简介
使用本指南从MacBook Pro中取出粘合电池。 这最好在iFixit电池更换套件的帮助下完成; 您的套件中的液体粘合剂去除剂将溶解固定电池的粘合剂,从而轻松拆卸电池。 或者,您可以使用iOpener应用适量的热量,以便在撬出电池之前软化粘合剂。
iFixit胶粘剂去除剂是高度易燃的。在通风良好的地方执行此程序。 在此过程中,不要在明火附近吸烟或工作。
为了安全起见,在开始执行此程序之前请先排掉MacBook Pro的电池。如果意外穿刺。充电的锂离子电池可能会造成危险且无法控制的火灾。
注意事项:用于溶解电池胶粘剂的溶剂可能会损坏某些塑料,如MacBook Pro的塑料扬声器外壳。 使用溶剂时要小心。
拆下以下10个固定在上壳体上的螺丝
  • 拆下以下10个固定在上壳体上的螺丝
    • 两个 2.3毫米 的梅花五角螺丝
    • 八个 3.0毫米 的梅花五角螺丝
For all the screws you use the P5 pentalobe screwdriver?
Carlos - 回复
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - 回复
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
the macbook in the picture is 2012. does it has the same structure as 2013?
Edison - 回复
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - 回复
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - 回复
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - 回复
把你的手指放在上下壳体中间
  • 把你的手指放在上下壳体中间
  • 轻轻地把上下壳体拉开
添加评论
上下壳体中间有两个塑料卡扣相连 在组装期间,温柔地从中间推下机壳,重新扣上这两个塑料卡扣。
  • 上下壳体中间有两个塑料卡扣相连
  • 在组装期间,温柔地从中间推下机壳,重新扣上这两个塑料卡扣。
There are two screws that are shorter-they go to the back near the vent.
wrbandllm - 回复
This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
addvariety - 回复
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
Tommy Huang - 回复
如有必要,可拆卸粘在电池接触板上的塑料盖。
  • 如有必要,可拆卸粘在电池接触板上的塑料盖。
添加评论
用撬棒的平端,将电池连接器从主板插座上直着往上撬起。 确保您只抬起了连接器本身,而不是插座,否则您可能会对主板造成永久性的损坏。
  • 用撬棒的平端,将电池连接器从主板插座上直着往上撬起。
  • 确保您只抬起了连接器本身,而不是插座,否则您可能会对主板造成永久性的损坏。
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
jramsey21 - 回复
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
salvatorebarbera -
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
andrehedegaard -
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Steve - 回复
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
Vadim Gribanov -
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Ethan Tarquin - 回复
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
Caleb Steinborn -
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Jonas Ehrs -
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
Parth Gudhka - 回复
在维修过程中,将电池连接器弯曲,以防止意外接触其插座。
  • 在维修过程中,将电池连接器弯曲,以防止意外接触其插座。
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
sebasgaes - 回复
I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
LaymanLab - 回复
That’s a great idea!
David Lilliebridge - 回复
I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
dbrick - 回复
移除两颗将逻辑板和I/O板线缆固定支架的2.1mm T5 梅花螺丝。 移除I/O板线缆支架。
  • 移除两颗将逻辑板和I/O板线缆固定支架的2.1mm T5 梅花螺丝。
  • 移除I/O板线缆支架。
添加评论
使用撬棒扁平的一端来从逻辑板插座上撬起I/O板插头。 小心,仅撬起I/O板线缆,而不是插座本身。这样会损坏逻辑板。
  • 使用撬棒扁平的一端来从逻辑板插座上撬起I/O板插头。
  • 小心,仅撬起I/O板线缆,而不是插座本身。这样会损坏逻辑板。
添加评论
径直提起逻辑板上I/O板线缆的尾端,来将其弯折远离插座。 防止损坏线缆,请在I/O板线缆的尾端弯折。
  • 径直提起逻辑板上I/O板线缆的尾端,来将其弯折远离插座。
  • 防止损坏线缆,请在I/O板线缆的尾端弯折。
添加评论
小心的在右扬声器下方放置撬棒的尖端,并将其从逻辑板上的插座中撬起。 小心的在右扬声器下方放置撬棒的尖端,并将其从逻辑板上的插座中撬起。
  • 小心的在右扬声器下方放置撬棒的尖端,并将其从逻辑板上的插座中撬起。
添加评论
小心地从顶壳上撬起右扬声器。 小心地从顶壳上撬起右扬声器。 小心地从顶壳上撬起右扬声器。
  • 小心地从顶壳上撬起右扬声器。
I have successfully replaced battery without removing the speaker cables, as proposed by the comments in the next steps.
