简介
We disassembled the LG Gram 15" to see how the Surface/MacBook competitor stacks up.
Reference shot with packaging.
  • Reference shot with packaging.
添加评论
Reference shots. Reference shots. Reference shots.
  • Reference shots.
添加评论
We first use tweezers to remove the three plastic screw covers and five rubber bumpers. We find eight Phillips screws holding the case together. After removing the screws, we use picks to remove the lower case which is held in with clips.
  • We first use tweezers to remove the three plastic screw covers and five rubber bumpers.
  • We find eight Phillips screws holding the case together.
  • After removing the screws, we use picks to remove the lower case which is held in with clips.
添加评论
Lower case is removed to view the internals.
  • Lower case is removed to view the internals.
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
Battery comes out easily—just 6 screws and a connector on the motherboard. SSD is standard and user-upgradable. RAM is also standard and user-upgradable.
  • Battery comes out easily—just 6 screws and a connector on the motherboard.
  • SSD is standard and user-upgradable.
  • RAM is also standard and user-upgradable.
  • At this time, it's cool to note that you can remove the display assembly, speakers, daughterboard, backup battery, motherboard, trackpad, and the fan.
    • Perhaps slightly more useful knowledge: The only component we cannot remove is the keyboard.
添加评论
We chose the fan + heatpipe combo. 7 screws and 1 plug Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card. There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • We chose the fan + heatpipe combo. 7 screws and 1 plug
  • Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card.
    • There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • Trackpad's next. It's held in with 4 screws and pops out the top of the lower case.
Is the CPU easily removable from the motherboard or is it soldered? In other words, is the processory/chip user-upgradable? Thank you -
ken maready - 回复
I/O board, wireless card, speakers, and CMOS battery. The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
  • I/O board, wireless card, speakers, and CMOS battery.
  • The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
INTEL® DUAL BAND WIRELESS-AC 7265 is M.2 1216 or M.2 2230?
Miguel Gandara - 回复
Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
  • Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film.
  • It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
添加评论
Four screws later, the display assembly is free from the lower case.
  • Four screws later, the display assembly is free from the lower case.
添加评论
The LG Gram 15&quot; earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Most components are immediately accessible after removing the lower case cover.
  • The LG Gram 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • Most components are immediately accessible after removing the lower case cover.
    • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
    • Battery is also user-replaceable.
    • Only Phillips screws are used throughout the device.
    • Manufacturer does not provide user-accessible repair documentation.
添加评论
终点
另外一个人完成了本指南。
Jeff Suovanen
于2013年08月06日注册
161,549 信誉积分
创作了412篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了5,916篇指南
添加评论
浏览统计数据:
过去的24小时: 14
过去的7天: 118
过去的30天: 580
总计 5,195
