简介
参考本指南以更换三星盖乐世S6的电池
在拆你手机之前,使手机电池量降到25%以下。 充好电的锂电池如果不小心戳破会很容易着火
将回形针或SIM卡针插入和电源按钮同侧的SIM卡槽的孔中。
  • 将回形针或SIM卡针插入和电源按钮同侧的SIM卡槽的孔中。
  • 按压回形针或卡针,使得SIM卡槽弹出
    • 大力按压可能损坏你的SIM卡卡托
添加评论
将SIM卡托从手机中移除
  • 将SIM卡托从手机中移除
添加评论
  • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
  • 把iOpener放在微波炉中间 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果你的iOpener卡住了,它可能会过热并燃烧
which temperature must be used for heating? Thx
fbarletta - 回复
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - 回复
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - 回复
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - 回复
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - 回复
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - 回复
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - 回复
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - 回复
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - 回复
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - 回复
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - 回复
  • 加热iOpener三十秒
  • 贯穿整个维修过程,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
  • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
  • 如果出现膨胀千万不要碰iOpener。
  • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再加热,一个加热好的iOpener 应该可以保持热度十分钟
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - 回复
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - 回复
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - 回复
I don't own a microwave.
mdanihy - 回复
Its again waterproof when you change iphone 7 battery?
Jon - 回复
I don't have a microwave???
Joe Blow - 回复
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - 回复
can i use just ordinary microwave???
juneseok kwon - 回复
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - 回复
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - 回复
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - 回复
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - 回复
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - 回复
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - 回复
30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
60 seconds in the microwave, the iOpener burst.
I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
K
Karl Marble - 回复
  • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个避免碰到中心热的部分。
  • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
Will a hair dryer work for heating the glass?
Me berg - 回复
Yes, as does a heat gun.
anonymous 4602 - 回复
I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
Cobus de Beer - 回复
  • 将你的手机正面朝下放置。
  • 如果手机的玻璃面板已经碎裂,请在拆卸过程中用胶带固定住整个面板。
  • 将iOpener放置在面板上约60秒以融化固定玻璃面板边缘的封胶。
  • 移动iOpener以加热剩余部分的面板,同样需要60秒。
  • 吹风机,热风枪,或者加热工具也许都会用到,但是千万不要过度加热手机——OLED 屏幕和内部电池都会容易热损坏。
are there any option out there that allows you to heat the adhesive outdoors without any power plug?
Brotan Store - 回复
There's a star in the center of our solar system, you could try that.
John Joiner -
the way we do it at Get it fixed cellphone repair calgary is with a heat gun, wich is way easier than this, make sure to wear some gloves and dont worry to use to much heat as long as you point just to the back of the phone, (the back panel is thick enough to protect the logic board from over heat) instead of the usual blue plastic piece i sugest to use the thinnest metal razor knife and a business card so you can insert the business card and move it all around the frame, those blue plastic things are way too thick that will break the glass panel if you apply to much pressure
get it fixed - 回复
After did that with my own heat pad, the white paint got ripped off but luckily glass back cover did not break. So I scratched all white part of the back cover and now its all transparent.
Jae Chung - 回复
I used a purpose built heating device at 100 degree celsius. Lower temperatures didn't work.
ken - 回复
  • 将吸盘紧紧吸在后部玻璃面板的下部。
If the rear screen is cracked/smashed, you will not be able to use a suction cup to remove it. The suction could would not seal because of the cracks. I tried masking tape, 3M shiny HVAC tape, and others, and the suction could would not seal to those surfaces either.
I ended up using the sharp point of the smudger to remove some shards of glass to get underneath the cover to leverage it up and out. Definitely use gloves and safety glasses if you have to do this.
dougpender - 回复
Thank you for your comment. I needed to see this particular instance of what to do when the back cover was cracked. I was going to try to suction it with tape covering it. This saved me some heartache. You're an angel!!
