简介
参考视频
视频概述
加热手机背部边缘,来使得撬开时不会开裂。使用许多撬片来切割粘合剂,在必要的时候花些时间来对手机重新加热。
  • 加热手机背部边缘,来使得撬开时不会开裂。使用许多撬片来切割粘合剂,在必要的时候花些时间来对手机重新加热。
添加评论
取下标注出的螺丝。
  • 取下标注出的螺丝。
添加评论
  • 移除中框。
添加评论
  • 小心的在电池下方滑入一个撬棒或者薄而坚固的东西。 电池左右侧有粘合剂固定,切勿强行打开,这样会损坏屏幕。
  • 小心缓慢的将两侧的粘合剂割断,当完成后电池应该能够很容易出来。
  • 当粘合剂被切割后,电池应该很容易被取出,然后您可以放入新的电池了。
添加评论
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
68等其他人完成本指南。
特别感谢这些译者︰
25%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Sophia
于2014年03月25日注册
40,558 信誉积分
创作了62篇指南
Hi , Sophia
The Back Case after heating, will it be fixable without any adhesive solution
LOGESAM - 回复
Yes if you over heat the back for a long time. If you just heating it up to remove adhesive you should be fine.
Constantino - 回复
This is ridiculous. I don't know why they changed it so that you can no longer open the back cover and change your battery and expand memory. My note 4 broke and the insurance company railroaded me into getting a 5 because they didn't have the 4 in stock and didn't think they would be getting any more. I'm so upset. I want my money back.
Helena - 回复
That is exactly what they did to me, and they acted like they were doing me a favor.
Kathy -
Lol...note 4 from Asurion isn't a thing anymore for Insurance.
Why are you so mad? it's a HUGE upgrade because your itty bitty battery doesnt just fall out???
get real lol.
cooley -
I feel your pain! This "huge" upgrade is more like a HUGE rip-off! Samsung HAS replacement batteries but REFUSE to sell them to the public so they can charge $70 for you to ship it to them, not knowing what they will do with it ... ex: drop, crack, erase info, then send a "refurbished" phone back instead of your mint condition phone. I'm mad! I want to buy the battery form them and do the replacement myself but they REFUSE so they can take us for more money. NO MORE SAMSUNG FOR ME!
Lucky Lady -
There is a reason why they did this. They can track you as long as the battery is in the cell. If the battery is out they cannot track you. Therefore, if you cannot remove the battery even though it is off, they can track you, listen to you, etc. They have this technology and have been using it for a long time, Helicopters doing surveillance on those they want to know what their doing, by having this they know exactly what everyone is doing and where they are at any time. Not just for criminals.
Lydia Brockmeyer -
Would doing this void my warranty?
Willie contreras - 回复
Ofcourse it will void your warranty..You seriously think opening up fixed battery wont void your warranty lol..
Asad Malik -
By the time you need a new battery, your warranty will be out anyway most likely.
Kathy -
is the battery linked in this post the same one that comes in Note 5 stock? i'm hesitant to buy a battery that might be worse than i currently have.
paul - 回复
Yes the battery is OEM
Jade Davis -
Are there any problems which might arise if I change my note 5's battery?
shayminimyahs - 回复
I installed a new battery and my note 5 never turned on. I re-installed the old one and do not turn on. :(
What I can do nex?
Virgilio Munoz - 回复
check the connections when it plugged in to the main board, see if any prongs are bent or broken. Make sure there are no tears in the ribbon from the batteries.
Dustin Gonzales - 回复
Is there a way to get a larger capacity internal battery? Google has not helped me one bit in the matter. I would like up up the 3000 mah if possible, I don't care if the phone is thicker. I have a 4hr lifespan with 3000 mah at 100% charge right now...utterly terrible.
joinhalo - 回复
I also am having to charge my phone every 3 to 4 hours. Terrible!
dgpaul - 回复
I swapped the battery and saw 24hr use with normal usage. Old oem battery had blown up and was all lumpy. Amazing how much better it is. I don't know how not to break the glass whIle removing the back cover though, would recommend buying a spare back cover just in case since it breaks easily.
joinhalo -
dbpaul, best way to avoid damages is to heat the back cover area and use 2 suction holders. 1 attached to the LCD and one to the back cover. gently pull them appart and the glues will begin to seperate. you can get them on this site for ~$3 a piece.
Suction Handle
Product code: IF145-361
Dustin Gonzales -
What tool are you using to heat/melt the adhesive? I tried using a hair dryer but it did not work :(
Newton Berwig - 回复
Are there any performance issues (ie. Lost info or app data?
Robert - 回复
Thank you so much (: i had to buy a heat gun from my local hardware store the blow dryer just didnt get hot enough . The most difficult part of this process was removing the actual battery it didnt just pop out like the video . it was glued in place i couldn't just rip it out either becaue the screen was on the other side i didnt want to yank it around to much and crack the screen underneath. but i slide a thin card and seperated the glue from battery (: yay all fixed !
mooberries25 - 回复
Hi I need you help!! im planning to buy a replacement battery for my note 5 n9208 but the supplier only has n920 will it be fine to use it? pls i need your prompt reponse.. thank you so much in advance
lem_bads - 回复
I've tried using blow dryer and it doesn't loosen the glue at all. I have a heat gun, but won't it damage stuff inside?
littl-bit - 回复
This is ridiculous...I have heated my phone til it burns my fingers and the glue does NOT release at all. And the hotter the phone gets, the worse the suction cup works!!!! Waste of $ for a battery I can't use!
littl-bit - 回复
Will you have to replace the back if it is cracked when you take it off?
