简介
Luckily for repairers, pulling the battery out of the Lenovo K5 Note is a simple task. Unfortunately, however, a broken display will require a bit of work for repair, thus yielding a repairability score of 6 out of 10.
Packaging.
  • Packaging.
  • Front and back reference shots.
添加评论
Rear case is a tight fit, but with the SIM card removed it pries off with determination and a couple picks. No screws or glue.
  • Rear case is a tight fit, but with the SIM card removed it pries off with determination and a couple picks. No screws or glue.
  • Spring contacts connect the camera flash module and presumably some case antennas.
  • Camera flash module is lightly adhered to the rear case.
添加评论
  • The battery connector is secured underneath a bracket attached to this fingerprint sensor. Three Phillips screws secure the bracket.
  • Once the bracket's removed, there's a pull tab for easy battery removal.
添加评论
  • On the way to removing the motherboard we had to break through a tamper-evident sticker.
添加评论
  • The motherboard is booby-trapped with cables on both sides.
  • The power/volume button assembly is glued to the chassis and soldered to the motherboard.
  • The headphone jack is soldered to the motherboard.
Where is the antenna in this mobile
MAHESH KURTKOTI - 回复
  • A handful of Phillips screws secure the daughterboard—all the same size.
  • The vibrator motor is soldered to the daughterboard.
  • The primary speaker connects by way of spring contacts.
添加评论
  • The primary camera is firmly glued to the midframe. It might be possible to extract it without first removing the motherboard, but only with some risk of pry damage to the motherboard.
  • The selfie camera is installed on the back of the motherboard, requiring removal of the motherboard for access.
  • Both cameras are modular.
  • With the interconnect cables out, this is as far as we go. The display looks to be firmly secured to a mid-frame for rigidity and would be impractical to separate. While it's the most likely component to break, everything else mounts to it—making it effectively the last component to be removed.
添加评论
  • The Lenovo K5 Note earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery is replaceable with just a couple of tools.
    • A single Phillips 00 driver takes care of all the screws.
    • Some parts are modular, but high-wear components like the headphone jack and charge port are not.
    • Sparing use of adhesive.
    • Replacing the display assembly requires removing every other component from the device first.
    • Manufacturer does not provide user-accessible repair documentation.
添加评论
终点
24等其他人完成本指南。
Jeff Suovanen
于2013年08月06日注册
184,020 信誉积分
创作了149篇指南
团队
iFixit iFixit 的会员
Community
111 名成员
创作了6,680篇指南
I repaired (assembled)my old phone and the useful parts are sold (which is in dead mobile
TECHNO DUDE TECHNO DUDE - 回复
Bro...My phone wifi not connecting
sudheesh p s - 回复
Error.plug out the charger
How to fix this problem in k5 note
elbahar1979 - 回复
When somebody call me i can hear their voice properly, but they can’t hear my Voice properly so i have to raised my voice …
How to fix this Probem in Lenovo K5 note..please help
John Ckck - 回复
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 59
过去的30天: 266
总计 3,693
