简介
使用本指南来更换您三星盖乐世S8 上失效的电池。
本指南包括了移除玻璃后壳,你将需要重新更换粘合剂来将后壳重新与手机粘贴。
在拆解手机前,断开电源,并将电量降低至25%以下。 电池如果被以外刺穿很容易导致爆炸或者着火,如果断开电源这样的风险就会降低许多。
在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。 把iOpener放在微波炉中间 。
  • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 把iOpener放在微波炉中间 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
which temperature must be used for heating? Thx
fbarletta - 回复
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - 回复
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - 回复
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - 回复
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - 回复
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - 回复
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - 回复
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - 回复
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - 回复
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - 回复
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - 回复
加热iOpener三十秒
  • 加热iOpener三十秒
  • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
  • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
  • 如果出现膨胀千万不要碰iOpener。
  • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - 回复
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - 回复
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - 回复
I don't own a microwave.
mdanihy - 回复
Its again waterproof when you change iphone 7 battery?
Jon - 回复
I don't have a microwave???
Joe Blow - 回复
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - 回复
can i use just ordinary microwave???
juneseok kwon - 回复
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - 回复
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - 回复
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - 回复
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - 回复
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - 回复
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - 回复
把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
Will a hair dryer work for heating the glass?
Me berg - 回复
Yes, as does a heat gun.
anonymous 4602 - 回复
在S8 的背面较长一端放置加热过的iOpener 大约2分钟。
  • 在S8 的背面较长一端放置加热过的iOpener 大约2分钟。
    • 你有可能要多次加热iOpener以及将iOpener放置在手机上多次来加热下方的粘合剂。 按照iOpener指南来避免过度加热iOpener。
  • 在你等待粘合剂软化的时候,请移步到下一步骤来考虑一下一会从哪撬开手机。
添加评论
接下来的步骤中将切割背面玻璃面板边缘下的粘合剂。 后壳上的粘合剂如第一张图像所示。
  • 接下来的步骤中将切割背面玻璃面板边缘下的粘合剂。
  • 后壳上的粘合剂如第一张图像所示。
  • 从手机外面看到的撬动位置如下:
    • 厚的粘合剂部分
    • 较薄粘合剂的部分
    • 为了保护指纹识别传感器,避免撬动这里。
添加评论
一旦后面板摸起来热了,尽量在手机的顶部边缘放置吸盘,同时也要避免放在弯曲的地方。 吸盘不会在玻璃弯曲的地方吸附的很好。
  • 一旦后面板摸起来热了,尽量在手机的顶部边缘放置吸盘,同时也要避免放在弯曲的地方。
    • 吸盘不会在玻璃弯曲的地方吸附的很好。
  • 提起吸盘,在后玻璃面板下插入一个撬棒,或者打开工具。
    • 由于弯曲的玻璃,你需要按照弯曲的弧度向上推撬棒,而不是径直插入到手机里。
We can't seem to get anything between the edges even after heating the back panel. Any tips?
Megan Kennington - 回复
Hi Megan, unfortunately the adhesive is super tough on this one. I’d recommend carefully continuing to apply heat, very gradually so that you don’t accidentally overheat the battery. Eventually you should be able to get a little gap with the suction handle.
Adam O'Camb -
一旦工具牢牢地插入到玻璃里面后,重新加热iOpener然后将其放置在原位来软化粘合剂。
  • 一旦工具牢牢地插入到玻璃里面后,重新加热iOpener然后将其放置在原位来软化粘合剂。
添加评论
在手机的侧面向下滑动撬棒,来分离粘合剂。 慢慢操作,这样撬棒尖端就不会从缝隙中滑出。如果切割工作变得困难了,请重新加热放置iOpener。
  • 在手机的侧面向下滑动撬棒,来分离粘合剂。
  • 慢慢操作,这样撬棒尖端就不会从缝隙中滑出。如果切割工作变得困难了,请重新加热放置iOpener。
添加评论
在手机剩下的边角,重复先前的加热和切割工作 在你切割下一侧的时候请在先前的一侧放置一片撬片,来避免粘合剂重新粘连。 在你切割下一侧的时候请在先前的一侧放置一片撬片,来避免粘合剂重新粘连。
  • 在手机剩下的边角,重复先前的加热和切割工作
  • 在你切割下一侧的时候请在先前的一侧放置一片撬片,来避免粘合剂重新粘连。
Petite erreur: le guide dit iPhone au lieu de S7 :)
Nicolas Duthilleul - 回复
Bonjour Nicolas ! Merci pour la remarque ;-) Nous l’avons prise en compte et corrigé la traduction. La prochaine fois, n’hésitez pas à corriger directement en cliquant sur le bouton Traduire en haut à droite de l’étape.
Claire Rapp -
指纹传感器线缆与手机在后玻璃面板靠近主摄像头的位置连接。 这个线缆十分的短,在移除玻璃面板的时候也要断开。 抬起玻璃杯时,请仔查看以确保带有蓝色连接器的橙色电缆已断开连接。
  • 指纹传感器线缆与手机在后玻璃面板靠近主摄像头的位置连接。 这个线缆十分的短,在移除玻璃面板的时候也要断开。
  • 抬起玻璃杯时,请仔查看以确保带有蓝色连接器的橙色电缆已断开连接。
  • 使用打开工具将残留粘合剂分离,小心地打开手机。
  • 如果指纹传感器电缆看起仍处于连接,请勿继续抬起面板,在继续之前请用撬棒来断开连接。
  • 移除玻璃后面板。
添加评论
在更换后面板之前你需要移除手机上旧的粘合剂。
  • 在更换后面板之前你需要移除手机上旧的粘合剂。
    • 在移除掉旧的粘合剂后,使用用高浓度的异丙醇(至少90%)清洁手机机身的边缘,然后再贴合上新的粘合剂。
Bonjour,
Vous parlez d’ajouter de l’adhésif, comment et où le trouve-t-on cet adhésif ?