Jessie Brooks -
  • 本步骤还使用了一个塑料撬片,用来将后部面板从中框分离。如果双面胶的粘性仍然很强,用iOpener再加热一次。
  • 使用吸盘在面板中部用力,旋转你的手腕向上拉后部的边缘。
添加评论
  • 当你打开一个够大的缝隙后,在后部玻璃面板和中框之间插入一个塑料撬片。
At this stage I didn’t use a plastic pick as I think they are too thick and will crack a screen that’s not already cracked. I used a stainless steel
I sesame blade which does a much better job of cutting through the adhesive. Just be careful not to insert it in too far. I sometimes put a mark on my blade to ensure it doesn’t go in too far.
Wayne Lyell - 回复
  • 将塑料撬片绕后部玻璃面板的底部左侧滑动。
添加评论
  • 将塑料撬片沿着手机的电源按钮一侧滑动。
添加评论
  • 将塑料撬片沿着手机顶部滑动。
添加评论
  • 将塑料撬片沿着手机的音量按钮的一侧滑动。
添加评论
  • 按住中框,向上拉后部玻璃面板将其与组件分离。
    • 如果由于双面胶粘性太强,用塑料撬片在玻璃下面滑动数次。
添加评论
  • 在后部面板和中框之间插入塑料撬片。
  • 沿着手机的顶部滑动撬片以清除剩余双面胶。
  • 扭动撬片以分离两部分。
添加评论
  • 此时,后部玻璃面板应该完全从手机上分开。双面胶可能仍然会粘附在两侧上。
  • 拉开后部面板,然后完全分离它们。
  • 参考此指南以重新安装后部玻璃面板。
You should note that the adhesive strip may need to be fully removed from the frame in order to proceed with repairs. The adhesive on my phone covered all of the screws exposed in the next step.
Sean Cruz - 回复
  • 卸下13个3.5毫米用来将中框固定在手机上的Phillips #00螺丝。
Make sure you do not mix up these thirteen screws with a hidden 14th screw under the mid-frame chassis, on the left side of the headphone port, on daughter-board. This 14th screw is shorter than the other screws, so make sure you do not replace it with one of the longer screws. It will push up against the front glass and lift it away from the adhesive.
David Whyte - 回复
  • 紧紧地抓住中框组件的边缘。
  • 向下推电池的同时抬起中框组件,以将其与手机的剩余部分分开。
FIRMLY GRASP IT! - Patrick
Armen Orbelyan - 回复
Bei diesem Schritt sicher sein, dass SIM Card Fach entfernt ist!
zikal - 回复
I found the glue still very sticky here, i had to go around with my picks to free it, its very stuck with a UK version, beware!!
databeat1 - 回复
I damaged my screen here a bit, be careful not too slide your pick between the digitizer and the screen.
Anton -
i suggest to apply heat on the corners of the front screen to lose the adhesive a lil bit and push from the bottom back of the phone right where the wireless charger is because of the charging port
get it fixed - 回复
When grabbing from the bottom, you fun the risk of damaging the charging port and headphone jack. I would suggest starting from the top. This is because the two ports at the bottom slide down into the frame. There is also adhesive that will give you a little resistance.
Alex Philip - 回复
Step 18 is not correct, you have to start from the top. You can damage the charge port
Daniel Yaben - 回复
On mine the adhesive actually tore away part of the colored film on the back of the screen glass rather than separating from it. I’m guessing applying heat to the screen corners first would help avoid this (I didn’t). https://imgur.com/a/V7vZQ
Brian Hardie - 回复
  • 抬起中框将其与手机的剩余部分分离。
what do the numbers ZF-N2 AS WELL AS (F13) AT THE END OF THE MODEL NUMBER, THEN THERE IS REV 5-1-C W G 15221............... WHAT ALL HAS TO MATCH WHEN REPLACING THE MID FRAME.