Furthermore, in the steps after 22, where the battery is removed from the upper case, I have easily performed with a credit card and a drop of rubbing alcohol on it and finished in several minutes. Try it!
kem - 回复
移除将右扬声器和顶壳固定的螺丝。
  • 移除将右扬声器和顶壳固定的螺丝。
    • 一颗5.7mm T5 梅花螺丝。
    • 一颗6.5mm T5 梅花螺丝。
    • 一颗3.8mm T5 梅花螺丝。
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
在右扬声器线缆尾端提起扬声器,将其从机壳中拉出。 在右扬声器线缆尾端提起扬声器,将其从机壳中拉出。 在右扬声器线缆尾端提起扬声器,将其从机壳中拉出。
  • 在右扬声器线缆尾端提起扬声器,将其从机壳中拉出。
添加评论
将撬棒头部插入连接器附近的左扬声器的线缆下,轻轻撬起,使其从主板上脱离。 将撬棒头部插入连接器附近的左扬声器的线缆下,轻轻撬起,使其从主板上脱离。
  • 将撬棒头部插入连接器附近的左扬声器的线缆下,轻轻撬起,使其从主板上脱离。
Same as my comment on Step 11: This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, I skipped the speaker cable removal (Steps 11, 12) and didn't have any problems replacing the battery. ( FYI - I used a heat path method, vs the solvent).
barak - 回复
将固定左扬声器的几颗螺丝拆下:
  • 将固定左扬声器的几颗螺丝拆下:
    • 一颗 5.7 mm T5 Torx螺丝
    • 一颗 6.5 mm T5 Torx螺丝
    • 一颗 3.8 mm T5 Torx螺丝
添加评论
向上提起左扬声器,从电池中滑出,以便将其从上盖中取出。 小心不要将扬声器电缆挂在侧面的螺丝孔柱上 小心不要将扬声器电缆挂在侧面的螺丝孔柱上
  • 向上提起左扬声器,从电池中滑出,以便将其从上盖中取出。
  • 小心不要将扬声器电缆挂在侧面的螺丝孔柱上
添加评论
使用撬棒扁平的一端从逻辑板插座上撬起触摸板排线插头。 使用撬棒扁平的一端从逻辑板插座上撬起触摸板排线插头。
  • 使用撬棒扁平的一端从逻辑板插座上撬起触摸板排线插头。
The trackpad cable can also be of a different type where you pull the tape on it
Rogier van der Heide - 回复
从电池固定胶带上拉起触摸板线缆。 从电池固定胶带上拉起触摸板线缆。
  • 从电池固定胶带上拉起触摸板线缆。
添加评论
如果有必要的话,剥下所有粘在触摸板线缆上的胶带。 使用撬棒末端来将ZIF连接器上的滑杆解锁。 使用撬棒末端来将ZIF连接器上的滑杆解锁。
  • 如果有必要的话,剥下所有粘在触摸板线缆上的胶带。
  • 使用撬棒末端来将ZIF连接器上的滑杆解锁。
Overall, I really enjoyed this project and it was a complete success but this step is the one spot I came up short. I forgot to flip the retaining tab back down when I reassembled and I got a totally unresponsive keyboard and trackpad before I opened it back up and realized I had forgotten this tiny but crucial step.
nathan taylor - 回复
径直从触摸板控制板上的ZIF插座中拔出触摸板线缆。 径直从触摸板控制板上的ZIF插座中拔出触摸板线缆。
  • 径直从触摸板控制板上的ZIF插座中拔出触摸板线缆。
With all due respect, step # 19 and 20 pics shows the ZIF socket on the trackpad board, not the Mac logic board, I think...
See step #17 which seems to be correct. There is an inconsistency in the guide.
Just to be sure...