Difficile à appliquer ?
Cordialement,
Stéphane
Steph D - 回复
Mille excuses, je viens de voir les “adhesive strips” :)
Steph D - 回复
移除11颗3.7mm  #000  十字螺丝。
  • 移除11颗3.7mm #000 十字螺丝。
添加评论
移除NFC天线和无线充电线圈组件。 移除NFC天线和无线充电线圈组件。
  • 移除NFC天线和无线充电线圈组件。
添加评论
移除3颗3.7mm十字#000螺丝。
  • 移除3颗3.7mm十字#000螺丝。
添加评论
移除扬声器组件。
  • 移除扬声器组件。
添加评论
使用撬棒扁平的一端来断开电池连接头。 使用撬棒扁平的一端来断开电池连接头。
  • 使用撬棒扁平的一端来断开电池连接头。
添加评论
准备iOpener,然后将其直接放置在电池上。
  • 准备iOpener,然后将其直接放置在电池上。
  • 放置iOpener至少一分钟来软化电池粘合剂。
添加评论
使用撬片来从电池底部开始撬起。 您将对着外壳上方的子板和天线线缆处撬动。 小心地撬动以免伤害到那两个组件。
  • 使用撬片来从电池底部开始撬起。
    • 您将对着外壳上方的子板和天线线缆处撬动。 小心地撬动以免伤害到那两个组件。
  • 你有可能需要重新加热和放置iOpener,来进一步软化粘合剂。 粘合剂很强劲可能需要多次尝试来开始从下方撬起。
添加评论
将撬片滑向电池侧面来分离剩下的粘合剂。 将电池从外壳中取出。 将电池从外壳中取出。
  • 将撬片滑向电池侧面来分离剩下的粘合剂。
  • 将电池从外壳中取出。
添加评论
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
19等其他人完成本指南。
特别感谢这些译者︰
55%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Adam O'Camb
于2015年04月11日注册
23,543 信誉积分
创作了281篇指南
团队
iFixit iFixit 的会员
Community
116 名成员
创作了5,778篇指南
Who are these geniuses that engineer a cell phone that requires complicated surgery in order to replace a faulty or dead battery? Really? And this POS costs the yuppified zombies how much?
Joseph Kennedy - 回复
What type of adhesive do you use to stick the phone back
Good Survey - 回复
Hi! In our store you’ll find a rear cover adhesive strip for the S8. In the event that that’s sold out, we recommend using Tesa Tape—the 2 mm width should work well for this repair.
Adam O'Camb -
How complicated compared to my old S4 … what a joke
mofla39 - 回复
Will the phone still be water resistant after this ?
Thanks
aperret - 回复
This was wild. I hope I don’t have to use this knowledge for awhile. Why doesn’t Samsung just tell you to send it back and they will fix it for the price of a new battery? If I pay $800-$1,000 for a phone that I can’t change the battery on after a year or two, I’m going to be !#^&@@ at Samsung. Should we all complain to them about making this service available or having them advertise the lack of battery changing before a customer buys it?
mtrman94 - 回复
that’s the issue. Like Apple, Samsung want you to buy another new phone every year instead of replace the battery.
ANTHONY CAETON - 回复
Same issue, i sent my S8 back to Samsung 15days ago and still waiting for my f****** phone.
Pietro Ferracini - 回复
This process did NOT work for me. I purchased the kit and spare battery thinking it would be as easy as the video shows. However, after multiple attempts and several different hot pads later, the cover did not budge AT ALL. Now, I’m stuck with a kit that didn’t work and a battery (not even a Samsung replacement battery like the site stated), and nothing to show for it. Not being able to replace any battery in any electrical device on your own is just a poor engineering letdown, especially in such an expensive phone.
Michael Pakosta - 回复
There are versions of phones with waterproof battery compartments and certainly they could maintain their ability to control waterproofing the product of they still redesigned the access to the back cover via a more robust removable rear cover with gasket.
But with rear main cover more secure with screws possibly?
I'm not going to spell out how to tell them to make their phones, but maybe they might consider how users want to have the ability to change the battery themselves, and maintain the control of the device without sending it to a repair site for some time period.
Think of all the professional customers, besides all the soccer moms, students and retirees who they might dismiss right away.
Military & Government Officials, maybe even Senior Company Executives and tech companies that use these for everything from email and texting to secure encrypted NSA stuff.
Make it so they can be field repaired with a fresh battery seems like a no brainer?
That's my 2 cents!
Michael McGarghan - 回复
if battery deteriorates to a very low level, say, just last 1 hour after recharge, and it’s under warranty, can we send it back to Samsung for free repair?
chasun - 回复
添加评论
浏览统计数据:
过去的24小时: 251
过去的7天: 1,848
过去的30天: 7,677
总计 78,573
