简介
This guide will explain how to do simple maintenance on your Avanti 308YWT evaporator tray. This involves simply removing and cleaning the tray. If the evaporator tray is not cleaned it could cause the fridge to start leaking, which could eventually damage the floor.
Before starting, unplug the refrigerator.
  • Before starting, unplug the refrigerator.
添加评论
Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
  • Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
添加评论
  • Remove the evaporator tray by simply pulling up and out the tray. make sure that none of the liquid spills.
添加评论
  • The evaporator tray might have ice build up on it. You can remove this ice by pouring warm water on the tray. After the ice is melted, clean the tray with warm water and soap.
添加评论
  • Dry and reinsert the tray.
添加评论
  • Plug the refrigerator back in.
添加评论
结论
6等其他人完成本指南。
Seye
于2014年10月11日注册
344 信誉积分
撰写一个指南
团队
USF Tampa, Team 1-38, Donnelly Fall 2014 USF Tampa, Team 1-38, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G38
1 名成员
创作了1篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 25
总计 962