mike gentry - 回复
  • 使用撬棒的平端从主板的插座上断开电池的连接器
添加评论
  • 在外壳和电池之间插入塑料撬片。
    • 尽可能小心,并保持塑料撬片平整插入,以避免弯折电池,否则可能会损坏电池并使其释放危险的化学物质。
  • 将塑料撬片进一步推入以将电池与手机分开。
    • 如果电池被太牢固地粘住,无法将塑料片插入,请将加热的iOpener放在电池上来松开粘合剂。
    • 另外,在电池的每一个角落都涂上一些异丙醇,让它们作用几分钟,以溶解粘合剂。
    • 不要撬动主板,否则可能会损坏手机。
Do you have to remove the battery to remove the motherboard? I just need to remove the motherboard for soldering.
Jake - 回复
No, it is not necessary to remove the battery.
cityzen -
However, it makes it easier to handle the phone with the battery taken off.
Ben -
I used a trick from a different phone tear down, but it really helps, slip a length of dental floss under the top edge of the battery, then with a back and forth action of the floss, you can slice through the adhesive and easily remove the battery, worked great on this phone.
danechapman - 回复
Dude that's awesome, wish someone would have mentioned this a long time ago. Battery removal can be a pain. Defiantly going to try that sometime soon!
Felix Robinson -
  • 把电池从手机中取出
  • 不要重复使用拆下来的旧电池,因为这是一个安全隐患。请用一块新电池来替代它。
  • 安装新电池:
    • 从手机中去掉任何残留的粘合剂,并使用异丙醇和无绒布擦拭粘合区域。
    • 用预切割粘合剂或双面胶带固定新电池。为了正确地定位,将新的粘合剂安放在电话中,而不是粘到电池上。粘合剂应该围绕电池隔层的旁边,而不是在中心的矩形切口(实际上是显示屏的背面)。
    • 将电池牢牢地按住5-10秒。
Question!? If the screen is barley cracked at the coner, (2cm) of the phone, would it shatter thru this process!? Please let me know ASAP!?
dominiquem1991 - 回复
again, mine a UK version was very sticky beware!!
databeat1 - 回复
Yes the UK version is very well glued in. I recommend using a flat metal spudger and pushing it in from the bottom right side and then continue doing the same working up. This method seems to be the safest and only takes a minute or two
martywild10 -
I used a credit card and a bit of hair dryer to ease it out.
adele - 回复
结论
参考以下步骤的相反方向重新组装你的设备。当你重新安装后盖玻璃时,请参考更换后盖玻璃粘合剂指南
215等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Dante Mazzanti
于2015年07月13日注册
29,577 信誉积分
创作了131篇指南
If I had known that replacing the battery was this complicated I would have never bought Galaxy s6.
barb kory - 回复
Mcgyver variation: guitar pick, safety pin, hair dryer, and a west marine camera mount kit's suction cup. got it.
devcyr3n - 回复
Do ya THINK this process MIGHT void your warranty?
peteyfurlong - 回复
weird question , if its under warranty , why would anyone go thru so much trouble just to replace a %#*@ battery
limz555 -
Samsung warrenties are rubbish. Only had the phone 6 months and the charger point broke but bacause my phone had a small crack on it they voided the warrenty and wanted me to pay nearly £200 to replace the screen and back!!!! Now the battery has gone completely- phone is only 8 months old and no use. Safe to say won't be having a Samsung again.
Cathy Vickers -
In the United States it's actually against the law to void someone's warranty because they opened their device up, unless they make any unsupported modifications which are the sole causation of the damage/defect.
Christopher Engelhardt -
I have been trying for 3 days to get the phone open...using all of these instructions and tools. No luck! %#*@!
sailr - 回复
What step are you stuck on?
Evan Noronha -
I've encountered phones where the IOpener was no match for all the adhesive. I succeeded by heating them with an iron that's made for shrinking monocoat covering around the wings of radio controlled model airplanes. You can get them at a good hobby shop for ~$15.00. It's shaped so you can heat around corners and comes with a sock to keep from scratching anything. That method always defeated the adhesive for me.
