简介
本指南展示了更换三星盖乐世S6 Edge出现故障的电池的必要步骤。
本指南涉及到拆卸后部玻璃面板。拆卸后部玻璃面板需要去除将其固定到位的粘合剂。参考本指南以重新安装后部玻璃面板。
  1. 将曲别针或SIM卡弹出工具插入位于电源按钮一侧SIM卡槽旁边位于电源按钮一侧的小孔中。
    • 将曲别针或SIM卡弹出工具插入位于电源按钮一侧SIM卡槽旁边位于电源按钮一侧的小孔中。
      • 不要将工具插入麦克风孔中,否则将会导致其损坏。你可以找到SIM卡托的轮廓。
    • 按压来弹出SIM卡托。
    • 将SIM卡托从电话上移除。
    First thankful sir that you have a good idea for people to creat like this.. I am very happy from your website its too good. All things i learn from your website thank you..
    Lovely Khan - 回复
  2. 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
    • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
    • 把iOpener放在微波炉中间 。
      • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
    which temperature must be used for heating? Thx
    fbarletta - 回复
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 回复
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 回复
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 回复
    Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
    Fletcher Carpenter - 回复
    I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
    putinaspiliponis - 回复
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 回复
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 回复
    I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
    Sherry Carew - 回复
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - 回复
    Hi, the microware have multiple power 1 to 9, what must be used ?
    Regards,
    Cedric
    Cedric VINCENT - 回复
    • 加热iOpener三十秒
    • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
    • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
    • 如果出现膨胀千万不要碰iOpener。
    • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - 回复
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 回复
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 回复
    I don't own a microwave.
    mdanihy - 回复
    Its again waterproof when you change iphone 7 battery?
    Jon - 回复
    I don't have a microwave???
    Joe Blow - 回复
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - 回复
    can i use just ordinary microwave???
    juneseok kwon - 回复
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - 回复
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 回复
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 回复
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 回复
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 回复
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 回复
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 回复
    • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
    • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
    Will a hair dryer work for heating the glass?
    Me berg - 回复
    Yes, as does a heat gun.
    anonymous 4602 - 回复
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 回复
    • 将你的手机正面朝下放置。
    • 如果手机的玻璃面板已经碎裂,请在拆卸过程中用胶带固定住整个面板。
    • 将iOpener放置在面板上约60秒以融化固定玻璃面板边缘的封胶。
    • 移动iOpener以加热剩余部分的面板,同样需要60秒。
    • 吹风机,热风枪,或者加热工具也许都会用到,但是千万不要过度加热手机——OLED 屏幕和内部电池都会容易热损坏。
    are there any option out there that allows you to heat the adhesive outdoors without any power plug?
    Brotan Store - 回复
    There's a star in the center of our solar system, you could try that.
    John Joiner -
    the way we do it at Get it fixed cellphone repair calgary is with a heat gun, wich is way easier than this, make sure to wear some gloves and dont worry to use to much heat as long as you point just to the back of the phone, (the back panel is thick enough to protect the logic board from over heat) instead of the usual blue plastic piece i sugest to use the thinnest metal razor knife and a business card so you can insert the business card and move it all around the frame, those blue plastic things are way too thick that will break the glass panel if you apply to much pressure
    get it fixed - 回复
    After did that with my own heat pad, the white paint got ripped off but luckily glass back cover did not break. So I scratched all white part of the back cover and now its all transparent.
    Jae Chung - 回复
    I used a purpose built heating device at 100 degree celsius. Lower temperatures didn't work.
    ken - 回复
    I used a blow dryer, attached my multimeter heat sensor to the back to monitor the temperature. At 54 degrees Celsius I could separate the back with a suction cup from my phone without damaging the paint.
    LRD - 回复
    • 将吸盘紧紧吸在后部玻璃面板的下部。
    If the rear screen is cracked/smashed, you will not be able to use a suction cup to remove it. The suction could would not seal because of the cracks. I tried masking tape, 3M shiny HVAC tape, and others, and the suction could would not seal to those surfaces either.
