Introduction
Removing the rear glass panel from your Galaxy S6 destroys the adhesive holding it in place. Follow this guide to replace the adhesive tape on your Galaxy S6's rear glass. Most adhesive strips will come packaged as shown, although the film dimensions and color may vary.
Before beginning, we recommend you remove any residual adhesive from the glass panel using a lint-free cloth and solvent such as high concentration isopropyl alcohol (at least 90%).
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Peel the clear film off of the adhesive packaging.
  • Peel the clear film off of the adhesive packaging.
Lay the glass panel face-up and rotate it so that the lens holes are on your right.
  • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
  • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
  • Lay the adhesive on top of the glass.
  • Run your fingers over the tape to firmly attach it to the glass.
  • Peel back the outer layer of green film.
  • Peel back the inner film layer.
  • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
  • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  • Use a pair of tweezers to remove any adhesive still on the midframe.
  • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  • Align the top of the rear glass with the top of the phone.
  • Press the top edge of the glass into the midframe so that there's no gap at the top.
  • Lower the rest of the rear panel and press it firmly into the midframe.
Finish Line
101 other people completed this guide.
Evan Noronha
135,006 Reputation
728 Guides authored
iFixit Member of iFixit
Community
109 Members
6,207 Guides authored
7 Comments
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
Rob Crawford - Reply
I snagged a replacement front and back glass adhesive and a new daughter board for the S6 from http://www.mobiledefenders.com/. They seem okay so far. Only about a buck for the adhesives, plus shipping.
PortableOpossum -
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
shabria jones - Reply
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
Richard Meyers - Reply
I ordered a rear glass housing from amazon with the adhesive pre-aligned and installed so that all I have to do is peel away the film and snap it on.
Sean Myer - Reply
Past 24 Hours: 41
Past 7 Days: 245
Past 30 Days: 1,259
All Time: 66,411
