简介
This guide shows you how to replace the motherboard of your Huawei P8 Lite.
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone. Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
添加评论
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool. When all clips are open, you can easily remove the back cover from the rest of the phone. We do not recommend to try to remove the back cover whilst you haven't opened all clips. They are very strong and you will risk to break the back cover.
  • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
  • When all clips are open, you can easily remove the back cover from the rest of the phone.
  • We do not recommend to try to remove the back cover whilst you haven't opened all clips. They are very strong and you will risk to break the back cover.
The back panel is really really easy to brake, be careful :)
romaingauthier - 回复
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone. Remove the 4 Torx T5 screws which hold down the lower part of the loudspeaker. Remove the three Phillips #000 screws which hold down the upper part of the loudspeaker.
  • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  • Remove the 4 Torx T5 screws which hold down the lower part of the loudspeaker.
  • Remove the three Phillips #000 screws which hold down the upper part of the loudspeaker.
  • Remove the loudspeaker carefully.
The 4 screws wich hold down the lower part of the loudspeaker are Torx screws for me. But it's a French Huawei, doin' nothing like the others :)
Christopher Hourlier - 回复
Die Wasserschadenindikatoren sitzen unter dem Mainboard. Bei den Aufklebern auf den TORX handelt es sich um Garantiesiegel.
Andre Richter - 回复
Danke für den Hinweis, wurde so übernommen.
Dominik Schnabelrauch -
Remove the three Phillips #000 screws that hold the metal plate in place. Remove the metal plate with a tweezer. Unplug the battery flex connector with a spudger.
  • Remove the three Phillips #000 screws that hold the metal plate in place.
  • Remove the metal plate with a tweezer.
  • Unplug the battery flex connector with a spudger.
添加评论
Peel off the liquid indicator in the top right corner and remove the two Torx T5 screws. Remove the five Phillips #000 screws. Carefully pry off the plastic cover on the left side.
  • Peel off the liquid indicator in the top right corner and remove the two Torx T5 screws.
  • Remove the five Phillips #000 screws.
  • Carefully pry off the plastic cover on the left side.
  • Then remove the top cover.
添加评论
Remove the SIM card and SD card trays. Disconnect the three plug connectors and one ZIF connector. Unlock the ZIF connector by lifting the small black plastic lever.
  • Remove the SIM card and SD card trays.
  • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
添加评论
Remove the volume and power button cable. Take out the motherboard by lifting the bottom part first.
  • Remove the volume and power button cable.
  • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
添加评论
结论
To reassemble your device, follow these instructions in reverse order and apply adhesive where necessary.
另外一个人完成了本指南。
Tobias Isakeit
于2014年03月31日注册
23,902 信誉积分
创作了197篇指南
团队
iFixit iFixit 的会员
Community
117 名成员
创作了5,757篇指南
添加评论
浏览统计数据:
过去的24小时: 15
过去的7天: 91
过去的30天: 310
总计 1,507
