简介
硬重启、恢复出厂设置:删除所有用户数据,包括通讯录、下载的文件、帐号等、并删除所有用户安装的程序,以及将所有设置恢复到出厂设置
此操作仅适用于忘记锁屏密码或者手机无法开机等情况,切勿轻易尝试,除非你是刷机狂魔,对数据一点都不在意。
方法:关机状态下同时按住【音量-】和【锁屏】直至手机开机并显示一个叹号放开,然后依次按下【音量+】【音量-】【锁屏】【音量-】,出现熟悉的齿轮转动即开始恢复,稍等几分钟即可
视频:如果有梯子可以看看
视频概述
关机
  • 关机
  • 按住音量下键并连接充电器。当你看到一个感叹号shi松开按钮。
  • 现在按下这个顺序的按键:
    • 音量上键
    • 音量下键
    • 电源键
    • 音量下键
  • 手机将重置并重新启动。
Please help me i have problem resrting my phone..
kier jumento - 回复
Are you really?
eyobe - 回复
what a great Method .it work ........... thankx for genius method
usmanmanga85 - 回复
please help, I just did the hard reset but now it's denying my microsoft account login...
i did the reset but failing to login my account and now I cant do anything. Im stuck on the sign in page...
Chido Marufu -
i did reset but now cant login and cant access anything...
Chido Marufu -
Chido Marufu -
my phone cant touch anymore i hve microsoft mobile rm-1089.after hard reset the phone reboot and stuck at language selection no touch at all been hard resetting over and over. .any help?
bedelfever - 回复
bhai mayra nhi ho rha
ns890157 - 回复
it worked thnks ilove the tips
dex vin - 回复
Approximately how much time is it supposed to take?
Aashka Vora - 回复
This not working what else can I do?
Oluwakemi - 回复
Thank you so much you r great. I have done.....thanks
Rakshit - 回复
fantastic.Thank you so much
Kirti Sethia - 回复
fantastic.Thank you
Kirti Sethia - 回复
Awesome…Thank You so much…
Bipin Bihari Sethi - 回复
After I press the volume down key and insert my charger no exclamation mark appears so what do I do??
Richard Donkor - 回复
I am re start the phone as per instructions but the phone will not be open.
Still the exclamation mark appears
What I do?
Siva ganesh - 回复
total sucess
CPI - 回复
I followed the hard reset procedure, but when I press the volume up button, the phone goes off. I have not had the chance of pressing the other buttons. Please help me if there's any other method. Thanks
Lawrence Kumah - 回复
Very well... Thank you...
Ankita Kar - 回复
How do i cancel the hard reset?
Yadira Ruiz - 回复
Thanks exellent!
sunethwbs - 回复
resetting in progress. Thanks
Benjamin Bara - 回复
wa za mara da kho mata yada wa
niamatullah123 - 回复
结论
你的手机已经恢复出厂设置了
135等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
ZFix
于2013年12月09日注册
157,324 信誉积分
创作了304篇指南
团队
Master Techs Master Techs 的会员
Community
277 名成员
创作了751篇指南
thanks a lot!!
very useful!
suchitra kumar - 回复
You are mouthed
Idris - 回复
THankx for your help..
Pinak - 回复
but my mobile timeing was 107 and this step are not work that
shahaji jadhav - 回复
same with me.
can you help me? I try the step but is not work in my mobile timing is 790880. how to remove those screen password?
Alden Hammisain -
worked for me...thanks
erick - 回复
It really worked for my Microsoft Lumia 535. Thanks
Tiamiyu Babatunde - 回复
how did you do it because mine turning on as soon as l press the volume up button
alfredjunior -
Thanks A lot. Saved my day
Shivam Jain - 回复
When i press that button nothing happen to the phone it only starts..
kier jumento - 回复
When i press that button the phone starts and nothing happen
kier jumento - 回复
did your work out
alfredjunior -
thanks, worked for me
Humphrey Tamata - 回复
when I followed what you have stated, my phone could not load up the exclamation mark but shows battery charging sign
jobstevegimisimo - 回复
Answer to skipping ! Symbol and going straight to battery charging symbol?
Albert einstine -
Good Way Thankx.......
Shahid Muhammad - 回复
It worked greatly thank you very much it is greatly greatly appreciated it was just as simple as it is explained!!!
Tifani Hill - 回复
worked for me thanks man.
Will Hanson - 回复
thank you very much for a wonderful solution.
satya033 - 回复
i followed the same instructions, but when I press the start button my phone switches on and goes back to the password locked screen.
Jyoti Raj - 回复
Thats what mine is doing did u find a solution
Shamekia Mitchell -
Thank you...saved my time
Fredrick Omondi - 回复
Não resultou... Fica em loop mostrando as engrenagens e depois uma carinha triste
Que posso fazer para voltar a ligar o telemóvel??
andreiapanatal83 - 回复
You knw Actually the lock has been broken but i duano what is next step mean while it's asking to fix some point for which look forward to get this done.
