivice for an easier way to pull on the suction cap, hold the rest of the phone, and still have a hand free to slide under? is there a tool or something like a vice or clamp or something that could make this easier?
ersatzmelon - 回复
I would also like to add that as I’m replacing the screen, it’s obviously been broken, so theres alot of cracks in the glass that make the whole process for the front feel very dangerous and theres also of the screen surface thats super hard to get the suction cap to gain purchase on, I’ve been able to get it off but I’m sure that this might be an area that might need special attention, perhaps more advice for how to manage this step safer.
Also as the screen is broken, turning off the phone in order to work on it was really difficult, the s8+ I have requires you to press an on screen button to turn it off, you seemingly can’t just use the physical buttons, I had to use an educated guess about the button location and repeat pressing the side mechanical power button and then blindly proding the broken screen, adding a step that could make this easier would have saved time, if theres a way to turn it off without using the screen that would help also.
ersatzmelon -
Hi, that’s a great question. I usually have my left had on the phone, using my index finger and thumb to pull on the suction cup, and using the rest of my hand to stabilize the phone. I insert the pick or halberd spudger with my other hand. This definitely is not an easy process and I think everyone has a slightly different way to they do it. Alternatively, using an iSclack can make opening the phone way simpler if you’re having trouble with the suction cup.
If the screen’s badly cracked, I’d recommend taping over the screen with packing tape to contain any glass shards. Then you can make a handle with another piece of tape or glue the suction cup down to lift the screen. I’ve also updated the guide with information to help handle a cracked screen—thanks for bringing that up!
Adam O'Camb -
hey , so I replaced my friends s8 screen which I did before on my s8 but his phone is been acting weird it gets stuck on T-Mobile for a few mintues and then it will access the phone then dieds
Raed - 回复
i wanna replace the screen glass only am i able to do that or i should replace the entire assembly ?
amr - 回复
The glass is fused to the display, so while it may be possible for a professional to separate them with specialty tools, it’s recommended to replace the whole display assembly.
Adam O'Camb -
I manage to replace a few of the galaxy s8 screen while removing only 3 screw !! I made a small video about it. it’s not perfect but you should save at least half the time while replacing it!!!!
https://youtu.be/3Cw3imiqdj4
Jeff Gravel - 回复
I just replaced the digitizer and glass and frame. I did everything I was spose to but when I took the Battery out to put it in the new phone there was a small Crack noise from the top of the battery where the cable is. Would that cause the batery to not give power to my new screen? Or what else could cause the phone to not get any power after replacing everything?
Helena towe - 回复
添加评论
浏览统计数据:
过去的24小时: 395
过去的7天: 3,079
过去的30天: 14,484
总计 427,149
