简介
Almost every watchmaker from Casio to Rolex produces watches with link bands. When adjusting or repairing a band becomes necessary, adding and removing links with a few special tools is the only solution. This comprehensive guide will demonstrate how to properly perform such manipulations on a Michael Kors brand wristwatch.
Place the watch on your wrist  and determine whether links should be added or removed.
  • Place the watch on your wrist and determine whether links should be added or removed.
  • If watchband needs to be expanded, approximate the number of links required.
添加评论
Set the watch on the block holder. Ensure the arrows located on the links are pointing downward. Ensure the arrows located on the links are pointing downward.
  • Set the watch on the block holder.
  • Ensure the arrows located on the links are pointing downward.
添加评论
When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
  • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
  • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
  • Two pins hold each link to the band, so two pins must be removed per link.
添加评论
Discard the broken links or save any extra links that you remove.
  • Discard the broken links or save any extra links that you remove.
添加评论
To add links to the watchband, position the watch on the block holder with the arrows facing upward. Insert pins into the holes that connect the new link to the rest of the watchband.
  • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
  • Insert pins into the holes that connect the new link to the rest of the watchband.
  • Use the soft side of the hammer to strike the pin down.
添加评论
Lastly, make sure that all the pins joining the links are secured in place. Lastly, make sure that all the pins joining the links are secured in place.
  • Lastly, make sure that all the pins joining the links are secured in place.
添加评论
结论
另外一个人完成了本指南。
Jack Beinkampen
于2016年10月06日注册
145 信誉积分
撰写一个指南
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - 回复
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - 回复
添加评论
浏览统计数据:
过去的24小时: 43
过去的7天: 303
过去的30天: 1,585
总计 16,871