David Blythe - 回复
If you are using a heat shrink iron as David commented above, keep it in contact with the phone for the shortest possible time required to soften the adhesive. At their highest settings these irons can reach over 200 degrees C (around 400 F) which is hot enough to damage flat cables, and distort or even melt plastic components inside the phone.
mlewus - 回复
The recipe is quite good and easy to follow.
But you should buy the the adhesive film and use it to fix the body again because the old one you have to destroy to handle the screws.
This film you can by at Amazon for 7,50€ and it was delivered within 2 days.
Winfried Vogel - 回复
Guys I had the same problem. For those who need to restart the S6 which is not responsive, try holding your power button and volume buttons simultaneously for more than 7 seconds before trying to remove battery which is btw mission impossible 15.
Akica - 回复
Thanks Akica, for your tip. It worked! Had S6 for 18 months and never had any problems until now but didn't realise such a palaver required to take the cover of a phone!
rosemary_mcdonald -
it worked thanks
alaa sassi -
This is why it pays to read the comments! Thank you! Totally worked and saved me a huge headache!
Ell -
This is why it pays to read the comments! Totally worked and saved me a major headache! Thank you for sharing! :)
Ell -
Thanks for the guide! I haven't done it yet as I don't need to, I was just checking to see how hard it would be to replace my phone battery so I would know if I would really have to baby the thing haha...this is a great guide, which I would have no trouble following so my mind is at ease.
Clayton Boyle - 回复
The replacement battery doesn't come with adhesive strips. How can I stick the replacement part down? Can I use those adhesive strips for iPhones? Or clear double sided tape?
Ben Adelie - 回复
Either of those options should work. I'd be partial to using iPhone adhesive strips to make the battery easier to remove the next time around.
Evan Noronha -
Do you if coaxial antenna cable from s6 edge works on s6? I managed to broke it and i dont find to buy for s6.
Tracke - 回复
Hi i am looking for the battery for my Samsung S6 at the moment is out of stock so how long I have to wait?
Bobby Nguang - 回复
Once you get to removing the battery there is some adhesive holding it in place. It is probably a good idea to replace this so the battery does not move around, I used a small amount of UHU all purpose glue.
DO NOT USE super glue as this damages the plastic covering of the battery.
David Foley - 回复
Just did this today. If I had to add anything, you need a LOT of heat, and a VERY thin guitar pick to get between the glass and the midframe. I had to get the back panel to around 100c before the adhesive would give way, a lot hotter than I usually need to get most things apart (75-80c is the norm). Be careful not to burn yourself whilst you're doing this. Also, a larger battery will fit in here! Apparently S7 batteries can fit in the S6, but do your research online before you attempt this.
Stephen De Tomasi - 回复
good post. useful information to phone users of Samsung s6
Chiru S - 回复
Use a purpose built heating pad at 100 degree Celsius eg; https://www.aliexpress.com/item/Uyue-948...
ken - 回复
first time I have attempted this for my Samsung S6 and worked perfectly. I used a hot air gun... at max 110 degrees Celcius. Took about 30 minutes. cheers!
Mark - 回复
Hi, would you recommend changing the battery or just buying a portable charging dock? I'm torn with what to do. I want to change the battery but don't want to damage the phone. Thanks.
Mel Broadwood -
looks like samsung are going backwards, simple to change a battery on my S3
Barry Cook - 回复
Iopener is a joke. Not near enough heat.
Scott Conover - 回复
So before I changed the battery my phone was on 60 percent..then once it was replaced with a new battery it was still at 60 percent..Can anyone tell me if thats good, bad, etc.
Jordan Sanchez - 回复
hi! ive just finished replacing the battery after using your method. it worked perfectly! however, now im having problems trying to get the screen on. i placed the phone on charge (as the new battery would need charging) and i attempted to turn it on after 30 mins. The first time i pressed the power button, the blue light at the top came on, the buttons at the bottom near the home button lit up and i heard the samsung start up sound, but nothing showed on the screen. the second time i pressed the power button (while battery was still being charged, the bottom buttons, again, lit up and the red charging indicator light remained on but i didnt get the samsung start up sound and the blue light as i did the first time. Is this just an issue with the battery not being charged still or is there possibly something wrong with the connector on my motherboard?
