简介
根据本指南以更换三星盖乐世S6显示屏。该组件由一个LCD和触摸面板构成。组件是封装的,务必同时更换。该步骤对修理屏幕破损或触摸屏反应迟缓的问题很有帮助。
本指南仅涉及到拆卸后部玻璃面板,金属中框,逻辑主板和电池都在原位置。注意: 一些更换的屏幕已经提前装在中框上了 (又名,chassis),那么这样就需要你把手机内部配件都转移过来,并且装上一个新电池。这样的步骤非常不同,所以确保你在开始本指南之前就有了正确的配件。
如果中框损坏或变弯,那么需要更换它,不然新的屏幕就不能装上了,屏幕的压力将变得压力不均。
拆卸后部玻璃面板需要去除将其固定的粘合剂。参照 指南 以重新组装后部玻璃面板。
从中框拆离屏幕的过程,经常会损坏屏幕,所以如果你要替换屏幕的话再使用本指南。
将回形针或SIM卡针插入和电源按钮同侧的SIM卡槽的孔中。
  • 将回形针或SIM卡针插入和电源按钮同侧的SIM卡槽的孔中。
  • 按压回形针或卡针,使得SIM卡槽弹出
    • 大力按压可能损坏你的SIM卡卡托
添加评论
将SIM卡托从手机中移除
  • 将SIM卡托从手机中移除
添加评论
  • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 把iOpener放在微波炉中间 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
which temperature must be used for heating? Thx
fbarletta - 回复
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - 回复
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - 回复
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - 回复
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - 回复
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - 回复
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - 回复
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - 回复
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - 回复
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - 回复
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - 回复
  • 加热iOpener三十秒
  • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
  • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
  • 如果出现膨胀千万不要碰iOpener。
  • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - 回复
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - 回复
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - 回复
I don't own a microwave.
mdanihy - 回复
Its again waterproof when you change iphone 7 battery?
Jon - 回复
I don't have a microwave???
Joe Blow - 回复
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - 回复
can i use just ordinary microwave???
juneseok kwon - 回复
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - 回复
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - 回复
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - 回复
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - 回复
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - 回复
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - 回复
30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
60 seconds in the microwave, the iOpener burst.
I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
K
Karl Marble - 回复
  • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
Will a hair dryer work for heating the glass?
Me berg - 回复
Yes, as does a heat gun.
anonymous 4602 - 回复
I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
Cobus de Beer - 回复
  • 将你的手机正面朝下放置。
  • 如果手机的玻璃面板已经碎裂,请在拆卸过程中用胶带固定住整个面板。
  • 将iOpener放置在面板上约60秒以融化固定玻璃面板边缘的封胶。
  • 移动iOpener以加热剩余部分的面板,同样需要60秒。
  • 吹风机,热风枪,或者加热工具也许都会用到,但是千万不要过度加热手机——OLED 屏幕和内部电池都会容易热损坏。
are there any option out there that allows you to heat the adhesive outdoors without any power plug?
Brotan Store - 回复
There's a star in the center of our solar system, you could try that.
John Joiner -
the way we do it at Get it fixed cellphone repair calgary is with a heat gun, wich is way easier than this, make sure to wear some gloves and dont worry to use to much heat as long as you point just to the back of the phone, (the back panel is thick enough to protect the logic board from over heat) instead of the usual blue plastic piece i sugest to use the thinnest metal razor knife and a business card so you can insert the business card and move it all around the frame, those blue plastic things are way too thick that will break the glass panel if you apply to much pressure
get it fixed - 回复
After did that with my own heat pad, the white paint got ripped off but luckily glass back cover did not break. So I scratched all white part of the back cover and now its all transparent.
Jae Chung - 回复
I used a purpose built heating device at 100 degree celsius. Lower temperatures didn't work.
ken - 回复
  • 将吸盘紧紧吸在后部玻璃面板的下部。
If the rear screen is cracked/smashed, you will not be able to use a suction cup to remove it. The suction could would not seal because of the cracks. I tried masking tape, 3M shiny HVAC tape, and others, and the suction could would not seal to those surfaces either.
