简介
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap.
工具
无需工具。
配件
This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure.  As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
  • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
添加评论
Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
  • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
  • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
添加评论
  • Turn the headlights ON.
添加评论
  • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
添加评论
  • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
添加评论
  • Within 5 seconds, release the Sel/reset button.
  • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
  • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
  • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
  • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
添加评论
终点
3等其他人完成本指南。
David Spalding
于2015年11月12日注册
4,940 信誉积分
创作了9篇指南
This looks like the fix I may be looking for! What make or model vehicle is this? My Chrysler Town & Country used to occasionally get the gauge needles pinned to infinite and there was a similar procedure to run the self test and reset the needles. My Mom’s old GM Delta 88 has been having a similar problem and I am wondering if this procedure will work on her car.
George Hickey - 回复
添加评论
浏览统计数据:
过去的24小时: 104
过去的7天: 1,027
过去的30天: 4,769
总计 43,205
