简介
Unlike most tablets, the Huawei MediaPad M2 10.0 has a display assembly that is easy to remove, a big positive when looking at repair. The battery is incredibly difficult to remove, however, giving the tablet a 7 out of 10 on the repairability scale.
Front/back reference shots. Front/back reference shots. Front/back reference shots.
  • Front/back reference shots.
添加评论
Simple plastic clips make opening easy. The display cable has enough slack to lay the display aside to work on the interior.
  • Simple plastic clips make opening easy.
  • The display cable has enough slack to lay the display aside to work on the interior.
添加评论
Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
  • Display assembly carries: display interconnect cable, home button/fingerprint reader and cable, and its bracket.
    • Home button/fingerprint reader is easily removed and replaced.
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
The battery is glued to the rear case by very strong adhesive. Heat, adhesive removal fluid, and much prying, the battery is removed.
  • The battery is glued to the rear case by very strong adhesive.
  • Heat, adhesive removal fluid, and much prying, the battery is removed.
    • Frustrating that an inevitable repair/replacement would be this hard, but at least it isn't blocking other components' replacement.
添加评论
The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious. Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
  • The bracket over the speaker and button/headphone jack cable has two different kinds of screws, Torx and Phillips, making removal obnoxious.
  • Removable in parallel with the battery are: lower speaker, speaker/antennas, brackets, and microphone bumper.
    • SIM tray can be removed while the device is sealed, obviously.
添加评论
The final components out of the rear case are fairly modular:
  • The final components out of the rear case are fairly modular:
    • SIM reader and vibrator assembly
    • Headphone jack and button cable assembly
    • Front and rear facing cameras
    • Motherboard, unfortunately has a soldered-on charging port. That means a more expensive repair for a common failure point.
添加评论
The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair): The display is easily removed from the simple clips holding it to the body, simplifying repairs.
  • The Huawei MediaPad M2 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • The display is easily removed from the simple clips holding it to the body, simplifying repairs.
    • Most components are modular and not overly complex.
    • The battery is extremely difficult to remove, even with heat and prying.
    • The charging port is soldered to the motherboard, making replacement of this high-use component expensive.
    • Manufacturer does not provide user-accessible repair documentation.
添加评论
终点
另外一个人完成了本指南。
Andrew Optimus Goldberg
于2009年10月17日注册
372,126 信誉积分
创作了1,284篇指南
团队
iFixit iFixit 的会员
Community
114 名成员
创作了5,916篇指南
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 45
过去的30天: 237
总计 2,248