I ended up using the sharp point of the smudger to remove some shards of glass to get underneath the cover to leverage it up and out. Definitely use gloves and safety glasses if you have to do this.
dougpender - 回复
Thank you for your comment. I needed to see this particular instance of what to do when the back cover was cracked. I was going to try to suction it with tape covering it. This saved me some heartache. You're an angel!!
Jessie Brooks -
  • 本步骤还使用了一个塑料撬片,用来将后部面板从中框分离。如果双面胶的粘性仍然很强,用iOpener再加热一次。
  • 使用吸盘在面板中部用力,旋转你的手腕向上拉后部的边缘。
添加评论
  • 当你打开一个够大的缝隙后,在后部玻璃面板和中框之间插入一个塑料撬片。
At this stage I didn’t use a plastic pick as I think they are too thick and will crack a screen that’s not already cracked. I used a stainless steel
I sesame blade which does a much better job of cutting through the adhesive. Just be careful not to insert it in too far. I sometimes put a mark on my blade to ensure it doesn’t go in too far.
Wayne Lyell - 回复
  • 将塑料撬片绕后部玻璃面板的底部左侧滑动。
添加评论
  • 将塑料撬片沿着手机的电源按钮一侧滑动。
添加评论
  • 将塑料撬片沿着手机顶部滑动。
添加评论
  • 将塑料撬片沿着手机的音量按钮的一侧滑动。
添加评论
  • 按住中框,向上拉后部玻璃面板将其与组件分离。
    • 如果由于双面胶粘性太强,用塑料撬片在玻璃下面滑动数次。
添加评论
  • 在后部面板和中框之间插入塑料撬片。
  • 沿着手机的顶部滑动撬片以清除剩余双面胶。
  • 扭动撬片以分离两部分。
添加评论
  • 此时,后部玻璃面板应该完全从手机上分开。双面胶可能仍然会粘附在两侧上。
  • 拉开后部面板,然后完全分离它们。
  • 参考此指南以重新安装后部玻璃面板。
You should note that the adhesive strip may need to be fully removed from the frame in order to proceed with repairs. The adhesive on my phone covered all of the screws exposed in the next step.
Sean Cruz - 回复
  • 卸下13个3.5毫米用来将中框固定在手机上的Phillips #00螺丝。
Make sure you do not mix up these thirteen screws with a hidden 14th screw under the mid-frame chassis, on the left side of the headphone port, on daughter-board. This 14th screw is shorter than the other screws, so make sure you do not replace it with one of the longer screws. It will push up against the front glass and lift it away from the adhesive.
David Whyte - 回复
  • 紧紧地抓住中框组件的边缘。
  • 向下推电池的同时抬起中框组件,以将其与手机的剩余部分分开。
FIRMLY GRASP IT! - Patrick
Armen Orbelyan - 回复
Bei diesem Schritt sicher sein, dass SIM Card Fach entfernt ist!
zikal - 回复
I found the glue still very sticky here, i had to go around with my picks to free it, its very stuck with a UK version, beware!!
databeat1 - 回复
I damaged my screen here a bit, be careful not too slide your pick between the digitizer and the screen.
Anton -
i suggest to apply heat on the corners of the front screen to lose the adhesive a lil bit and push from the bottom back of the phone right where the wireless charger is because of the charging port
get it fixed - 回复
When grabbing from the bottom, you fun the risk of damaging the charging port and headphone jack. I would suggest starting from the top. This is because the two ports at the bottom slide down into the frame. There is also adhesive that will give you a little resistance.
