简介
Battery Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty battery. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some soldering and desoldering tips.
Remove the brush head by pulling the top away from the base.
  • Remove the brush head by pulling the top away from the base.
Pry open the end cap from the toothbrush body. Remove the spring. Remove the spring.
  • Pry open the end cap from the toothbrush body.
  • Remove the spring.
Apply pressure on the brush shaft to release the toothbrush internals. Remove the internals through the bottom of the toothbrush body.
  • Apply pressure on the brush shaft to release the toothbrush internals.
  • Remove the internals through the bottom of the toothbrush body.
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
Use flat head screwdriver to remove power button pressure plate. Use flat head screwdriver to remove power button pressure plate.
  • Use flat head screwdriver to remove power button pressure plate.
Desolder the coil wire from the motherboard. Check out this helpful guide for some soldering and desoldering tips. Squeeze and remove coil from motherboard.
  • Desolder the coil wire from the motherboard.
  • Squeeze and remove coil from motherboard.
Desolder the motor from motherboard. Remove motherboard and battery from body of toothbrush internals.
  • Desolder the motor from motherboard.
  • Remove motherboard and battery from body of toothbrush internals.
Desolder the battery connections from the motherboard. Remove motherboard from battery holder.
  • Desolder the battery connections from the motherboard.
  • Remove motherboard from battery holder.
Pull to slide battery from battery housing. Remove battery.
  • Pull to slide battery from battery housing.
  • Remove battery.
结论
另外一个人完成了本指南。
Carl Kinsey
自 2017年11月08日就是会员了
119 信誉积分
2撰写一个指南
团队
IUPUI, Team S5-G4, Baechle Fall 2017 IUPUI, Team S5-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G4
3 名成员
4撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 13
过去的7天: 60
过去的30天: 110
总计 128