    I ended up using the sharp point of the smudger to remove some shards of glass to get underneath the cover to leverage it up and out. Definitely use gloves and safety glasses if you have to do this.
    dougpender - 回复
    Thank you for your comment. I needed to see this particular instance of what to do when the back cover was cracked. I was going to try to suction it with tape covering it. This saved me some heartache. You're an angel!!
    Jessie Brooks -
    • 本步骤还使用了一个塑料撬片,用来将后部面板从中框分离。如果双面胶的粘性仍然很强,用iOpener再加热一次。
    • 使用吸盘在面板中部用力,旋转你的手腕向上拉后部的边缘。
    添加评论
    • 当你打开一个够大的缝隙后,在后部玻璃面板和中框之间插入一个塑料撬片。
    At this stage I didn’t use a plastic pick as I think they are too thick and will crack a screen that’s not already cracked. I used a stainless steel
    I sesame blade which does a much better job of cutting through the adhesive. Just be careful not to insert it in too far. I sometimes put a mark on my blade to ensure it doesn’t go in too far.
    Wayne Lyell - 回复
    I used a card like the ones people use to play poker or any card game with. Only one was needed to separate the back without any damage to the paint.
    LRD - 回复
    Be sure to apply a decent amount of heat when removing the last bit of the rear glass, cracked the rear of my screen (only a small amount mind) trying too use too much force not enough heat for the last spot.
    spank2103 - 回复
    • 将塑料撬片绕后部玻璃面板的底部左侧滑动。
    添加评论
    • 将塑料撬片沿着手机的电源按钮一侧滑动。
    添加评论
    • 将塑料撬片沿着手机顶部滑动。
    添加评论
    • 将塑料撬片沿着手机的音量按钮的一侧滑动。
    添加评论
    • 按住中框,向上拉后部玻璃面板将其与组件分离。
      • 如果由于双面胶粘性太强,用塑料撬片在玻璃下面滑动数次。
    添加评论
    • 在后部面板和中框之间插入塑料撬片。
    • 沿着手机的顶部滑动撬片以清除剩余双面胶。
    • 扭动撬片以分离两部分。
    添加评论
    • 此时,后部玻璃面板应该完全从手机上分开。双面胶可能仍然会粘附在两侧上。
    • 拉开后部面板,然后完全分离它们。
    • 参考此指南以重新安装后部玻璃面板。
    You should note that the adhesive strip may need to be fully removed from the frame in order to proceed with repairs. The adhesive on my phone covered all of the screws exposed in the next step.
    Sean Cruz - 回复
    When I did my battery, the adhesive stayed almost 100% on the back glass and was still in good shape. What didn’t remain attached only lifted slightly and I was able to coax it back to its original location with tweezers. I didn’t bother to remove and replace the adhesive layer because mine was still good. I set the glass out of the way where it wouldn’t get dirt on the adhesive while I finished the battery swap. I added some additional heat (hair dryer) after reattaching the glass to make sure the adhesive made the best seal.
    Wayne Thomason - 回复
    • 从中框卸下13颗3.3mm Phillips #00螺丝。
    Do yall sell the screws and the screw organization mat
    The lit asf Channel - 回复
    • 向下按压电池背部的同时,向上抬起中框边缘以使其从手机剩余部分分离。
    添加评论
    • 使用撬棒的平端从主板上断开电池扁平线缆的连接。
    添加评论
    • 从主板上断开home键扁平线缆的连接。
    添加评论
    • 使用撬棒的尖端,从主板上断开两个触点连接器。
    添加评论
    • 使用撬棒的平端从主板上断开显示屏扁平线缆的连接。
    添加评论
    • 从主板上断开听筒扁平线缆的连接。
    添加评论
    • 该主板为静电敏感元件,在操作时请务必小心。iFixit建议在直接手持此元件时佩戴防静电手环以避免将其损坏。
    • 紧握住主板靠近设备顶部的两侧边缘。
    • 此时请不要完全抬起主板,因为其底部仍连接有扁平线缆,需要先将其断开连接。
    • 如图小心地向上抬起主板,在与子板连接的线缆处别施加太大力。
    Better to remove the antenna connector from daughter board and keep the connector on main board, as You will planning to remove it you will need to take from it anyway.