Alex Philip - 回复
Step 18 is not correct, you have to start from the top. You can damage the charge port
Daniel Yaben - 回复
On mine the adhesive actually tore away part of the colored film on the back of the screen glass rather than separating from it. I’m guessing applying heat to the screen corners first would help avoid this (I didn’t). https://imgur.com/a/V7vZQ
Brian Hardie - 回复
  • 抬起中框将其与手机的剩余部分分离。
what do the numbers ZF-N2 AS WELL AS (F13) AT THE END OF THE MODEL NUMBER, THEN THERE IS REV 5-1-C W G 15221............... WHAT ALL HAS TO MATCH WHEN REPLACING THE MID FRAME.
mike gentry - 回复
  • 使用撬棒的平端从主板的插座上断开电池的连接器
添加评论
  • 在外壳和电池之间插入塑料撬片。
    • 尽可能小心,并保持塑料撬片平整插入,以避免弯折电池,否则可能会损坏电池并使其释放危险的化学物质。
  • 将塑料撬片进一步推入以将电池与手机分开。
    • 如果电池被太牢固地粘住,无法将塑料片插入,请将加热的iOpener放在电池上来松开粘合剂。
    • 另外,在电池的每一个角落都涂上一些异丙醇,让它们作用几分钟,以溶解粘合剂。
    • 不要撬动主板,否则可能会损坏手机。
添加评论
  • 把电池从手机中取出
  • 不要重复使用拆下来的旧电池,因为这是一个安全隐患。请用一块新电池来替代它。
  • 安装新电池:
    • 从手机中去掉任何残留的粘合剂,并使用异丙醇和无绒布擦拭粘合区域。
    • 用预切割粘合剂或双面胶带固定新电池。为了正确地定位,将新的粘合剂安放在电话中,而不是粘到电池上。粘合剂应该围绕电池隔层的旁边,而不是在中心的矩形切口(实际上是显示屏的背面)。
    • 将电池牢牢地按住5-10秒。
添加评论
  • 使用撬棒的尖端从主板的插座上断开蓝牙和Wi-Fi天线的线缆连接器。
This portion of the repair caused me problems after phone was closed up. The bluetooth cable on the left of the phone was not placed back into its cable track and was pinched off by screen once frame was placed in metal housing.
Sebastian Diaz - 回复
  • 使用撬棒的平端断开home键的连接器。
添加评论
  • 使用撬棒的平端从主板上断开显示屏组件线缆的连接。
Does taking the motherboard out wipe the phone?
Uil'yam - 回复
No, after disconnecting the battery there’s no way for info to be moved from the memory, until it’s connected to a power source again.
Wayne Lyell - 回复
  • 从主板上断开听筒组件线缆的连接器。
添加评论
  • 抬起主板靠近摄像头的一侧以将其从显示屏框架上分离。
  • 此时请不要将主板完全移除。因为它仍然通过一条在主板底部的扁平线缆连接到子板。
添加评论
  • 断开在主板下面连接到子板的线缆的连接器。
添加评论
  • 再次加热iOpener
  • 将iOpener平放在S6的显示屏一侧。约30秒后,将iOpener放置在另一侧。
添加评论
  • 将塑料撬片以向上的角度插入。
  • 塑料框架被粘在显示器组件上。以下步骤将塑料框架从显示器组件上分开。
    • 这一步很容易意外损坏LCD屏幕。务必小心地分离这些部件。
    • 步骤执行正确的话,你将会看到显示器框架和显示器组件的空隙。
    • 若步骤执行不正确,塑料撬片将可以透过LCD看得到。如果出现这样的情况,只需取出撬片,重新执行本步骤。
Your warning says “When done incorrectly, the pick will be visible through the LCD. If this happens simply remove the pick and start again” but this is the opposite - you should see the pick through the LCD otherwise you’ll destroy it and it will also need to be replaced.
B B - 回复
The warning says “When done incorrectly, the pick will be visible through the LCD. If this happens simply remove the pick and start again” but this is the opposite of what you should do - the pick SHOULD BE VISIBLE through the screen otherwise you’ll destroy the LCD.