Derrick hardin - 回复
Will you have to replace the back if it is cracked whenever you take it off to replace the battery?
Derrick hardin - 回复
I just did a battery replacement on my dad's refurbished note 5. Getting the back to 450F was enough to seperate it. Do not use a small suction cup. Find something that takes up alot more surface area so you don't have to pull as hard. If your back does crack buy a replacement one its like ~10$ and mine came with pre-applied adhesive.
Matthew Dela Cruz - 回复
I have a Note 4 and want a 5. Can I permanently remove the adhesive from the cover to help aiding the removal process? The phone won't get in the water anyway. Adhesive seems like an overkill.
Tony - 回复
I wouldn´t do that in advance, because it may damage some part and the phone is not waterproof and dustproof anymore.
Claus Gärtner - 回复
My Note 5 Needs a new battery would it be worth it to buy one? seems really complicated to replace, Or just go through insurance for a refurbished phone. I really like my Note 5 there offering me a Samsung galaxy s7 edge, for replacement if I choose to. they dont have Note 5's
Heather - 回复
Hello Heather,
I would recommend you to go through insurance. Its a pity of course to loose the favorite phone, but the repair action isn´t easy. If you don´t have experience on such kind of action, you maybe damage your phone.
Claus Gärtner - 回复
I changed the battery and but forgot to take out the sim initially. I checked the sim on other phone and thats working ok. But on this phone, no sim is getting signals or registered... any idea.. did i spoil something?
Ali - 回复
Did you check the contacts in the phone for the sim? Are they in a good condition und clean? Try to clean them with a clean piece of cloth and a litte amount of alcohol on it.
Claus Gärtner -
Thanks, Sophia, I think your post has convinced me to stick with my Note 4 and not upgrade to the 8. I understand why manufacturers are moving away from replaceable batteries, but I sure don't like or agree with it.
Rick S - 回复
Is samsung galaxy note 5 a strong phone to use, does the battery last?
Harry Gillis - 回复
Is samsung galaxy note 5 a strong phone to use, does the battery last longer, pls wats the major problems with this brand?
Harry Gillis - 回复
What going do u use to glue faces of note 5 back on?
Scottprideaux@gmail.com
Scott Prideaux - 回复
I just put all the firmware and software for the Galaxy 8 on my Note 5 so it acts just like an ant but it doesn't have the hardware but it still got a lot of new cool stuff for free
Scott Prideaux - 回复
Stupid speak text it acts just like an 8 not an ant
Scott Prideaux - 回复
Grrrr lol, my first Note 4 and i cracked the digitizer and glass. I cracked them by gently pushing on the back of the battery so the sub-chassis could come out. Next time i’m putting the heat gun on Volcano to melt that %#*@ glue!! :-)
Aaron Tremblay - 回复
Grrrr.!!! I broke the screen and digitizer while gently pressing on the back of the battery so the sub-chassis could come out, but no, it didn’t come out. So, next time i’m setting the heat gun to Volcano and melt that glue the heck out of there!!! :-)
Aaron Tremblay - 回复
Thanks ,++Heat Gun++ setting temperature is?
zhangyang - 回复
These are some of the stupidest comments I've ever read in my life Samsung enclosed the housing to keep water in moisture from getting inside of the device seconds the Note 5 is a huge upgrade compared to this shity ass Note 4. And the expandable memory saying that's why they make Dropbox yes Samsung did not put expandable memory in this phone because they wanted everybody to buy the next model and yes that is kind of shity of them but they send signals and updates to your phone to slow it down so that you get the next phone. The reason being new technologies are coming out and they can't continue to produce old technology when they are making new technologies it's the wave of the future get used to it or don't use a %#*@ cell phone
Spencer - 回复
Sticking to my Note 4, after seeing these comments on remove/replacing the battery.
Tony - 回复
I did it! Only casualty was the back case but I found an OEM on Amazon for that at 13 bucks. Since I use the Samsung S-view case, I am able to use my phone immediately. When the new back comes I will put that back on. Thanks Sophia!
Terry Kraft - 回复
This will be my 3rd battery replacement. Once you do it its not so bad, the factory outside shell was a major pain but my replacements have come off very easy and I did NOT have to replace it. 2nd battery was bad. 3rd was oem VERIZON compatiable MAKE SURE you get the battery for your service provider (att/sprint/verizon/etc..) it does make a difference, there are dozens if not more batteries out there.
THANK YOU FOR THIS TUTORIAL IT WAS SPOT ON EASY TO FOLLOW!!!!! Much easier than youtube
joeykbarry - 回复
添加评论
浏览统计数据:
过去的24小时: 99
过去的7天: 789
过去的30天: 3,546
总计 178,832