Bart Van Dessel - 回复
移除一颗将电池板与顶壳固定的3.7mm T5 梅花螺丝。
  • 移除一颗将电池板与顶壳固定的3.7mm T5 梅花螺丝。
添加评论
由 iFixit电池替换组件 提供的液体胶水去除剂可以影响MacBook Pro屏幕的抗反射图层。
  • 由 iFixit电池替换组件 提供的液体胶水去除剂可以影响MacBook Pro屏幕的抗反射图层。
  • 为了保护你的屏幕,在你操作的时候在屏幕金额键盘放置一块铝箔片。
添加评论
如果您有一个带有液体去胶剂的iFixit电池套装,那么现在你就准备好了。 或者,如果您使用热的iOpener方法,请跳过以下三个步骤。
  • 如果您有一个带有液体去胶剂的iFixit电池套装,那么现在你就准备好了。
  • 或者,如果您使用热的iOpener方法,请跳过以下三个步骤。
  • iFixit脱胶剂含丙酮,可能会刺激眼睛和皮肤。
    • 处理和涂抹去污剂时,请戴上防护眼镜。 (您的套件中包含防护眼镜)
    • 禁止不戴护目镜,只戴隐形眼镜。
    • 套件中还包含防护手套。 如果您担心皮肤刺激,请戴上手套。
添加评论
打开你的粘合胶去除剂容器。 将少量(大约1-2毫升)的胶水清除剂装入您的工具包中的注射器。
  • 打开你的粘合胶去除剂容器。
  • 将少量(大约1-2毫升)的胶水清除剂装入您的工具包中的注射器。
    • 最好每次不要超过约1-2毫升的胶水去除剂填充注射器,以避免意外涂抹太多。
    • 在本程序的其余部分,根据需要补充注射器。
添加评论
在最右边的电池单元的边缘均匀涂抹少量的胶水去除剂(约1毫升)。
  • 在最右边的电池单元的边缘均匀涂抹少量的胶水去除剂(约1毫升)。
  • 等待2-3分钟,液体的粘合剂去除剂渗透到电池下方,然后再进行下一步骤。
添加评论
如果您没有粘合胶去除剂,您将使用热的热的iOpener 来加温和软化将电池固定到上壳上的一部分粘合剂,然后在那时仔细撬动。 使用热的iOpener来覆盖一半的最右边的电池
  • 如果您没有粘合胶去除剂,您将使用热的热的iOpener 来加温和软化将电池固定到上壳上的一部分粘合剂,然后在那时仔细撬动。
  • 使用热的iOpener来覆盖一半的最右边的电池
  • 大约一分钟后,重新加热iOpener并将其移动到覆盖最右侧电池的另一半。
添加评论
在最右侧的电池和上盖之间推一个塑料卡,去切断两者之间的粘合剂。 在此过程中,请注意不要用工具损坏任何电池。 损坏的锂离子电池可能会泄漏危险化学品和/或着火。 只能使用塑料撬工具 当使用热的iOpener方法时,如果遇到显着的撬动阻力,请停止并使用iOpener重新加热您正在处理的部分。
  • 在最右侧的电池和上盖之间推一个塑料卡,去切断两者之间的粘合剂。
  • 在此过程中,请注意不要用工具损坏任何电池。 损坏的锂离子电池可能会泄漏危险化学品和/或着火。 只能使用塑料撬工具
  • 当使用热的iOpener方法时,如果遇到显着的撬动阻力,请停止并使用iOpener重新加热您正在处理的部分。
添加评论
在相邻的电池单元中重复操作。 将少量(约1ml)的液体粘合剂去除剂置于电池单元下方,并等待2-3分钟以使其渗透并软化粘合剂。 或者,如果需要,可以使用iOpener重新加热此部分。
  • 在相邻的电池单元中重复操作。
    • 将少量(约1ml)的液体粘合剂去除剂置于电池单元下方,并等待2-3分钟以使其渗透并软化粘合剂。
    • 或者,如果需要,可以使用iOpener重新加热此部分。
    • 将电池单元和上盖之间的塑料卡推进去一英寸,然后缓慢地将电池撬开以分离所有粘合剂。
添加评论
将塑料卡就放在电池下方,以防止粘合剂重新粘黏。 如果使用iOpener,重新加热并放置在最左边的电池上。 再次,将iOpener放在每个位置大约一分钟,再加热,以加热最左边的每个电池单元。
  • 将塑料卡就放在电池下方,以防止粘合剂重新粘黏。
  • 如果使用iOpener,重新加热并放置在最左边的电池上。