B B - 回复
not sure about that BB, if the pick is visible, it’s between the digitizer and the lcd… you want these two to come off together or the digitizer will not be functional after being ripped off the LCD.
hogdoctor - 回复
I was too vigorous with the pick, and maybe not pointed up (away from the glass) enough, but I got the pick far enough into the digitiser that it peeled the glass off of the digitiser. Ruined it. If you can see the pick through the glass STOP.
Buck - 回复
  • 将手机翻过来使其面朝下。
  • 在手机的右侧,显示器组件和塑料显示器框架之间插入塑料撬片。
添加评论
  • 向下滑动撬片以将显示器框架从显示器组件上分离。
添加评论
  • 将塑料撬片插在听筒插座旁边。
  • 将另一个塑料撬片插入框架和显示器组件在显示器线缆的一侧之间。
添加评论
  • 将撬片沿着向子板的方向滑动
添加评论
  • 将另一个撬片插入显示器框架和顶部一侧的触摸屏之间。
I found that I could not free the black sticker digitizer in the middle without damaging the digitizer see fig 39. I don’t know if the UK Samsung is glued better? but its very stuck to the frame, be very very careful to separate the pink and black digitizer, they are very expensive, I wish I dug deeper on the internet first, this step could take 30+ mins to do
databeat1 - 回复
  • 沿着手机顶部朝着震动器方向滑动撬片。
    • 轻轻地拉出撬片以避免损坏听筒扬声器格栅。
添加评论
  • 在手机顶部右侧角落环绕滑动塑料撬片。
  • 由于触摸屏控制器IC在顶部右侧角落的显示器框架下面。在本步骤请仅使用撬片的尖端。
This should really be pointed out more than it is. I've gone through a few phones by destroying the IC. Of course if you're doing the repair without instructions it's no ones fault but your own. (guilty) But... This warning should be in BOLD and CAPPED with blinking lights and arrows.
Felix Robinson - 回复
  • 抓住靠近听筒插座塑料撬片,朝显示器框架底部右侧的角落滑动。
  • 旋转塑料撬片将塑料框架从显示器组件上分离。
添加评论
  • 将显示屏连接器当成一个铰链,继续从右侧向上翻塑料框架。
  • 框架举起的角度刚刚超过90度时,将触摸屏线缆穿过显示屏框架上的开孔,然后将框架从显示器组件上分离。
Great guide. My goal is to disable my left sofy key. I have done this with software fixes but due to a short somewhere and possibly some water damage the button hits it self continuously causing the phone to run slow even though I used an app to tell it to take no action when the button is hit. Looks like step 42 I should disconnect/break the connection.
If anyone knows an easier way please advise.
ptrgrnwd - 回复
Great illustrations and the best tutorial I have seen. Steps are easy and simple to follow.
Rafael - 回复
Really good to follow reparing the phone. But i'm afarid of seeing other word like korea
James - 回复
What is the copper foil for shown here on the back of the display assembly? I tore it.
AjL - 回复
结论
参考以下步骤的相反顺序重新安装你的设备。若要重新组装后部玻璃面板,参照 更换后部玻璃面板粘合剂的指南
232等其他人完成本指南。
特别感谢这些译者︰
25%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Dante Mazzanti
于2015年07月13日注册
29,992 信誉积分
创作了26篇指南
I replaced my screen now my service doesn't work as well as it did before. What could I have missed.?
Mike Trevino - 回复
First thing you want to do is make sure that all the cables and wiring are in place on your device's logic board. I have seen this several times in my cell phone repair history.
If that step does not fix the issues then you want to change refer to the Samsung Support site about No Signal issues.
shamir wilkes -
Latent or low service bars after you remove the mid-frame from outer frame is due to contacts within the outer frame not making the proper contact with the board. You can test service outside the frame which is one to two bars and very difficult to make calls. Once refit to the frame properly the service is boosted. If you are having service issues, its more than likely the frame. Take apart and check the inner frame and reassemble. Check service before you replace the back screws and glass battery door.
