简介
This guide will help you with the process of replacing the Wi-Fi PCI Card in your device.
配件
无需配件。
Unscrew the two screws using a Phillips #0 screwdriver.
  • Unscrew the two screws using a Phillips #0 screwdriver.
添加评论
Use a spudger to lift the back cover and remove it from the device.
  • Use a spudger to lift the back cover and remove it from the device.
添加评论
  • Unplug the two wires that are on the Wi-Fi PCI card (white & black).
添加评论
  • Unscrew the single screw in front of the Wi-Fi PCI card using the Phillips #0 screwdriver.
添加评论
  • Remove the Wi-Fi PCI card from the device.
添加评论
结论
abdualmjeed Alabdurazzaq
于2018年01月15日注册
471 信誉积分
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 31