    • 再次,将iOpener放在每个位置大约一分钟,再加热,以加热最左边的每个电池单元。
添加评论
重复先前操作来分离最两边的电池。 请记住将少量(约1毫升)的胶水去除剂涂在每个电池下,然后等待2-3分钟才能渗透并软化粘合剂。 使用第二张塑料卡将两个最左侧的电池与上壳分开。
  • 重复先前操作来分离最两边的电池。
    • 请记住将少量(约1毫升)的胶水去除剂涂在每个电池下,然后等待2-3分钟才能渗透并软化粘合剂。
    • 使用第二张塑料卡将两个最左侧的电池与上壳分开。
添加评论
继续重复撬动步骤。 将塑料卡插入第二个最左侧的电池和上盖之间切割粘合两个的粘合剂,并将电池从外壳上撬开。 将塑料卡插入第二个最左侧的电池和上盖之间切割粘合两个的粘合剂,并将电池从外壳上撬开。
  • 继续重复撬动步骤。
  • 将塑料卡插入第二个最左侧的电池和上盖之间切割粘合两个的粘合剂,并将电池从外壳上撬开。
添加评论
将第二张卡牌留在两个左侧电池之间的角落。 如果使用iOpener,请重新加热并将其应用于中央电池。 像以前一样,将iOpener放在每个位置大约一分钟,再加热,以加热每半个中心位置。
  • 将第二张卡牌留在两个左侧电池之间的角落。
  • 如果使用iOpener,请重新加热并将其应用于中央电池。
    • 像以前一样,将iOpener放在每个位置大约一分钟,再加热,以加热每半个中心位置。
  • 在以下步骤中,您可以使用第三张卡或右侧的卡片。 右角粘合剂应该是干燥/冷却的,使得在需要时可以容易地再次拉出电池。
添加评论
如果使用液体粘合剂去除剂,在每个最外侧的两个中间再加1毫升去除剂。 这可能有助于将MacBook Pro的一面提升几英寸,使得粘合剂去除剂以正确的方向在电池包下流动。 在工作时,您可以使用坚固的书或泡沫块来支撑MacBook Pro的一面。 在继续之前,让胶水去除剂渗透2-3分钟。
  • 如果使用液体粘合剂去除剂,在每个最外侧的两个中间再加1毫升去除剂。
    • 这可能有助于将MacBook Pro的一面提升几英寸,使得粘合剂去除剂以正确的方向在电池包下流动。 在工作时,您可以使用坚固的书或泡沫块来支撑MacBook Pro的一面。
    • 在继续之前,让胶水去除剂渗透2-3分钟。
  • 轻轻折叠最右边的电池,将塑料卡正确插入中央电池包下。
  • 将卡片推入其长度的一半左右,来切割电池和外壳之间的粘合剂。
  • 避免碰到触摸板,将卡对准粘合剂所在的地方-逻辑板。
  • 将卡放在适当位置上,以防止粘合剂重新密封。
添加评论
在剩下的电池包上采取相同的操作。 提起外侧的电池,将塑料卡插入左侧中央电池单元的一半左右,避免碰到触控板。 提起外侧的电池,将塑料卡插入左侧中央电池单元的一半左右,避免碰到触控板。
  • 在剩下的电池包上采取相同的操作。
  • 提起外侧的电池,将塑料卡插入左侧中央电池单元的一半左右,避免碰到触控板。
添加评论
返回到右侧中间中心电池下的塑料卡片上,然后扭动它将整个电池与上壳分开。 到现在,您已经将电池和顶壳之间的粘合剂切割完了,电池应该很容易的被取出来了。
  • 返回到右侧中间中心电池下的塑料卡片上,然后扭动它将整个电池与上壳分开。
  • 到现在,您已经将电池和顶壳之间的粘合剂切割完了,电池应该很容易的被取出来了。
    • 如果还不是那么容易的取出来,你需要重新加热iOpener并将其放在卡住的地方,再继续小心的使用塑料卡片切割粘合剂。
I found this to be more difficult than the edge sections. I had to reapply a few times the adhesive removal from both sides of the center sections before I was able to pry the battery. Take time and use the adhesive removal several times.