SPLYCERS SALES -
at step 18 make sure all of your motherboard components are free, my headphone jack got stuck on the frame and i nearly ripped the whole thing off
zigge zwiers - 回复
after the replacement of the display, everything works fine, soft keys are working and give back response, lcd display is also working but only the touchscreen doest recognize a tap... what could be the issue? may u help me asap, thanks!
Timo - 回复
Timo, i have the same issue. did you fixed it?
NEFI -
My phone model is G920i. Is it necessary that I should buy the same model or even models like G920A suits with my phone ?
farhannaz - 回复
I have the same model G920i, did you manage to install a different model?
soy_un_ovni -
my screen is flashing white and on and off and when it stops it works fine ... do i need to change the screen
nikolas mussington - 回复
It's too help full sir and doing a not a good it's best work done by u sir thankfully to provide the use full information thx we love u all
sandeepsuryasurya - 回复
Just changed the screen/digitizer on my G920i. The daughter board had two connections that goes under the housing and connects . One of the connections broke and I am going to replace the daughter board before re-assembling the phone. My question ; should new adhesive be used to re-seal the screen assembly to the housing that holds the boards and battery.
Elliot Hutcheson - 回复
Hello, dude. What version of the LCD digitizer did you get? The options in the store do not match for G920i. Cheers.
soy_un_ovni -
I have a SM-G920A, it has two barely visible cracks in the glass over the display. When it is on they are barely visible. when display is off they are more visible and can be felt with a fingernail.
Can this glass be replaced separate from the LCD display or does both the LCD and the glass have to be replaced to repair it? Or could it be replaced with the NuGlas tempered glass screen protector?
jackerbes - 回复
I just followed these steps to replace LCD on my S6, everything seems to be working fine except service is weak and microphone is giving problems. I can hear the other person but he is having difficulty hearing me, my voice is cutting off. What could be the reason for this?
Shahina Chagani - 回复
I rather just take it and get it done by professionals
Marquia Cato - 回复
Hi there,
I have removed the display assembly but the brown foil on the back of the display, the one that has the black rectangle under witch the battery sits, it become loose and I think it severed the connection with the rest of the foil, when I tested the display it doesn’t light up, I don’t know how that brown foil is called and if is possible to replace/fix this.
Thank you.
Tiberius - 回复
i dropped my phone now the screen is black and the phone doesnt work. do i just need to replace the screen?
Scott
scott proell - 回复
Hi, yes if the display flashes it might be a loose connection. I’ve also seen similar issues with the foil mentioned, Z axis tape works for reattaching it. The foil used for getting rid of slugs will work as used it before for making patches on antennas etc, but nice Z axis and copper tape is sold with the chibitronics circuit stickers kit.
Andre - 回复
My phone Is shattered but the screen Is completely black and the back arrow key and the window app opener lights up. But when I switch on my device it still recieves notifications but I cannot see anything so I am not sure what I broke if it is the lcd or if it is the digitizer broken in certain places so I need to know what part is broken so I can buy the right parts and tools to repair my device and my device is the samsung galaxy s6
patrick - 回复
Plzz help as my phone has a problem of touchpad.
My phone works perfectly sometimes and sometimes not
Plz suggest me what i can do and get rid out of touch problem on my samsung galaxy s6
NILESH CHOUDHARY - 回复
hi my s6 fell down and hit the ground on rhe font left edge. the front glass didn’t shatter but some parts of the white color beneath it got separated .and screen isn’t turning on any more. when trying to turn on the phone the notification led keeps twinkting but screen remains off. what is the solution?
salazar333 - 回复
it looks like the lcd panel below the glass broke. you’ve got to replace the screen. before doing that open your phone and make sure the connector isn’t loose or came off since the price of a new LCD is higher than other brands.
Keyvan Khademi Ravandi - 回复
添加评论
浏览统计数据:
过去的24小时: 127
过去的7天: 1,169
过去的30天: 5,423
总计 359,435