    Gabriel Pinho - 回复
    • 从主板下面断开与子板连接的排线。
    添加评论
    • 在电池下面插入一个塑料撬片并左右滑动以清除将其固定的粘合胶。
    添加评论
    • 转动塑料撬片完全移开并卸下电池。
    Hi Sam, in conclusion and reassembling is the heat pad (used at the appropriate step in reverse) sufficient to re-adhere the panels or should new adhesive be applied. If new adhesive is required, can you recommend a satisfactory product please.
    Cheers
    Warren
    Warren Redding - 回复
    You should apply new adhesive when reinstalling your rear panel. You can use this 3M Double-Sided Adhesive Tape that we sell, or look around online for adhesive tape cut specifically for your phone.
    Evan Noronha -
    Achtung!
    Der Rahmen unter dem Akku ist an den verklebten Längsseiten nur ca. 5mm breit. In der Mitte befindet sich kein stabiler Schutz zwischen Akku und der Rückseite des LCD-Panels. Also besser wirklich nur die Ränder lösen und nicht mit einem Spachtel oder Ähnlichem hinter dem Akku herumhebeln, denn das könnte das LCD beschädigen.
    Oliver Edler - 回复
    Beachten bei Akku Einbau!
    Die Position des Akkus muss in Längsrichtung unbedingt anhand des Anschlusssteckers ausgerichtet werden und nicht an dem Kunstoffrand des Bodens. Das Flachkabel ist nicht flexibel und der Anschlussstecker hat kaum Toleranz (+- 1/10 )
    Das ist etwas knifflig, denn man sieht die richtige Lage nur, wenn die Hauptplatine in Position ist.
    Am besten, man überprüft das, bevor der Kleber am Akku angebracht ist.
    Wer den Fehler gemacht hat, weiß was ich meine. :/
    Oliver Edler - 回复
结论
参照以下介绍的相反步骤重新安装你的设备。参考本指南以重新安装后部玻璃面板。
55等其他人完成本指南。
特别感谢这些译者︰
42%
Z.Heng正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Sam Lionheart
于2012年10月18日注册
341,589 信誉积分
创作了535篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了7,032篇指南
Interesting but so difficult not worth doing! My A G S6 edge battery expanded in the night and pushed of the back. Fortunately I was awake and saw it happen.
My advice is not use Samsung phones too dangerous!
John Butler - 回复
I did it ! It wasn’t that hard. Thank you
Elie - 回复
We can do it very easy.
arvind thakur - 回复
Good guide, but with one minor correction - the SIM card slot is on the volume button side of the phone’s upper edge, not the power button side. An important distinction, considering the potential damage one could do if they stick the pick in the wrong hole.
apocalypticcritic - 回复
Are these the same steps for the galaxy s6 edge plus?
Thank you
Jordan - 回复
can we switch batteries between S6 and S6 EDGE ?
Mohamed Salah - 回复
You cant switch between 6 and Edge since the Edge have a longer cable going from beneath the mainboard. And Yeah great guide.
Brian Baltzer -
thx 4 this! it showed me it's not rly worth buying this phone off eBay with a battery that needs replacing. while I feel pretty secure that I could replace the battery using this (extremely well explained) guide, I don't rly feel like investing this much energy into something that could potentially further damage my phone, so the search continues to replace my note 4 that had the eMMC bug :/
Heather Hodge - 回复
添加评论
浏览统计数据:
过去的24小时: 132
过去的7天: 1,009
过去的30天: 4,636
总计 99,233