Maxim Bulat - 回复
移除电池。 在安装新的电池前,从MacBook Pro壳子中移除所有残留的粘合剂。
  • 移除电池。
  • 在安装新的电池前,从MacBook Pro壳子中移除所有残留的粘合剂。
    • 幸运的是,你可以用你的手慢慢地将粘合剂撕下来。
    • 否则,用一点粘合剂去除剂将每个粘合剂部分浸泡2-3分钟,然后用撬片或其他工具将其刮掉。 这可能需要相当多的工作,所以要耐心。
    • 擦拭残留的粘合剂去除剂,花一些时间让MacBook Pro风干。
  • iFixit套件中的更换电池已预先安装了粘合剂。 在剥离覆盖胶粘剂的胶片之前,仔细确保电池的对位,然后将每个电池牢固地按入到位。如果更换电池上有原电池上不存在的胶片、衬垫,请将它们移除。
  • 使用前请先校准电池:让其用尽,然后将其充电至100%,然后再次用尽,直至MacBook Pro自动关闭。 再次充电并正常使用。
  • 如果您在安装新电池后发现任何不寻常的行为或问题,可能需要重新设置MacBook Pro的SMC。
Remember that the speakers fit on either side of the battery. When placing the new battery, make sure to leave enough space for them.
Cesario Uy - 回复
结论
要重新组装您的设备,请按照相反的顺序执行这些说明。
93等其他人完成本指南。
特别感谢这些译者︰
70%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Andrew Optimus Goldberg
于2009年10月17日注册
372,006 信誉积分
创作了1,284篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了5,912篇指南
is it possible to use MBP early 2015's battery on a late 2013 model?
gianluca pertosa - 回复
No, they're different parts.
fastasleep -
Thanks to this guide I saved my broken MacBook Pro from a coffee spill that killed the battery. It cost me about 30% compared to what it would have cost to have the battery changed at an Apple authorized repair center. It wasn't easy to do, but that just made it all the more satisfying.
One comment: the new battery pack I bought came attached to a thin film which had to be removed. I unfortunately tore off some of the strips of glue attached to the back of the battery cells, before getting the hang of it. No big deal. But if you have to do the same thing: peel slowly.
Fredrik - 回复
After i replace the battery, the new battery is outofsync with osx battery indicator. When the indicator hit the 30% mark the macbook just shutdown completly. How do i syncroniz the new battery with osx?
The tutorial i saw only, tell you to fully charged the battery and let it depleet until the warning message pop up that your battery is low and your mac go into sleep mod. Problem my mac cant go into sleep mod because it thinks that it has 30% left of juice.
Is there any method to change the sleep setting or to force a recalibration?
enis alijagic - 回复
I would download an application called coconut battery from here: http://www.coconut-flavour.com/coconutba...
This will indicate your battery's current health (I am not sure how accurate it is or how it measures the milliamps/hour) which might help you determine when you need to recharge it. I don't know what else you could do but I'd check the battery's health before anything since it might be causing the problem if it is faulty.
Alex Someone -
Brilliant guide, worked a treat.
Was tricky to remove the battery even with iOpener but carefully persevered. Took around 1hr 15 in total.
Thanks so much, this saved my girlfriend a lot of money!
Ben Saunders - 回复
How strong is the adhesive on the iFixit replacement battery, compared to the Apple OEM adhesive? Are we looking at a similar painful extraction process if/when we pull the replacement battery?
For that matter, is an Apple-esque strong adhesive actually necessary in this application? Double-sided tape is usually weaker; it might be a little thinner than the adhesive layer, and certainly far more user serviceable. Would tape be sufficient to hold the battery in place? Once you've got the bottom case screwed back on, the battery is immobilized anyway.
adlerpe - 回复
I really want to know the answer to this one
frugalpov -
It's still going to be fairly painful to remove. The battery needs to be very well secured—you don't want a soft-shell lithium ion battery coming loose and moving around inside the laptop. Even a little bit of movement could be dangerous.
Jeff Suovanen -
Saved me fortune. I was using the laptop for more than year as a desktop. The new battery helped me bring the macbook back to life.
Dipak Patil - 回复
Hi Dipak,
Are you from India? I try to Oder the Mac battery but the product can’t be shipped to India. Is there any other website that I can order the battery?
Tsering Dhondup -
Thanks for the guide! It helped me to save my MacBook from a coffee spill.
Pan Fantomas - 回复
Apple Canada quoted me ~300$ for battery + keyboard replacement though acknowledged that the battery had died prematurely (1.5 years since the date of purchase). When I opened the case two out of six sections were swollen. I ordered from ifixit their battery and the tools and with rate conversion + delivery to the border + taxes at the border it came to 180$. After ~2 hours I have 100% healthy battery installed in my macbook pro and it saved me 120$.
Maxim Bulat - 回复
添加评论
浏览统计数据:
过去的24小时: 152
过去的7天: 977
过去的30天: 4,710
总计 96,048
