简介
In this guide, some soldering is required when disconnecting the battery from the motherboard. If you are unfamiliar with soldering, watch Soldering Tutorial for Beginners, Five Easy Steps to familiarize yourself and to be able to correctly replace the battery.
Make sure that the OontZ Angle 3 is powered off before starting the disassembly. Use the plastic opening tool to remove the rubber caps from each end of the speaker. Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
  • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece. Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
Begin by removing the bottom piece, revealing the inner compartment with the speaker cables and battery. Remove two (2) 11.7mm Phillips #0 screws from each side of the speaker plate. Remove speaker plate from the front of the battery.
  • Begin by removing the bottom piece, revealing the inner compartment with the speaker cables and battery.
  • Remove two (2) 11.7mm Phillips #0 screws from each side of the speaker plate.
  • Remove speaker plate from the front of the battery.
Locate the soldering points for the battery on the motherboard face of the speaker. Use a soldering iron to carefully disconnect the battery from the motherboard. Learn more about soldering here.
  • Locate the soldering points for the battery on the motherboard face of the speaker.
  • Use a soldering iron to carefully disconnect the battery from the motherboard.
    • Learn more about soldering here.
  • Remove the battery from the inside compartment for replacement.
  • Be careful when soldering the new battery into the correct position on the motherboard, as a bad connection can cause the battery to overheat or catch on fire.
结论
5等其他人完成本指南。
Mason Hollander
自 2016年01月20日就是会员了
748 信誉积分
4撰写一个指南
团队
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G6
4 名成员
4撰写一个指南
What is the kind of battery used? Thanks!
Rodrigo Lopez - 回复
Hi Rodrigo, the Oontz Angle 3 uses a rechargeable 2200mAh lithium-ion battery. Happy Fixing!
Kelsea Weber -
the one that I have has a "circuit board" attached to the battery. Is this what controls the recharging? If so, where do you get the battery with these?
Rob - 回复
Hi Rob,use soldering iron disconnect the circuit board which come with old battery you going to replace, and soldering iron the disconnected circuit board back onto your new battery. The so called circuit board is to protect the battery from over discharge or over charge. Hope this help.
benckbenck -
2200mAh lithium-ion battery...... is it the 3.7?
thezestyitalian1 - 回复
Do you know the watt hour rating for this battery?
Kristen - 回复
If you don't know the watt hour rating, can you tell me whether this battery is 2200 mAh and 3.7v?
Kristen - 回复
One can also replace the battery with what looks like a 18650 lithium-ion sized battery; they range in size from a minimum from 2,200mah to 3,400mah; so technically one could also upgrade the lithium-ion sized battery up to the maximum 3,400mah size and thus upgrade oneself from 10 hours continuous play to 15 hours of continuous when one uses the 3,400mah sized lithium-ion battery instead of the 2,200mah lithium-ion battery.
Dennis Lee - 回复
Hi! Can i use 3.7 volts rechargeable battery for this?
Egie Manlunas - 回复
Trying to change a battery on a oontz xl,,,How do i open it for repair!?
Daniel Dejesus - 回复
Trying to change a battery on a oontz xl, how do i open it for the battery swap. Thank you!!
Daniel Dejesus - 回复
添加评论
浏览统计数据:
过去的24小时: 13
过去的7天: 117
过去的30天: 415
总计 6,244
