简介
本指南将向您展示如何更换S7上的屏幕。 您将需要从显示屏组件的背面去除大多数组件,然后仔细地将屏幕和数字面板从中间框架中撬开。 您将需要非常耐心和小心,以免损坏围绕中框的软纽扣电缆。
本指南涉及拆卸后玻璃盖,您将需要更换粘合剂以将后盖重新连接到手机。
如果您的屏幕受到破坏,请戴上防护眼镜,并将屏幕保护膜或胶带应用于显示屏,以帮助收集玻璃碎片。
视频介绍
结论
要重新组装设备,请将粘合剂涂抹在后盖上,并按照相反的顺序进行操作。
78等其他人完成本指南。
特别感谢这些译者︰
21%
大大大大大瓜砸正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Sam Lionheart
于2012年10月18日注册
323,770 信誉积分
创作了1,664篇指南
团队
iFixit iFixit 的会员
Community
113 名成员
创作了6,002篇指南
The screen replacement went smooth. I just wish it included the adhesive. I didn't see the note where the adhesive needed to be ordered in addition to the screen. Otherwise everything went well.
Thanks
march11934 - 回复
For the price of the screen, I can replace it in a Samsung repair center...
I just need to replace the glass, not all of the AMOLED touch screen... :-( Sorry but this didn't help me.
Darky - 回复
How much cost u paid to service centre for original display for samsung s7
Durgaprasad -
I'm wanting to help my friend do this but I don't have a heat gun. Would a blow dryer work to loosen the glue or does it need to be hotter? He got a quote for 200 from a shop to fix it but they said it takes a month…lame! I've replaced screens in many tables and phones and I have all the necessary tools other than the heat gun and the replacement screen components obviously.
Adam Bacon - 回复
@Adam Bacon Heat guns are quite inexpensive. The model she uses in this video runs about $20 or less in most shops. A blow dryer may work, but it’s difficult to say for certain. The adhesive Samsung uses is pretty robust. If you find yourself fixing a lot of devices you should really consider investing in a heat gun.
E West -
I did this repair. A heat gun isn’t really hot enough to remove the screen without destroying it. A hair drying isn’t going to touch the glue.
armand -
I just want to add that if you only need to replace the glass, this is not the guide for you, and the difficulty rating is a 10 of 10. What I would do to replace just the front glass, is to avoid all these steps, and remove the glass from the front. Do not attempt to remove the AMOLED screen, it will shatter in the process of removing it. You will notice in this video, the screen shatters in the bottom left of the phone, behind the glass.
The other issue is that the glass is laminated to a filter, which is backwards from many screens, where the LCD panels are laminated to the filter, and the screen floats. When you buy a replacement glass, you will need one that has the laminated filter attached, or you will need to figure out a way to separate the two pieces. (I could not).
armand - 回复
armand what did you use to remove the back, i’ve tried the hair dryer with no luck. Thanks;
Maria
nena_boricua52 -
I would also like to point out that both the front and back glass are extremely brittle. If you broke your glass, because the phone landed on its side, then check for spurs. The smallest protrusion will shatter the glass while applying pressure to seal the adhesive application. I had the tiniest of a protrusion, and the back glass exploded. Thankfully, those are cheap.
armand - 回复
Thank you very much for good instruction
Vedrasco Victor Vasili - 回复
添加评论
浏览统计数据:
过去的24小时: 276
过去的7天: 2,082
过去的30天: 9,399
总计 142,499