Akash Kumar - 回复
%#*@ it actually worked
Alex Teano - 回复
it is not working on my phone pls tell me another solution
AJITH TV - 回复
thank you bro........
laltu chowdhury - 回复
very useful guide
haprotege2020 - 回复
Thanks for your very good information
b17karthik - 回复
did we lost win 10 switch back to win 8.1 from win10 after factory reset?
my lumia 535 face screen freeze and some time auto power off and power button not working problem
when I press power button it show dim light and black screen again and also got heat up from upper front back side
the only thing work in these issue is remove back cover put off battery put in again
hasan_rameez - 回复
Very Useful.........
gauravmalikbro - 回复
The author did an excellent job that deserves commendation.The steps were so easy and straight forward
Alabi Tajudeen - 回复
good on ya mate thanks for trick
emreozcicekci - 回复
Wow thank u my IT It's work for me from Ernest tnx an tnx again my god bleessd u
bongs_72 - 回复
Tnx my IT its worked for me
bongs_72 - 回复
lumia 535 copied recovering mode
ashleys69 - 回复
thanks to ya, it really worked............. thanks to the crew
bi jay - 回复
Chido Marufu - 回复
It works for me lumia 540 thanks a lot....for your valuable suggestion..
Raghu Raghu - 回复
Thanks a lot it really work for me......kudos
philipbrown6743 - 回复
I try it but it really really and extremely work for me thanks a lot
awesome it really works. thanks alot
henry fundi - 回复
My phone appears (try again in 1034387 minutes) and could not open. Please help me. URGENT
chenthin707 - 回复
Thaaaaaank Youuuuuu soooo mucccchhh
Alber Einstein - 回复
This process is fully working if Your touch is Not working
Alber Einstein - 回复
It's like a GTA cheat code from the ps2 days, btw it worked for me :<}
Shaquille Richards - 回复
Thanks It worked
lasherrika - 回复
My friend asked me to unlock it, I just tried in search engine. It helped me at right..
Haridass - 回复
It worked thank ya vry much amigo
Abdullah Twait - 回复
thanks alot it helped.
Jolandie Klein - 回复
did that, saw the gears then went to a sad smiley, please help.
Mharc - 回复
Bohat bohat shukriya
gangaram kore - 回复
thank you sooooooooooooooooooooooooooooooooo much
IHSAN ULLAH - 回复
can I do that on my phone but it has no power
Nash Rutsate - 回复
please help, can I do that on a powerless phone
Nash Rutsate - 回复
It is working but after reset edge browser is missing old help me
Prashanth D - 回复
Cool! Other remember to remove you sceenlock first before trying this, then it will work/
Liam Decker - 回复
My phone is reset but its asking reset protection key. What can i do
Uday Urs - 回复
how much time it should take to reboot and start
VANDAN NAGAR - 回复
Whats the answer to the timeframe regaurding how long does it take fof the reset to take?
Albert einstine -
Whats the eta for reset
Albert einstine -
Thanks to the author, for his excellent work.
aparesh datta - 回复
Thanks to the author for his excellent work.
aparesh datta - 回复
Not working for me. Pls help to reset password.
Bhuvana Vaithilingam - 回复
This method Not working for me. Phone only starts. Pls help me.
Thanks…..very helpful
Lahiru Wijewardana - 回复
My mircosoft windows phone will not factory reset
Louise Hopson - 回复
You are really genious bro… Awesome…
Thanks and it works for me very nicely…
Md. Mehedi Hassan Shawon - 回复
You are a guru, genius, in fact Einstein….. thanks a lot
Dhermy Machessy - 回复
You,re great !!!!!!!!!!!
keep it going. Love you, May God bless you Sir
Raj Kamal - 回复
Cheers man…it worked. God bless
samuel kalel - 回复
Good work! works like a charm!
qash miik - 回复
Awesome! I'm overjoyed, the steps were
Kameswari - 回复
If it failed for you try it this way without the charger: Press the power button to start and when it vibrates hold the volume down button until it shows you the exclamation mark. the do the volume up down power down sequence mentioned above here and leave it aside to show the logo then spinning cog wheels. The charge route failed for me too till i found the route where you dont include the charger.
romeohammer3 - 回复
My didnt work at all
Katy Hudson - 回复
The reset worked but it is asking for a reset protection recovery key that I am not able to get
Debbie Reid-Jones - 回复
Thank you vry vry much…
vinod Tolani - 回复
thank’s dude worked bang on……
mizer006 - 回复
it’s working.. although we have it trial and error, and thank to you…
rotsennoziuk - 回复
Thank so much it really work perfectly for me
aisivbiekpen - 回复
thanks you so much.. you are awesome …..
tejipta - 回复
phone restarts when i hold volume down
can’t reset
Shubham Sharma - 回复
you are good lumia, great job done
ANANIVI EMMANUEL 18-10-2014 - 回复
添加评论
浏览统计数据:
过去的24小时: 288
过去的7天: 1,864
过去的30天: 8,437
总计 280,682
