简介
When going to plug in your 1/4 in guitar plug, you feel the output jack push into your guitar. This is not an uncommon occurrence for guitar players. Sooner or later something has to give. The wear of everyday use has driven the output jack inside the guitar. Now, we'll have to take the strings off the instrument and go in after the input jack. After we've got the jack, we'll have to secure it to the body, so that it doesn't happen again.
配件
无需配件。
Where did my output jack go? Don't worry - we'll be back to jamming in no time!
  • Where did my output jack go? Don't worry - we'll be back to jamming in no time!
添加评论
Lets start by gently setting the guitar on a soft surface.
  • Lets start by gently setting the guitar on a soft surface.
  • You may hear the rattling of the output jack within the guitar as you do this.
添加评论
  • Next, we're going to need to get those strings off of there. So lets start at the 'tuning machines' at the head of the guitar.
添加评论
  • Begin turning the tuning machines in whatever order you like. Here, I've started at the low E string. Begin turning it toward yourself to loosen the string up.
添加评论
  • Carefully unwind the guitar string from the tuning machine and then repeat this step for the other five strings.
  • The very ends of the strings can sometimes be pointy and needle like. Also, watch out for strings whipping your hands after the tension is released.
添加评论
  • After the strings are released from the tuning machines, you can now release the pegs that hold them into place. These are located at the bottom of the guitar body, just below the sound hole.
  • put these off to the side in a tray or someplace they won't get lost!
添加评论
  • We now have access to the inside of our acoustic-electric guitar.
添加评论
  • Using a flashlight, we can have a look around through the sound hole and see what we can find.
  • Dropping your flashlight onto your guitar body could really do some damage, so be careful.
添加评论
  • Tilting the guitar slightly and looking in through the noise whole, we've spotted our misplaced jack.
添加评论
  • The angle is too awkward to feed the jack through the whole by hand, but we can guide the jack to the magnetic screw driver and hopefully pull it out through the hole in the guitar body.
  • Here I've laid my flashlight down to free up my hands and provide some extra light.
  • You may need to tilt the guitar at an angle that makes the jack move closer to your hand or the screwdriver.
添加评论
  • Gently guide the jack through the hole using the magnetic screwdriver.
添加评论
  • Feed the output jack into the threaded hole and jack in. You're ready to jam!
添加评论
结论
Now that we've fished out the input jack from the guitar body, we can start jamming again. Let's be more careful plugging out 1/4 in cable in from now on.
michael burrell
于2017年02月21日注册
101 信誉积分
撰写一个指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 18
总计 251
