简介
This guide shows how to replace the screen for the Insignia NS-DS9PDVD15.
  1. Turn the power off. Slide the power button to OFF.
    • Turn the power off. Slide the power button to OFF.
    添加评论
  2. Unplug AC adapter from car cigarette lighter.
    • Unplug AC adapter from car cigarette lighter.
    添加评论
    • Make sure there is no DVD or CD in the disc tray
    添加评论
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
    添加评论
    • Pry off back panel with prying tool, then remove by hand.
    添加评论
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
    添加评论
    • Slide the tray up and off of the hinge completely.
    添加评论
    • After the bottom cover and disk tray have been removed, remove the back panel from the top half.
    • There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
    添加评论
    • Once all the screws are removed, pry off the cover with the pry tool.
      • You'll see the PC board, back of the speakers, and the back of the screen.
    添加评论
    • Remove the ribbon cable carefully with the pry tool.
    • First, push out the black portion.
    添加评论
    • Next, push out the 'ribbon' with the pry tool.
    添加评论
    • Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
    添加评论
    • After the screws and washers are removed, you can lift the screen off with the pry tool.
    添加评论
结论
Johnny Rozo
于2018年04月03日注册
583 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 3
总计 126