Any help would be greatly appreciated!
Tyranique Thurston - 回复
Just swapped out my battery… took about half an hour for me too. I would recommend a hair dryer over the heat pad they give you. Put the hi dryer on high and steadily went over the back panel for about 3 to 4 minutes moving medium slow…. I used the adhesive that I bought for the phon that matches the frame, but t had to buy on amazon for it. Also, needed just a bit of double sided tape to put the new battery on in place.
Overall though it’s a great kit and instructions!!! Gonna have to do another Samsung 6 soon, but the cost for the kit andbatteries is way cheaper than anew phone or the $120 to have someone do it for me. Though I am technically very capable to do the repair, anyone should be fine doing it if they can use a screw driver and just take their time.
Scott Boskovich - 回复
What the &&^&, are you joking with this $@$*? If you need to remove a phone's battery, it should just be a hands-only process, not some hour long ordeal with specific tools that are useless for any other job. What brainless douche came up with such a pain in the ass design for a phone? Ridiculous!
sgt ROCK - 回复
This was super easy to do. The kits on Amazon fit perfectly. Used my hobby iron and went around the edges for about 3 minutes set at 100C (212F) and everything came off real easy with no damage to anything. Took about 40 minutes to do, which included cleaning up the old adhesive and the phone before reassembling. Well worth the effort versus buying a new phone, the new battery is just like the day I bought it.
HockeyDad - 回复
The battery swap is complete, but the screen now is only black, with a momentary flash of a green box when the power button is pressed. Holding the power button/volume button simultaneously has no effect. Could this be a broken screen problem?
Michelle - 回复
Hair drier didn’t work that well for me and I ended up breaking the back, but at £3 on eBay I considered this a small price to pay for less messing about and a quicker fix if you buy it in advance
Tezza de Grey - 回复
You can put the S7 Edge battery into the S6. Fit exactly perfect!!! You can read some review serching in internet
Daniel Yaben - 回复
Hello. My S6 felt in the sink (full of water). Unfortunatly the rear facing camera glass (from the frame) was broken. Couple of water got inside. Already passed a few days, putted the S6 to dry (even in rice), but it still doesn’t power on. Pretty sure it short circuited somewhere. I’m considering replacing the battery and the rear camera. Do you think I have any chance?
presi - 回复
I also wouldn’t have bought this phone if I’d known how hard it is to do the routine maintenance of replacing the battery. Since this is rated as difficult, I was afraid to attempt it myself. I took a new battery and adhesive strips to a local repair shop, SecurePro in SLO, where someone who’s done this many times turned it around perfectly in under half an hour. No more range anxiety!
Cynthia Replogle - 回复
Wasn’t too bad- my only problem / tip (?)- the rear glass on my phone had semi-shattered, so prying the rear cover off caused a few more breaks in the glass- and crucially, the glass seperated from the opaque film backing rather than from the phone. meant having to remove the backing and glue. Which was fine- I didn’t mind having the rear glass broken before but now it is transparent! which actually looks super cool. Great guide.
Hugh Roche Kelly - 回复
Out of curiosity - I replaced the battery with the kit from IFixIt - production date of new battery was early 2018.
Battery is now used for 2 months - and has a capacity of close to 0. So it last for 1/4 day without any interaction; phone typically drops dead at around 40% of the battery. A reboot then shows 0% battery.
Has anyone seen similar behavior.
I’m wondering if replacing the battery jet again makes sense - or if all S6 batteries (even the replacment kits) are just crap.
Nico - 回复
添加评论
浏览统计数据:
过去的24小时: 422
过去的7天: 2,854
过去的30天: 13,299
总计 433,294
