视频介绍
终点
26等其他人完成本指南。
ian mdx
于2016年06月30日注册
6,166 信誉积分
创作了16篇指南
Good video!!
Mandy - 回复
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - 回复
Please answer, what is the glue you used in the video? Thanks.
tcatt - 回复
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - 回复
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
lightmeupper - 回复
I mange to replace the screen and start the phone up. But now the power Button dosen work. Whan can i do?
Johan Fritiofsson - 回复
So i just had to put the screws in again… Puh
Johan Fritiofsson -
添加评论
浏览统计数据:
过去的24小时: 78
过去的7天: 564
过去的30天: 2,688
总计 52,959
